Old 02-23-2013, 10:52 PM   #421
Hix
Hix's Avatar
Drives: 2017 WRB PP
Does it have an e85 tune?
Hix is offline   Reply With Quote
Old 02-23-2013, 10:57 PM   #422
ScionFrsFan
It will...
ScionFrsFan
ScionFrsFan is offline   Reply With Quote
Old 02-23-2013, 11:20 PM   #423
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
Originally Posted by ScionFrsFan View Post
Jack, is this the first vehicle that unichip has tuned for e85?
No, google it.
pixel67 is offline   Reply With Quote
Old 02-26-2013, 07:44 PM   #424
Unichip Jack
Unichip Jack's Avatar
Drives: E36 M3, Whiteout FR-S
Busy weekend swapping parts and tuning… almost complete with the Vigilant CAI family… that should be posted by Friday.
Thanks for all the pm’s and calls about re-mapping and choosing the best map for your car. I’m hammering through the map selection guide, but if you have questions before it’s done, don’t hesitate to message me or give us a call.
Big picture… none of the maps will hurt anything and you can try any appropriate map (remember the intake is the key to which map family you’re working in).
If the car likes the map, it will run smoothly and pull strong everywhere.
If the car doesn’t like the map (too much timing and/or too little fuel for your specific car/octane combination) you’ll feel flat spots and may throw a flashing CEL. If it does, no harm/no foul… just (1) go back to what worked well previously or (2) choose a map with more fuel and/or less timing or (3) go to a higher octane fuel. As soon as you change the map back, the car will immediately revert to the original Unichip performance level.
Cheers
Unichip Jack is offline   Reply With Quote
Old 02-26-2013, 08:16 PM   #425
Hix
Hix's Avatar
Drives: 2017 WRB PP
Edit: found my answer... You should append the first post with the quote I linked below.
Old 02-27-2013, 01:02 AM   #426
subiestar
Drives: CBS Limited BRZ
Any plans for 91 octane maps? especially crap quality Arizona/Cali/Nevada 91 octane?
subiestar is offline   Reply With Quote
Old 02-27-2013, 08:57 AM   #427
Hix
Hix's Avatar
Drives: 2017 WRB PP
I think the 92 octane is for 91.. At least that is what he said a few pages back.
Originally Posted by Unichip Jack View Post
I’d consider 91 premium, but the beauty of the MapQ Library is you have the timing changes to support a wide range of fuel octanes… there are 9 different timing maps for each bolt-on configuration in each fuel map specification.
Consider, for example, the midgrade and premium grade maps in the Fuel Standard folder…
… working up from the middle, you have the Timing Standard 89 octane map which is designed (cleverly…) for nominal 89 octane fuel. You also have a Timing In 89 octane map which has a little more ignition timing so it needs a little more octane… say 90.
Jumping up to the Timing Standard 92 octane map which is (again, cleverly…) designed for nominal 92 octane fuel… so there’s a little gap between the Timing In 89 octane map and the Timing Standard 92 octane map… but you also have the Timing Out 92 octane map which is for slightly less octane than the Timing Standard map… say 91.
We’ve made maps that essentially step all the way from Timing Out 87 octane that’s workable with a poor low octane fuel all the way to Timing In 92 that’s good for 93 octane… and everything in between.
It’s important to realize there are variances between blends and not all 91’s are the same… with the download cable you can cover pretty much any fuel you come across.
Launch control… yes, the Unichip does launch control and we’re experimenting with different options on our test cars.
Cheers
Old 02-27-2013, 09:02 AM   #428
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
@Unichip Jack, Did you guys have any fitment issues with the front crank vent pipe on the VMS intake and the throttle body harness adapter? The front PCV pipe is angled down towards the block and I thought it may get in the way...
Also haven't seen the VMS intake available at checkout yet.
Old 02-27-2013, 12:37 PM   #429
bakerr6
Drives: 2013 raven black fr-s
Cheers
Thanks Jack,
also if you guys have questions about map switching (at least with the flux2), please let me know. I am back in town now, and since tax season is almost up, I have a little free time.
bakerr6 is offline   Reply With Quote
Old 02-27-2013, 06:09 PM   #430
xcelir8brz
Drives: 2013 BRZ Limited
I can help too.
xcelir8brz is offline   Reply With Quote
The Following User Says Thank You to xcelir8brz For This Useful Post:
HRTROB (03-16-2013)
Old 02-27-2013, 07:37 PM   #431
Ingeberger
Ingeberger's Avatar
Drives: 2013 Scion Fr-S
Damn, this system sounds too good to be true. Right now I just have a drop in filter (K&N), but I'm looking to add a Perrin CAI and a catback exhaust (TBD). My question is: will the tune for "drop in filter only" increase output or really change the overall performance much? I wouldn't expect too much, it's just a drop in... I'm just wondering because I'll make this purchase sooner before I get my other goodies if it really helps. Thanks!
Ingeberger is offline   Reply With Quote
Old 02-27-2013, 08:01 PM   #432
Unichip Jack
The Unichip will do very nicely with just a drop in… a large part of the power gain comes from additional ignition timing which has nothing to do with the intake or exhaust modifications.
If you also get the download cable, you have everything you need when/if you do get an intake… reprogramming takes about a minute.
Cheers
Old 02-28-2013, 12:38 AM   #433
topnotch
Drives: Scion FR-S
Installed my unichip this weekend that just past. Install was quick and easy. Unichip was very helpful with helping install the remapping program on my laptop.
Thanx to Erin for all the help. Thanx Jack for recommending me to try the 92 octance with standard fuel and timing plus. I enjoy the sublte change to the vehicle.
I have the greddy intake and sp exhaust setup with the map program mention above for my map 1. For Map 0, I have 92 octane with standard fuel, standard timming.
I ran map 0 for two days and was impressed by the pick up in the rpm ranging from 3k to 6.5k. Switched to map 1 for two days and was enjoying the car more. The car revs faster under load and the rpms seems to move a bit faster.
When i Punch the car at 3k on I can feel the car take in the air on the greddy intake with ease. Unlike before the unichip, youll punch the car and it will lag a little and you can hear the car suck in all the air, but the rpm is barely climbing up. Not now, It climbs well. You hear the intake, u feel the car move and see the rpm climb all at the same time. Makes the car a blast to drive. I've punched on the freeway going sixty five. I punched on third gear at 2.5k. From a stop light i punched it. entering a freeway i punched it. Good times. Not expecting a huge amount of power from this setup. Just looking at freeing up the intake and exhaust on the vehicle. This Unichip did it.
topnotch is offline   Reply With Quote
Old 02-28-2013, 03:13 AM   #434
Chillz
Drives: Asphalt FR-S & S14
Jack,
Is there a dummy map or a way to easily switch off the Unichip without physically removing it? I'd like to be able to easily compare OEM with the tuned maps.
Chillz is offline   Reply With Quote
Let's get tuning! EcuTek tuning now available! carbonBLUE Southwest 6 06-29-2015 02:37 PM
Unichip EMS Unichip Jack Engine, Exhaust, Bolt-Ons 300 11-22-2014 03:13 AM
unichip 13 FR-S Veteran Engine, Exhaust, Transmission 9 02-03-2013 11:05 PM
unichip 13 FR-S Veteran CANADA 0 12-03-2012 05:31 PM
