Old 02-23-2013, 09:45 PM   #15
Synack
Boosted
Synack's Avatar
Drives: Sideways
Nothin a blowtorch can't fix
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 02-23-2013, 09:48 PM   #16
Foobar
SLO NO MO
Foobar's Avatar
Get a breaker bar or some other long pipe that you can put over your wrench to get leverage.
Old 02-23-2013, 10:01 PM   #17
reeves
It's well known that Dealership mechanics have ONE setting for their impact gun: MAXIMUM torque!
Just be aware of that next time you take your car in for them to work on.
Old 02-23-2013, 10:03 PM   #18
AsphaltLover
AsphaltLover's Avatar
Drives: 2006 Scion TC, 2013 FR-S Asphalt
they did this to mine also. standing on it normally works, but the one they happened to overtighten on mine was the wheel lock. would not come off at all since the wheel lock key would slip out of the pattern if you applied too much force.
if i had a flat tire i'd have been fucked.
AsphaltLover is offline   Reply With Quote
Old 02-23-2013, 10:40 PM   #19
ahausheer
Re-member
Drives: Toyota camry
Should probably add that they may be cross threaded if you cannt bust em loose with all your might or weight. New-ish lug nuts just don't get that tight. Axle nuts- yes, lug nuts no.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 02-24-2013, 01:29 AM   #20
naticedog04
Drives: 02 RSX-type s(sold) 99 Civic CX
Quick question, did u jack up the car by the tire to lighten the pressure??? If so, get a breaker bar... Good luck!!!
naticedog04 is offline   Reply With Quote
Old 02-24-2013, 04:11 PM   #21
Razz
Razz's Avatar
Drives: Fast
Take it to the dealer. If there is a problem, they did it.
Then tell them to use a torque wrench.
If you had your oil changed there make sure they untighten it and torque it by hand.
Razz is offline   Reply With Quote
Old 02-24-2013, 05:15 PM   #22
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
Originally Posted by ahausheer View Post
Apply wrench, use car jack under end of wrench, protect the eyes, cross the fingers, and viola.
...that's voila
Life is short...NO BORING CARS
russv is offline   Reply With Quote
Old 02-24-2013, 08:53 PM   #23
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Those cross wrenches suck at removing wheels. You'll destroy your back, I would consider a breaker bar over anything else if you have no impact.
Rayme is offline   Reply With Quote
Old 02-24-2013, 09:02 PM   #24
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Originally Posted by DuMa View Post
lesson 1. never go to the dealer for maintenance you can do at home or at a friend's house
Agree! Reason #164,455,334,554,529,443 not to take it to the dealer for little stuff.
My cars always dress formally. They all wear black tires.
Black Tire is offline   Reply With Quote
Old 02-24-2013, 09:05 PM   #25
Chad
Chad's Avatar
Drives: FR-S Whiteout
Originally Posted by Ingen View Post
I love my dealership 99% of the time. They do a good job, are very friendly and have taken great care of me. However, they rotated my tires at my 7500 mile service and now.. I can not loosen the wheels. I don't have an impact, but I couldn't do it with a 4 way wrench.
Should I ask them to loosen and correctly torque? Do I need to be worried about stud damage?
I intend to autocross the car and I think I will lose my mind if I lose a wheel because I didn't nip this in the butt.
What do you guys think?
Edit: more concerned about possible damage, any opinions on that? I was thinking dealer because they could replace the studs while they're at it.
I've had this problem before. I think most dealers will just impact them on there because they don't really care or think that it will do damage. However I've had lugs break in half on me and almost damage my wheel.
I just dont trust anyone now with tightening my wheels, bought a hand torque wrench at Crappy Tire for like 50 bucks and haven't looked back.
It's such a simple thing (which is why they tend to overlook it) but can have potentially serious repercussions.
Chad is offline   Reply With Quote
Old 02-24-2013, 09:28 PM   #26
ahausheer
Re-member
[QUOTE=russv;754612]...that's voila [/QUOTE
Whoopsie Daisy.
Old 02-24-2013, 10:20 PM   #27
Porsche
Drives: 2013 BRZ Ltd. MT
Originally Posted by Chad View Post
I just dont trust anyone now with tightening my wheels ... It's such a simple thing (which is why they tend to overlook it) but can have potentially serious repercussions.
I agree, and I do the same. As Mark Donohue once said, those four, fist-sized patches of rubber are the only thing standing between me and Saint Peter.
Porsche is offline   Reply With Quote
Old 02-24-2013, 11:20 PM   #28
comic0guy
Drives: Evo X, 1996 Celica, DGM BRZ
I think a breaker bar will work better than a four way, it makes things much easier
comic0guy is offline   Reply With Quote
A warning about wheel studs post_break Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 41 05-05-2015 03:07 PM
broken wheel studs Matt Andrews Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-06-2012 12:47 AM
Small wheel studs PrinzJ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 10-10-2012 04:47 PM
Bolt Pattern, Wheel Hubs and Studs Jeff Lange Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 03-08-2012 02:49 AM
