Old 01-29-2013, 09:52 PM   #1
its_the_biz
Drives: Whiteout 6MT
Potential bad gear box?
when i first purchased the car, the gears would shift right into spot like a hot knife on butter. however, now occasionally the gears would act up and require a little bit of effort to pop into position. and it happens randomly. and other times it would be perfectly smooth. anyone else getting this problem?
its_the_biz is offline   Reply With Quote
Old 01-29-2013, 09:55 PM   #2
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Mostly 1st to 2nd?
Weather affects it as well and I highly doubt its a bad tranny tho we did have one car were the dealer forgot to fill the tranny fluid.
Easy fix tho get some Motul in that gear box and you will be fine.
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 01-29-2013, 09:59 PM   #3
so26
Drives: Raven FR-S 6MT
Are you new to driving a MT car? Does this occur during upshifts, downshifts or both?
so26 is offline   Reply With Quote
Old 01-29-2013, 10:04 PM   #4
its_the_biz
Originally Posted by Mr.Jay View Post
Mostly 1st to 2nd?
yes mostly 1st and 2nd. i'll swap out the fluids and give it a try.
i took a few year break from driving MT. but i dont feel that is a factor. it happens both up and down shifts.
Old 01-30-2013, 04:46 AM   #5
Snake
Drives: ADM Toyota 86 GT
Mine started crunching into second gear after about 300kms. Is worse when it is cold gets a bit better when it is warm.
Snake is offline   Reply With Quote
Old 01-30-2013, 05:51 AM   #6
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
I had crunching right up till i had my serviced today
It back to being hot knife into butter .
I will ask tomorrow what they did to it to make it soo much better!
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 01-30-2013, 09:17 AM   #7
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
What mileage are you at?
Old 01-30-2013, 11:21 AM   #8
chutrain
chutrain's Avatar
Drives: WRB BRZ
Mine has been a little tough to get into second when it's cold. Only noticed recently with about 4500 miles. Going to swap out the fluids. Was going to do it when I had around 1k miles, but never got around to it.
In the garage:
1988 BMW E30 M3
2003 Ducati ST4s ABS
2006 Subaru Legacy GT Spec B #444/500 (For Sale)
2013 Subaru BRZ WRB Limited - Acquired 9/15/12
chutrain is offline   Reply With Quote
Old 01-30-2013, 11:32 AM   #9
Yruyur
Yruyur's Avatar
Had my transmission replaced for the shifting getting harder then it started grinding going into 4th every time.
Old 01-30-2013, 11:33 AM   #10
reeves
Originally Posted by its_the_biz View Post
..now occasionally the gears would act up and require a little bit of effort to pop into position. and it happens randomly. and other times it would be perfectly smooth. anyone else getting this problem?
I got the same problem.. 2nd gear randomly grinds. Other times is perfectly smooth.. Switched to Pentosin MTF-2 tranny fluid for 4K miles now, but I still get the random grinds. Pentosin did make shifts feel alot better/easier though, especially when it's cold. Before Pentosin, it was all but impossible for me to shift into 2nd when cold.
I am starting to notice after a long drive (30 minutes or more) the grinds rarely, if ever, occur anymore.. maybe it goes away after the tranny gets really hot?
reeves is offline   Reply With Quote
Old 01-30-2013, 05:54 PM   #11
A5D5TRYR
A5D5TRYR's Avatar
Drives: FR-S 6MT Ultramarine (BeeDrill)
I put Motul Gear 300 in mine and although it is better it still hasn't fixed 2nd gear when the car is cold and it's below freezing. Above freezing the Motul has definitely made everything much smoother though. I will be trying Pentosin next. Unfortunately it is very expensive. There's only so many times I want to spend $100 bucks to see if some other fluid will make things better. But I will report back on the difference between the Motul and Pentosin for me when I get around to changing it.
2013 Scion FR-S - Ultramarine 6MT
A5D5TRYR is offline   Reply With Quote
Old 01-30-2013, 06:06 PM   #12
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Also forgot to mention that if its really bad in the cold double clutching helps a lot
Out of the FRS game
Old 01-30-2013, 09:17 PM   #13
DriftEightSix
Pegasus White
Drives: 86
12730 kms. Fixed at around 2000kms and returned less then 1000kms later. if it happens again i am going to bitch my ass off.
Old 01-30-2013, 09:18 PM   #14
DriftEightSix
Pegasus White
Drives: 86
It was the only way to change gears!! evens whilst rev matching it wasn't 100% smooth.
Potential trade. Supermassive Cosmetic Modification (Interior/Exterior/Lighting) 2 12-21-2012 05:40 PM
FA20 N/A potential ? adprokid Engine, Exhaust, Transmission 4 11-18-2012 09:48 AM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 08:39 PM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 07:44 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
