Old 01-28-2013, 04:44 PM   #71
TIE Pilot
TIE Pilot's Avatar
Drives: TIE interceptor; BRZ13
Originally Posted by fuddbutter View Post
Any chance of intergration with Android? so i can have my Nexus 7 plugged into it for on the fly tweeking?
Not sure if this works
https://play.google.com/store/apps/d....unichip&hl=en
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
TIE Pilot is offline   Reply With Quote
The Following User Says Thank You to TIE Pilot For This Useful Post:
microbionic (01-28-2013)
Old 01-28-2013, 06:53 PM   #72
ScionFrsFan
Jack, what is in the works with us auto guys...will there ever be launch control?
ScionFrsFan
ScionFrsFan is offline   Reply With Quote
The Following User Says Thank You to ScionFrsFan For This Useful Post:
pixel67 (01-28-2013)
Old 01-28-2013, 07:48 PM   #73
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
That is awesome and is exactly what I have been looking for. Looks like it requires a bluetooth adapter. Jack, what kind of adapter is needed?
Sent from my SPH-L710 using Tapatalk 2
pixel67 is offline   Reply With Quote
Old 01-29-2013, 07:42 AM   #74
TIE Pilot
TIE Pilot's Avatar
Does not say how to buy but i guess this is the module
http://www.unichip.com/Products_BTM.html
Old 01-29-2013, 01:23 PM   #75
Pandle
Drives: CBS BRZ
I'd like to know this too...
Pandle is offline   Reply With Quote
Old 01-29-2013, 01:56 PM   #76
bakerr6
Drives: 2013 raven black fr-s
Guys, I will do some pulls sometime soon. i'm scheduled to go into the local shop to have my car dyno'd on feb. 7th. I'll post my sheets on here. I'm hoping we have an e85 tune by then so I can try and get numbers on this also.
bakerr6 is offline   Reply With Quote
The Following 3 Users Say Thank You to bakerr6 For This Useful Post:
ScionFrsFan (01-29-2013), Sojhinn (01-29-2013), zohare (01-29-2013)
Old 01-29-2013, 04:59 PM   #77
zohare
zohare's Avatar
Drives: '13 Firestorm Base AT
Mechanically this should be Impossible... right? but I saw someone on YouTube w launch control on an AT. Maybe just for proof of concept? Then again- how does the car rev match so well. Idunno. I'm curious how this turns out no one has been really clear on how much control we have on the AT. I'm wondering if maybe it somehow completely opens the torque converter to downshift?
zohare is offline   Reply With Quote
Old 01-29-2013, 06:28 PM   #78
ScionFrsFan
Good question and wow would that be sweet!!! I messaged a few of you on what you guys like better timing in or standard and everyone likes timing in better only a few haven't tried it yet. I tried it today, but the roads were wet so I can't give an opinion of it yet...kinda felt first pulled harder??
....I want e85 and launch control maybe that makes my car =Race Car?
ScionFrsFan
zohare (01-31-2013)
Old 01-31-2013, 05:41 PM   #79
Unichip Jack
Unichip Jack's Avatar
Drives: E36 M3, Whiteout FR-S
For everybody with a MapsQ Download cable, the Perrin CAI map family is posted and ready for use. It includes the Fuel Standard/Timing Standard, Timing In, and Timing Out maps for low octane, midgrade, and premium octane fuel.
If you’re running this intake, or thinking about it, you’ll definitely want a calibration to go along with it to correct the fuel trim changes it creates.
We’re finalizing the Fuel In and Fuel Out calibrations and will get them posted soon.
Cheers
Unichip Jack is offline   Reply With Quote
Old 01-31-2013, 05:58 PM   #80
pixel67
pixel67's Avatar
I believe Fuel in/out and timing in/out is all this kit is capable of. Launch control is ecu reflash territory. Jack, feel free to correct me if I am wrong.
Old 01-31-2013, 06:38 PM   #81
AsphaltLover
AsphaltLover's Avatar
Drives: 2006 Scion TC, 2013 FR-S Asphalt
What does 91 octane fuel count as? Is that considered premium or midgrade? Us California guys have a hard time tracking down 93+ octane. There are some stations around but most people have to go out of their way to get it.
Cheers
AsphaltLover is offline   Reply With Quote
Old 01-31-2013, 08:17 PM   #82
Unichip Jack
I’d consider 91 premium, but the beauty of the MapQ Library is you have the timing changes to support a wide range of fuel octanes… there are 9 different timing maps for each bolt-on configuration in each fuel map specification.
Consider, for example, the midgrade and premium grade maps in the Fuel Standard folder…
… working up from the middle, you have the Timing Standard 89 octane map which is designed (cleverly…) for nominal 89 octane fuel. You also have a Timing In 89 octane map which has a little more ignition timing so it needs a little more octane… say 90.
Jumping up to the Timing Standard 92 octane map which is (again, cleverly…) designed for nominal 92 octane fuel… so there’s a little gap between the Timing In 89 octane map and the Timing Standard 92 octane map… but you also have the Timing Out 92 octane map which is for slightly less octane than the Timing Standard map… say 91.
We’ve made maps that essentially step all the way from Timing Out 87 octane that’s workable with a poor low octane fuel all the way to Timing In 92 that’s good for 93 octane… and everything in between.
It’s important to realize there are variances between blends and not all 91’s are the same… with the download cable you can cover pretty much any fuel you come across.
Launch control… yes, the Unichip does launch control and we’re experimenting with different options on our test cars.
Cheers
Old 01-31-2013, 09:57 PM   #83
pixel67
pixel67's Avatar
Cheers
Cool. Thanks for the clarification. Is the bluetooth module still available? I would like to use the android app.
Old 02-09-2013, 04:26 PM   #84
Unichip Jack
All of the Fuel and Timing maps for 92 and 89 Octane maps are posted. We'll get the 87 Octane maps next week.
Cheers
Unichip map downloads and tuning Unichip Jack Software Tuning 1133 06-30-2023 04:28 AM
Unichip EMS Unichip Jack Engine, Exhaust, Bolt-Ons 300 11-22-2014 03:13 AM
unichip 13 FR-S Veteran Engine, Exhaust, Transmission 9 02-03-2013 11:05 PM
unichip 13 FR-S Veteran CANADA 0 12-03-2012 05:31 PM
Software Gauges shirouxkamui Electronics | Audio | NAV | Infotainment 1 08-12-2012 10:30 AM
