Old 02-13-2013, 12:59 AM   #141
zkubidu
Drives: SWP BRZ
@Dave-ROR, do you have before and after oil temps of the setup while on a track? Just curious how well the setup is cooling the oil. Thanks.
zkubidu is offline   Reply With Quote
Old 02-13-2013, 11:24 AM   #142
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I haven't been on track since installing the cooler and didn't have a gauge on the car before I plan to loop it (to eliminate the cooler) on track if everything else is going smoothly.
Others have seen close to 300 degrees I believe in the south.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-13-2013, 10:53 PM   #143
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
At what Oil Temperature should I consider an oil cooler as necessary?
Old 02-13-2013, 11:35 PM   #144
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I'd prefer to keep it down around 250-270.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-14-2013, 12:07 AM   #145
OrbitalEllipses
Drives: Attitude
Does a higher viscosity oil get hotter, cooler, or no difference?
Old 02-14-2013, 01:44 AM   #146
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I have no idea.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-19-2013, 08:55 AM   #147
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
@robispec did you get to the track last weekend for some testing?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-24-2013, 02:32 PM   #148
zkubidu
Drives: SWP BRZ
Maybe I'm missing something...but where did you end up mounting the oil temp sender? I see you got the oil pressure on the end of the galley at the head, but didn't see where you decided to move the temp sender once the sandwich plate was removed.
Thanks again.
Old 02-24-2013, 10:39 PM   #149
robispec
Drives: Black frs project
ok logging still not working but at ACS in fontana the ECU would start pulling power at 200 degree farenheit.... with a SEVENTY degree ambient day(I went back to my stock cooling system to baseline the car) oil temps were in the 290-295 range no pressure readings but I have gone to a 5/30 oil
Putting the BIG SOLUTION back in to see how it works.
robispec is offline   Reply With Quote
Old 02-25-2013, 08:14 AM   #150
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I think it was 87 on Saturday and a few degrees less yesterday. I hit 235 after the cooler max but normally 230. Not sure how that would compare to the oem sender's reading. It's likely higher than the pan would read but lower than the head oil temps of ourse. My guess is that I'm within my 250 range that I'm good with.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-25-2013, 12:24 PM   #151
celica73
Is that 200 deg oil or water temp (assuming you are talking oil temps)?
Old 02-25-2013, 04:31 PM   #152
robispec
200 is water
Old 02-25-2013, 08:25 PM   #153
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Someone asked does thinner oil cool faster/better... Sort of.
Go here for answer: http://www.bobistheoilguy.com/motor-oil-105/
Oil pan temps should be hottest because that's where the oil falls after it's picked up all the heat from flowing through the engine.
Since you're also a Honda guy you might want to know that I'm looking at running a 12.5:1 B18C with big cams at 8500rpms for 6 hours in a 2100 CRX with a 25gallon fuel cell. Oh yeah.. with an oil cooler.
PRO86 | STL | LuckyDog
Old 02-25-2013, 08:28 PM   #154
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Nice, 6 hours is nothing though
And I've seen cooler temps in the pan due to air flow and oil volume. Depends on sensor location, etc. Sandwich plates often read hot because the block heats the sandwich plate itself.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Oil Cooler wootwoot Engine, Exhaust, Transmission 92 12-27-2014 08:10 PM
ARC Oil Cooler ill86 Engine, Exhaust, Transmission 19 10-18-2014 04:30 PM
One-Off Oil Cooler? wootwoot Engine, Exhaust, Transmission 37 07-18-2014 05:42 PM
Oil Cooler kit for FI applications, getting one? JoeBoxer Forced Induction 84 01-20-2013 09:48 AM
Cooler than drifting! Rampage Other Vehicles & General Automotive Discussions 8 04-03-2012 12:55 AM
