Old 02-21-2013, 11:17 AM   #57
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
I just bought a universal lighting harness from princes auto with a fuse, relay and on off switch built in. that cost me 10 dollars. I know a switch in the car is not the prettiest when it is not designed in an OEM fashion but really, 10 dollars is a lot cheaper than a 100 dollar stalk and a wiring headache.
The Following User Says Thank You to SkAsphalt For This Useful Post:
Sco2355 (02-21-2013)
Old 02-21-2013, 11:25 AM   #58
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Originally Posted by SkAsphalt View Post
I just bought a universal lighting harness from princes auto with a fuse, relay and on off switch built in. that cost me 10 dollars. I know a switch in the car is not the prettiest when it is not designed in an OEM fashion but really, 10 dollars is a lot cheaper than a 100 dollar stock and a wiring headache.
Tru, also depends on ur OCD level lol
lbroskee is offline   Reply With Quote
The Following 2 Users Say Thank You to lbroskee For This Useful Post:
Sco2355 (02-21-2013), SkAsphalt (02-21-2013)
Old 02-21-2013, 11:29 AM   #59
Sco2355
It isn't a big deal, it just wasn't what I wanted. Good job though on saving the money.
Btw stalk is only $60, not $100. Since I took the headache out of figuring out which wire to use wiring will take what, like 10-15 minutes?
Appreciate the info though, it's good info for someone who wants an alternative to what I did.
Sco2355 is offline   Reply With Quote
Old 02-21-2013, 11:44 AM   #60
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
60 is better. I saw a few posts talking about 105-100 dollars for the part, which is cost prohibitive. I wouldn't be surprised if I end up going this route because I would like to have the light on the dash work.... I am OCD that way. Now that I know it exists. I want it
however it would render my harness useless in its current form. would need to be rewired.
Old 02-21-2013, 01:44 PM   #61
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
The price differences are for 2 different stalks. The $60 is for the BRZ stalk, which has an auto headlights spot. The $100 is for the Tundra/Corolla stalk, which does not have an auto headlights spot. Since the FR-S does not have auto headlights a lot of guys prefer a stalk without the auto headlight spot.
kmbkk is offline   Reply With Quote
Old 02-23-2013, 04:48 PM   #62
NemeGuero
bumpin for news. Get the prius stalk yet?
NemeGuero is offline   Reply With Quote
Old 02-23-2013, 11:46 PM   #63
ymboc
ymboc's Avatar
All this talk about the auto-headlight spot makes me wonder what it would take to get that working too... might not be too much more -- just a sensor and some wiring probably.
ymboc is offline   Reply With Quote
The Following User Says Thank You to ymboc For This Useful Post:
IgnitionGundam (11-09-2013)
Old 02-24-2013, 01:40 AM   #64
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Apparently you have to replace the main body ECU and add sensors. See this thread, post #356:
http://www.ft86club.com/forums/showt...=27366&page=17
Old 02-24-2013, 06:54 AM   #65
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Anyone know where to source the GT86/BRZ stalk with auto and front and rear fog light switch? I have front fogs on mine and I would like to retrofit the rear fog. Looks like my car is already prewired for the rear fog since I have a fuse for the rear fog, contacts on the empty slot for the rear fog relay and a third wire (yellow) on the reverse light connector in the trunk
HRTROB is offline   Reply With Quote
Old 02-26-2013, 12:24 AM   #66
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
If I have a full harness with a relay and a switch, could I tap the switches ground wire and run that that to the "white wire" so when I turn on the switch (and complete the circuit) it will activate the dashboard fog light indicator through the white wire into the BCU?
Hope that question made sense.
Old 02-26-2013, 01:47 AM   #67
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
I think so.
FRSFirestorm is offline   Reply With Quote
The Following User Says Thank You to FRSFirestorm For This Useful Post:
SkAsphalt (02-27-2013)
Old 02-26-2013, 03:37 PM   #68
NemeGuero
Originally Posted by zooki View Post
Well, I just ordered the Tundra/Corolla switch, so I'm now waiting for it to come in. I have a prewired harness with a relay coming, so I think what I'm going to do is tap into the side marker light for +12V power to the trigger side of the relay, and tie the ground side of the trigger into this pin 30 wire. That "should" let the switch turn on the fog lamps only when the parking or headlights are on. I think....
Update? Fit and plug n play? (minus wiring out from fuse box)
Old 02-26-2013, 04:13 PM   #69
zooki
Drives: waiting on a 2021...
I just received the switch yesterday. It will be next week before I have time to work on it.
zooki is offline   Reply With Quote
Old 02-28-2013, 12:34 AM   #70
SixSpeed
Drives: '14 Toyota Corolla S
Originally Posted by MemphisR View Post
Rear fog light?
It is a rear fog indicator, according to step 9 of this DIY:
http://www.ft86club.com/forums/showthread.php?t=29954
SixSpeed is offline   Reply With Quote
Who here has LEDs in their fogs/DRLs in their GT? RZ86 Cosmetic Modification (Interior/Exterior/Lighting) 10 03-30-2013 10:54 PM
Fogs wiring; Will this work? Khánh Cosmetic Modification (Interior/Exterior/Lighting) 12 02-16-2013 12:44 PM
BRZ HID Bulb + HID Fogs delusional DIY (Do-It-Yourself) Guides 4 02-05-2013 05:09 AM
new Camry fogs fit the frs?? hislargeness Cosmetic Modification (Interior/Exterior/Lighting) 3 09-26-2012 03:20 AM
for everyone thinking of using rear fogs xpicer Cosmetic Modification (Interior/Exterior/Lighting) 4 07-04-2012 12:53 AM
