Old 02-23-2013, 03:53 PM   #1
diss7
Drives: AE86, 2x GT86, TE27
New tyres 205/40/17
I'm FINALLY taking delivery of my car on Monday. Even though it arrived on Thursday, apparently it takes more than two days to do a groom. Even more annoying was driving past the dealership last night and seeing the car just sitting in the showroom!
So I went and ordered my tyres, 205/40/17's. Why did I go with this size?
They have the lowest circumference of any feasible option. 195/45/16 would've been even smaller, but that would've been taking the point too far. Also, I wouldn't be able to fit the brakes I want under a 16" rim, and I'd already bought 17s anyway.
Why am I focused on a small circumference wheel? Well it has numerous benefits. For a start, less unsprung weight = better handling. Secondly, smaller circumference tyre = effectively shorter gearing = better acceleration & braking. Thirdly, lower COG.
Regarding COG, a lot of people confuse COG with wheel arch gap. If you put a bigger radius wheel and tyre on from stock you are RAISING the COG.
Putting my wheel/tyre on lowers my COG 18mm over a stock setup. Straight away, my COG with stock suspension is probably lower than another setup with massive rims and tyres and coilovers.
Running my setup with stock suspension will look a bit rude though, as the down side to all this is that I end up with more wheel arch gap. But, of course I can add coilovers with will lower my COG further and reduce this arch gap. Also, because my wheel/tyre is smaller, I'll be able to going lower before I have any form of rubbing/fouling; should I feel the need to go that low.
diss7 is offline   Reply With Quote
Old 02-23-2013, 04:06 PM   #2
diss7
Related to above, I realise I most this will seem like the tyre is going to be to skinny, but I disagree. I've owned 4 silvia, that all at one time or another were putting down 300rwhp (the level were I see myself taking the new 86) and at no time did I feel that a 205 tyre was too skinny. Sure, you couldn't give it the full beans in 1st, or around a corner in 2nd or 3rd, but that was the fun of the setup!
Old 04-05-2013, 04:28 AM   #3
AbsolutKev86
AbsolutKev86's Avatar
Drives: Toyota 86 & Ford Expedition EL
Interesting, im running 205/55/16 n thinking of goin 215 45/17 for more grip instead...
AbsolutKev86 is offline   Reply With Quote
Old 02-24-2014, 03:45 AM   #4
doggieboy09
Sènior Member
doggieboy09's Avatar
Drives: '22 BRZ |'13 BRZ SSC (formerly)
Any pictures or experiences with this setup?
doggieboy09 is offline   Reply With Quote
Old 02-24-2014, 04:48 AM   #5
diss7
Yup. It's good. Drifts easier
Old 02-24-2014, 11:22 AM   #6
FunCon5
FunCon5's Avatar
Falkin tires make the 452 in a 215 35 17. FYI
FunCon5 is offline   Reply With Quote
Old 02-24-2014, 01:47 PM   #7
wparsons
wparsons's Avatar
FWIW, my 205/50/17 snows are wider than the stock 215/45/17 primacy tires.
As for the COG, does the lower COG from smaller tires actually help? It would interesting to see how smaller diameter tires affect the RC and COG, and more importantly how the COG moves compared to the RC.
flickr
Old 02-24-2014, 01:54 PM   #8
donutfilling
donutfilling's Avatar
Drives: frs
If it is enough grip really depends on what type of driving you are doing. Not ideal for autoX or track events, but I am sure they are fun to go drifting in.
If you are getting that in detail with its benefits, another benefit is a thinner sidewall so there would be less flex if you are comparing direct compounds.
donutfilling is offline   Reply With Quote
Old 02-24-2014, 04:20 PM   #9
wparsons
wparsons's Avatar
^^ Width isn't everything on a track, CSG found 225's are faster than 245's because they hold heat better. A stockish power level (not FI) FRS/BRZ just won't heat up 245's enough for optimal grip.
AutoX is a different beast since you can't warm up your tires, so how much heat they're holding lap after lap doesn't really come into play.
flickr
Old 09-21-2014, 09:08 PM   #10
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
So just wondering, does anyone have any pics of a setup with 205/40-17s? OP apparently was banned before being able to post up (not sure why though, checked out the post history and didn't see anything too weird). The only pics I could find of that size tire are here
http://www.ft86club.com/forums/showp...53&postcount=2
but that's on a heavily lowered vehicle.
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 09-24-2014, 08:25 AM   #11
troek
troek's Avatar
Drives: 2012 Toyota 86
what brand of tire did the op get i wonder?
troek is offline   Reply With Quote
Old 09-24-2014, 09:08 AM   #12
phobos512
phobos512's Avatar
@Manji thanks for the pics. Looks like you could benefit from some wheel hub spacers?
@troek - no idea, been looking at the General G-Max AS-03 myself, they're 4 lbs. lighter than stock and have very positive reviews in the kind of weather we experience here in Southern Maryland.
Old 09-24-2014, 10:32 AM   #13
troek
troek's Avatar
my friend ran the snot out of those tires on his r32 gt-r and loved them. not terribly high grip but they were extremely predictable and had progressive breaking traction. lots of tire talk. made for some fun times up in the mountains.
Tyres yomchi1989 AUSTRALIA 18 10-09-2012 09:02 PM
Toyo Tyres yomchi1989 AUSTRALIA 20 09-29-2012 01:44 AM
Tyres Z86 AUSTRALIA 51 09-16-2012 07:51 AM
WTB GTS Wheels with Tyres Loki556 Australia Classifieds 0 08-31-2012 10:31 PM
This is why the AS1 is on prius tyres!! Slide Scion FR-S / Toyota 86 GT86 General Forum 71 01-17-2012 09:26 PM
