Old 01-30-2013, 10:43 PM   #15
usptwins
Toyota Soul
usptwins's Avatar
Drives: 96 taco
Any RPM's?? Or at high RPM's?
No replacement for Displacement??? Tell that to the people with a 2JZ.
usptwins is offline   Reply With Quote
Old 01-30-2013, 10:52 PM   #16
uncivilised
Drives: 86 GT
Could it just be a characteristic of the gearbox? My altezza j160 does the same thing but its not bad for me.
I'm running redline mt90.
uncivilised is offline   Reply With Quote
Old 01-31-2013, 12:15 AM   #17
GoSharks
GoSharks's Avatar
Drives: BRZ Limited, WRB, 6 MT
Originally Posted by reeves View Post
I got the same problem.. 2nd gear randomly grinds. Other times is perfectly smooth.. Switched to Pentosin MTF-2 tranny fluid for 4K miles now, but I still get the random grinds. Pentosin did make shifts feel alot better/easier though, especially when it's cold. Before Pentosin, it was all but impossible for me to shift into 2nd when cold.
I am starting to notice after a long drive (30 minutes or more) the grinds rarely, if ever, occur anymore.. maybe it goes away after the tranny gets really hot?
Same experience for me. The transmission is my biggest problem with my BRZ, borders on unacceptable sometimes. I am very nervous shifting from 1st to 2nd in the morning as even with Pentosin it may grind. But better overall with Pentosin.
GoSharks is offline   Reply With Quote
Old 01-31-2013, 12:54 AM   #18
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
My 2nd gear almost grinds every time when it was -15.
shu5892001 is offline   Reply With Quote
Old 01-31-2013, 01:58 AM   #19
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
All rpms.
Hmm interesting.
Yup I know that feeling... this morning it was fine with my car; which im loving!!!
@nd box!?1?! they replaced it and it still happens :S
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 01-31-2013, 02:43 AM   #20
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Originally Posted by DriftEightSix View Post
It was the only way to change gears!! evens whilst rev matching it wasn't 100% smooth.
well damn. I have no clue now. My tranny is great tho i think I'm going to make the switch on fluids before next winter comes.
His 2nd gear not 2nd transmission.
Hope you find the source of your issue. Please report back!
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 01-31-2013, 05:59 PM   #21
usptwins
Toyota Soul
usptwins's Avatar
Drives: 96 taco
shit... idk man. bad synchro's??
Old 01-31-2013, 07:03 PM   #22
Metabrz
001 of 012
Metabrz's Avatar
Drives: MY12 NZDM Subaru BRZ "BRZ001"
I've installed a Cusco transmission collar mount and this has helped with 1st>2nd, 2nd>1st and 2nd>3rd shifting.
Shifting is faster, more precise and smoother. Shifting from 2nd to 1st at very low speeds is now a possibility whereas before I was not comfortable even trying it.
Downside is there is a little more transmission whine but its not annoying.
BRZ001: Peace Love and Wheelies @metabrz on IG
Metabrz is offline   Reply With Quote
Old 01-31-2013, 07:40 PM   #23
DriftEightSix
Pegasus White
Drives: 86
Nope cause it was fixed without having any parts replaced... still waiting to hear from the mech about what work he had done to the car... Its killing me not know what was done.
Old 02-23-2013, 03:50 PM   #24
its_the_biz
Drives: Whiteout 6MT
has your issues been fixed yet? if so, what has been done? im still getting the shitty shifting even 1000 miles later, today.
took the car in for the 1 month inspection and asked about it. they said it was normal and thats how the car was made. so im curious.
its_the_biz is offline   Reply With Quote
Old 02-23-2013, 04:15 PM   #25
Allch Chcar
Drives: N/A
It sounds like the wrong weight of gear oil for the temperature. If it's notchy when cold but fine after it warms up, the first number needs to be upgraded eg. XXw-XX. I seem to recall that the colder it is the heavier weight oil you need. Any gear oil experts on here?
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 02-23-2013, 05:07 PM   #26
XPR Small Block
Drives: Scion Frs
i think its the opposite with the oil same thing with motor oil colder it is the thinner it needs to be, hotter temps need thicker oils. think about it if the tranny is scratching the syncros when its cold is because the oil isnt able to expand enough to cover all the parts correctly when its warm the tranny is fully coated = fully functional trans
XPR Small Block is offline   Reply With Quote
The Following User Says Thank You to XPR Small Block For This Useful Post:
Allch Chcar (02-24-2013)
Old 02-23-2013, 05:29 PM   #27
DriftEightSix
Pegasus White
Drives: 86
Nope issue returned 500-1000kms laterbooking the car in again soon.
They told me it was normal but I can't see how I for 500km it was smooth has.
Old 02-24-2013, 12:00 PM   #28
GoSharks
GoSharks's Avatar
Same here. Switched to Pentosin, much better, but still grinds on occasion when cold.
Potential trade. Supermassive Cosmetic Modification (Interior/Exterior/Lighting) 2 12-21-2012 06:40 PM
FA20 N/A potential ? adprokid Engine, Exhaust, Transmission 4 11-18-2012 10:48 AM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 09:39 PM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 08:44 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 02:21 PM
