#29 | |
Site Moderator
Drives: Stuff
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#30 |
Drives: Black 86
I hope you are right. Lets see the real cause. That's what I believe thus, will leave my pulleys oem.
I double checked my cars awhile ago (86 & bmw), tensioner doesn't move that much, the video above was somewhat wild / crazy. Something is wrong |
#31 | |
Red wine
Drives: Subaru BRZ(R.I.P)
#32 |
Site Moderator
Drives: Stuff
It's being exaggerated due to the misfire. The entine engine is moving and RPMs aren't stable. Mines move a LOT, not much less than his.
-Dave
| The Following User Says Thank You to Dave-ROR For This Useful Post: | track_warrior (02-25-2013) |
#33 | |
Site Moderator
Drives: Stuff
-Dave
| The Following User Says Thank You to Dave-ROR For This Useful Post: | Jesse (03-07-2013) |
#34 | |
Drives: '15 STi Ltd
#35 | |
Site Moderator
Drives: Stuff
-Dave
#36 | |
Track Junkie
Drives: Faster than the Stig!
Im using 5w-30 Mobil 1. The car is still misfiring constantly in idle and the weird thing is there is no check engine light but she smoked for a bit on startup. Going to the dealer tomorrow and hopefully they can figure it out. A friend in a local shop says subarus often crack pistons and he says my car seems to have the symptoms. Im not very mechanically savvy but i hope its nothing serious.Some notes: -My oil level has not dropped since Feb 1st, its still full. -Coolant seems fine as well
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
#37 |
Did you miss a shift and over-rev the engine?
#38 |
NASA SpecE30 Racer
My guess is that your tuner tuned the AVCS very aggressively and for some reason some part of that system began having issues and has now failed. Could be oil pressure related since it occured at the track.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#39 | |
Dirt Trackin'
Drives: '13 Raven FR-S MT
Hope you get it figured out and back to the track, down-time sucks! |
| The Following User Says Thank You to FReSh For This Useful Post: | track_warrior (02-25-2013) |
#40 |
Drives: 2013 FRS/01 Tacoma
Really guys the crank pulley does not effect timing the engine is spun with an internal chain and the crank position sensor is on the flywheel side. If anything one of the VVTI came gears are damaged. Maybe you are using thicker oil then recommended and debre is in your oil blocking the passages. Or like others said a tune issue is the cause not making timing adjustment when needed.
#41 |
Dirt Trackin'
From those CEL's I would check that bank-1 camshaft sensor.
| The Following 2 Users Say Thank You to FReSh For This Useful Post: | track_warrior (02-25-2013), tripjammer (03-07-2013) |
#42 | |
Track Junkie
Nope, i actually shift at 7.2k rpm's since there is really not much going on after that.
| Scion/Toyota broke 3rd brake light applying tint | Lefty | Cosmetic Modification (Interior/Exterior/Lighting) | 32 | 10-31-2019 06:23 PM |
| How to wash your car in an hour or less, make it look like a pro, and not go broke... | seven | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 141 | 01-30-2015 11:32 AM |
