Old 02-22-2013, 11:11 PM   #43
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Originally Posted by mad_sb View Post
that wasn't even divorced, that one rejoined about 12" from the stock flapper
Some people may not think this applies, but the 4B11T is a 2.0 low compression motor running 19psi stock.... Huge gains going from tuned stock exhaust to 3" turbo back on the same tune... i don't have access to the photobucket account i used to use when i was tuning so i cant get all the plots right now.
The 4b11t comes with 10.5:1 CR. Thats decently high for a factory turbo motor. Sti's for comparison come in around 8.5:1 I believe.
Tansey86 is offline   Reply With Quote
Old 02-23-2013, 12:05 AM   #44
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
3 bar map sensor is good for ~29psi boost at sea level.. a 4bar is good headroom but most wont need it.
Lol at stage 3 overnight parts
You're right, 3 bar should suffice. But 4 bar sounds cooler, especially once these overnight parts arrive.
Coheed is offline   Reply With Quote
Old 02-23-2013, 03:49 AM   #45
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by SnapOv3st3r View Post
Lets face it. If you are at the point that you are needing something bigger than 3" then you don't really care about daily driving out of boost and having less hp than stock at those rpms. You aren't even racing at that DD activity so does it even matter. Sidebar, the amount of whp that you might have lost isn't even noticeable. You aren't accelerating hard enough to even care.
Larger exhaust is better for spooling sorry. Backpressure and turbo does not belong in the same sentence. Backpressure and N/A does.
Nameless made more power throughout the entire rpm range, with a 3 inch exhaust vs. a 2.5 inch. Their largest gain was low - mid rpm, but they still made impressive gains everywhere. And that was on a naturally aspirated car with no mods other then the exhaust system.
The Following User Says Thank You to Calum For This Useful Post:
Sportsguy83 (02-23-2013)
Old 02-24-2013, 07:51 PM   #46
SnapOv3st3r
Drives: 400whp Scion tC
Nameless exhaust is 3"? Nice. And the components of this engine may not be as optimized as many suspect, to gain even in N/A form.
SnapOv3st3r is offline   Reply With Quote
Old 02-24-2013, 08:16 PM   #47
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
they are testing the 3". Will release soon.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Calum (02-24-2013)
Old 02-24-2013, 08:29 PM   #48
Calum
That Guy
I'll stop cluttering up this thread, I swear, right after this.
The one thing that amazed me is that not one person said a single word about back pressure after the results we put out.
Back on track...
What options exist for mounting gauges? I've seen AVO (?) mounted some in the passenger side dash panel. While that's not bad, I'd like them to be closer, or at least angled toward me more. I'd really like something that could mount in a single din slot below my stereo. Any ideas?
Old 02-24-2013, 08:35 PM   #49
Sportsguy83
Drives: Limited BRZ
Back on track...
Boom, best solution out there... http://www.ft86club.com/forums/showp...&postcount=100
Originally Posted by PrimeMotoring View Post
Heres my solution to relocating the buttons from the cluster
Old 02-24-2013, 08:42 PM   #50
Calum
That Guy
BOOM!
@Sportsguy83 delivers!
Thanks man.
Sportsguy83 (02-24-2013)
Old 02-24-2013, 08:48 PM   #51
Sportsguy83
Drives: Limited BRZ
BOOM!
Thanks man.
I ordered one, should be arriving soon. IMHO, it is the BEST cleanest solution.
Old 02-24-2013, 09:00 PM   #52
Calum
That Guy
Yeah, absolutely. I really want to keep things clean and that piece is perfect.
Old 02-25-2013, 12:09 AM   #53
nix
nix's Avatar
Drives: AVO BRZ
For the turbo or charged guys not running and oil cooler... What kind if oil temps are you seeing when you flog it?
130c
nix is offline   Reply With Quote
The Following User Says Thank You to nix For This Useful Post:
Sportsguy83 (02-25-2013)
Old 02-25-2013, 12:01 PM   #54
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Depends on your seating position. Make sure before you order that you can actually see those locations and aren't looking at steering wheel instead like I am when I drive.
Old 02-25-2013, 12:04 PM   #55
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Single A Pillar Gauge Pod from MSA:
The Following 2 Users Say Thank You to King Tut For This Useful Post:
Calum (02-25-2013), vubaru (02-26-2013)
Old 02-25-2013, 10:10 PM   #56
Visconti
Drives: 05 STi
Superchargers on pumpgas will be fine without most upgrades.
The closer you get to 300whp the faster you'll need a clutch - I suggest CLUTCH MASTER.
If you need fueling I have drop-in injectors (No cutting of any wires)
If you need a fuel pump I offer the highest output fuel pump on the market.
Anyone going with forced induction needs a upgraded map sesnor.. if you go forced induction and dont have a map sensor your setting yourself for failure.
-John
Visconti is offline   Reply With Quote
Safely Jacking and Supporting Your BRZ/FR-S GrimmSpeed DIY (Do-It-Yourself) Guides 152 06-11-2021 07:44 AM
What mods have you done so far? Rossi AFRICA 148 11-16-2015 01:41 AM
Oil Cooler kit for FI applications, getting one? JoeBoxer Forced Induction 84 01-20-2013 09:48 AM
Supporting Mods Double4Free Scion FR-S / Toyota 86 GT86 General Forum 5 02-21-2012 05:33 PM
Unacceptable: Toyota/Subaru among group of auto manufacturers supporting SOPA. Mitch Other Vehicles & General Automotive Discussions 43 01-09-2012 08:07 AM
