Northwest AK, ID, OR, WA
Old 02-22-2013, 07:04 PM   #15
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
Oh. That makes more sense to me now. I was confusing when I saw some intake has 2 and some has 3.
Thank you for your advice. And I wait for your to post the links as well.
Old 02-22-2013, 07:44 PM   #16
stockysnail
Just the tip
stockysnail's Avatar
http://www.perrinperformance.com/brzfr-s/intakes
The first item is if you keep your stock air box. The second item is the replacement for the hose between your air box and the engine. It also removes the noise generator hose as Perrin's doesn't have it. The third item would replace your stock air box and would require the front bumper to be removed. I have the 2nd and 3rd items. Some people that can't afford that much $ are doing either just the first or the first and second items. The best sound and performace when giving it full throttle will be with the second and third items.
And if you go to their store they will sell the 2nd and 3rd items for $400 instead of $463 that their website says.
Old 02-22-2013, 08:00 PM   #17
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
Hi, Stocksnail. I want to know if the second item (inlet hose), does it has 2 output or 3 output. the picture only shows one side of it, I couldn't see the back of it.
If it doesn't has the 3rd output, what should I do with the exist hose that connect to my stock intake?
The Following User Says Thank You to Lverasky For This Useful Post:
PNW FRS (02-23-2013)
Old 02-22-2013, 09:36 PM   #18
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
its only a 2 output. the 3rd output would be a snorkel, and there would be a plug for it.
https://www.teamczp.com/system/produ...jpg?1349294796
that little black thing on the bottom right corner just caps the other end.
Chen is offline   Reply With Quote
Old 02-22-2013, 10:24 PM   #19
Clint520
Clint520's Avatar
Drives: GBS BRZ AT
Anyone know the price on labor to get this installed? I wouldn't want to mess with the bumper lol. Thanks in advance!
Clint520 is offline   Reply With Quote
Old 02-22-2013, 10:25 PM   #20
Chen
Regional Moderator
Chen's Avatar
depends on which one you go with. A lot of them you don't have to take off the bumper. Also a lo of them just reuse the oem location.
Old 02-22-2013, 10:31 PM   #21
Clint520
Clint520's Avatar
Drives: GBS BRZ AT
Ohh ok. So which one saves me from removing the bumper?
Old 02-22-2013, 10:51 PM   #22
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
I want to know the answer too.
Old 02-22-2013, 11:27 PM   #23
Chen
Regional Moderator
Chen's Avatar
a lot of them do. Basically anything that looks like this. (greddy, injen ,takeda, air raid) just to name a few.
http://image.importtuner.com/f/featu...r-s-intake.jpg
Heres a tutorial as well.
[ame="http://www.youtube.com/watch?v=ZP9yHvZyaGU"]Scion FR-S Injen Cold Air Intake Install - YouTube[/ame]
The Following User Says Thank You to Chen For This Useful Post:
Clint520 (02-23-2013)
Old 02-23-2013, 03:34 AM   #24
stockysnail
Just the tip
The ones that don't go into the front bumper aren't really cold air intakes (for the most part), they are warm air intakes as they will suck some warm air in from the engine compartment. Not really a big deal unless you're racing your car on the track.
The Following User Says Thank You to stockysnail For This Useful Post:
Old 02-23-2013, 12:05 PM   #25
31katys
31katys's Avatar
Drives: whiteout mt fr-s
I have the injen. I'm completely happy with it. 13hp upgrade, who wouldn't be? And a monkeys uncle can install it.
31katys is offline   Reply With Quote
Old 02-23-2013, 06:33 PM   #26
Chen
Regional Moderator
Chen's Avatar
Tuned or untuned?
Old 02-24-2013, 12:36 PM   #27
Skywgn1
Skywgn1's Avatar
Drives: 2013 Scion FR-S (manual)
Originally Posted by Chen View Post
Tuned or untuned?
Mine is untuned and I did notice a difference the first time I took it out. Still do. When I was in the higher RPM's with the stock intake/generator I felt the motor was struggling. Especially considering the noise it was making. Now....well now it's just fun to get it up there. The power and the "True sound" go hand in hand.
You should also buy the Perrin crank pulley too. Revs are quicker.
Customize the piss out of it and call it yours!
Skywgn1 is offline   Reply With Quote
Old 02-24-2013, 04:52 PM   #28
31katys
31katys's Avatar
Tuned or untuned?
Untuned. Though I am thinking of tuning it now that I talked with a couple of other people who have.
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 12:43 AM
INTAKE QUESTIONS ategs1992 Engine, Exhaust, Transmission 11 10-28-2012 05:25 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 01:31 PM
