View Poll Results: BBK or just pads/fluid/rotors
Are you crazy? U Need a BBK!!! 10 10.53%
Naw Dawg just upgrade your pads/fluid/rotors 61 64.21%
Planning on pads first then BBK later 24 25.26%
Voters: 95. You may not vote on this poll
Old 02-19-2013, 01:15 PM   #29
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Kido1986 View Post
Good fluid, AX6s and 117mph into turn 17 all day in 100F ambient went well for me
117? Hmm I need to check my speedo or you need to enter 16 a lot faster
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
CSG Mike (02-19-2013)
Old 02-19-2013, 01:24 PM   #30
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
It was my first time on full course, still a newbie (only 4 overall real track days under me). I was entering 16 about 62 if I recall the GPS logs.
<racedriverexcuses>
I'm fat and weight the car down
I'm using 7" wheels with 215s
excuse #3
excuse #4
</racedriverexcuses>
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 02-19-2013, 01:36 PM   #31
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
What offsets or wheel design fit the AP kit?
iLuveKetchup is offline   Reply With Quote
Old 02-19-2013, 02:36 PM   #32
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
<racedriverexcuses>
excuse #3
excuse #4
Ha I'm fat too. No excuse
I am using wider tires but that can hurt on a low HP car too.
I'll datalog this weekend since last time I made the brilliant decision to update firmware on the Solo forgetting that I never downloaded the data.. yeah.. my BRZ data and data from the Boss 302 were both lost
I need to bleed brakes, switch pads, etc tonight
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-19-2013, 02:39 PM   #33
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
17x8 RPF1s in the common offset (45 IIRC), 17x9s RPF1s are now reported to fit in +35.
Some other info here: http://www.ft86club.com/forums/showthread.php?t=19756
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-19-2013, 03:25 PM   #34
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
Our systems fit a wide range of 17's, but you need a spacer with the OEM wheels.
You can check wheel fitment on our site for either:
Sprint wheel fitment template
Endurance wheel fitment template
There's also a dedicated wheel fitment thread here.
Wheels that customers have told me fit without any spacer:
Sprint
Enkie RPF1 17x8 45
Wedsport TC105n 17x9 35
Mach V Motorsports "Awesome" wheel 17x9 42
Work Ultimates 18x8.5 47
Sparco (designed by OZ) Assetto Gara 17x7.5 48
Endurance
Enkie RPF1 17x8 45
BBS CH-R 18x8 38
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division
www.essexparts.com
JRitt is offline   Reply With Quote
Old 02-19-2013, 03:34 PM   #35
CSG Mike
CSG Mike's Avatar
Originally Posted by aCab View Post
I think the car's brakes are more than adequate.
Depends on what you consider adequate. Will it get the job done? Yes. Is it cost effective? No.
The S2k's brakes get the job done, but it's expensive to sustain.
Originally Posted by GTB/ZR-1 View Post
Not for the fast drivers on braking-intensive courses.
aCab is one of the fastest guys in the country... on a whole different level from me.
Originally Posted by JRitt
My estimate is that the average guy who tracks his car regularly will save enough money in two seasons to completely pay our system off. That doesn't even include all the intangible costs of time and potential problems. That's just straight savings on pads, discs, fluid, and resale value. The lengthy list of system benefits is just gravy.
Absolute truth.
Old 02-19-2013, 03:48 PM   #36
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Without a doubt Austin is a very very good driver
He's also probably more efficient with his brake usage compared to me
Sadly I lost all confidence in the stock gear and I doubt I'll ever get it back.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-19-2013, 05:27 PM   #37
iLuveKetchup
Drives: EFF JAY
Thanks for the info Dave-ROR & JRitt.
Old 02-19-2013, 08:32 PM   #38
aCab
aCab's Avatar
Drives: FR-S & S2k
Absolute truth.
Now I know you guys are just full of crap. I'm not fast, I'm just stupid enough not to know to drive slower. Two tire walls this year is testament to that. But the more beat up the s2000 body got, the faster the lap times were!
Agreed that the stock braking system is not economical by any means, but I do have my reasons:
I think the stock calipers will work is due to me needing to believe that they WILL, so I don't spend those precious NASA TT points on them. If brake wear is anywhere between the S2k (wear through pads fast), and miata (wear through pads slowwwwww), I'll be ok.
I see that most everyone is running brake kits dave,mike, robi, etc. I'm interested to know what the limits of the stock system are. Yes, I sell parts for a living, so I'm inclined to say they are needed but if you're only using them to slow or settle the chassis, that are their limitations with good fluid, stainless lines, and good pads? I'm sure ill find out this season.
aCab is offline   Reply With Quote
Old 02-19-2013, 09:07 PM   #39
CSG Mike
CSG Mike's Avatar
The other benefit is unsprung weight reduction... this car needs every bit of power it can put to the ground...
Robi was using an ULTRA light rotor. I don't know the exact weight, but I'd guesstimate around 6 lbs per ring. He cracked one in 2 places this weekend ala s2k. :o They were replaced by some beefier ones...
Old 02-19-2013, 09:18 PM   #40
Evasive Motorsports
Evasive Motorsports's Avatar
Drives: 2012 FR-S and BR-Z
Send a message via AIM to Evasive Motorsports
Stock car you just need pads and fluid. Unless you make like 500+hp. BBK kit will slow you down in the turns with too much bite.
Evasive Motorsports is offline   Reply With Quote
Old 02-20-2013, 12:07 AM   #41
sw20kosh
Drives: 2013 Black FR-S
my apologies when I created this poll I should have said "totally new brake system" instead of BBK. I didn't know the ESSEX sprint kit is more of a performance brake kit rather than a huge BBK.
I love the Sprint kit for its weight savings and for its ability to slow down wear on components.
Old 02-20-2013, 01:56 AM   #42
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
See!! There's proof. I've only hit one tire wall this year!
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Tracks Near Long Island NY whitefrs NY / NJ / CT / PA 18 11-11-2012 10:50 AM
Are you James Bond;) Go to tracks/shows :P LCD switching license plates ;) WTF Other Vehicles & General Automotive Discussions 10 10-04-2012 04:41 PM
South FL Tracks and AutoX raul Southeast 3 09-09-2012 07:56 AM
1/4 tracks brichard0625 NY / NJ / CT / PA 16 08-30-2012 12:01 PM
Favorite tracks around Kansas City area? ktBonefish Rocky Mountains / Great Plains 2 06-10-2012 09:29 PM
