Old 02-24-2013, 01:32 PM   #29
Allch Chcar
Drives: N/A
Originally Posted by XPR Small Block View Post
i think its the opposite with the oil same thing with motor oil colder it is the thinner it needs to be, hotter temps need thicker oils. think about it if the tranny is scratching the syncros when its cold is because the oil isnt able to expand enough to cover all the parts correctly when its warm the tranny is fully coated = fully functional trans
Yep, I got it backwards even after considering it. Lighter oil is better for colder temps.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 02-25-2013, 12:53 AM   #30
weedtank
weedtank's Avatar
Drives: Ultramarine
So is this a normal occurence? I have about 400 miles on my car so far and it grinds going from 1st to 2nd in the cold. Goes away when warmed up though..
weedtank is offline   Reply With Quote
Old 02-25-2013, 01:10 AM   #31
XPR Small Block
Drives: Scion Frs
sounds like its normal brake in but i still wouldnt want it scratching because thats added wear on the trans.. if it persists i would drain fluid an inspect it for any shavings. maybe change to a thinner fluid??? an also try an sync your rpm with your next gear selection maybe your dropping too many rpms before you ingauge the gear?/ not tryin to knock you just helpful tip..
XPR Small Block is offline   Reply With Quote
Potential trade. Supermassive Cosmetic Modification (Interior/Exterior/Lighting) 2 12-21-2012 05:40 PM
FA20 N/A potential ? adprokid Engine, Exhaust, Transmission 4 11-18-2012 09:48 AM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 08:39 PM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 07:44 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
