#1275 | ||||
Drives: Turbocharged
| The Following User Says Thank You to johnbradley For This Useful Post: | Dimman (02-18-2013) |
#1276 | |
Drives: 2024 GR86/ 2015 FRS
I made 191 whp on 93 octane in 5th gear. Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts |
#1277 |
On a dynojet it only wants the pull between 8-12 seconds, if it wasnt a DJ then yes it may have as some dynos (i.e. Dyno Dynamics, Mustang) do need to target a 1:1 ratio.
Nameless Performance official tuner..dont ban me I'm not selling anything
#1278 |
Blue is 4th gear, red is 5th. This is Pretune on the 3" exhaust and new header. 5th picks up minute amounts of torque but the length of pull leads to a detonation/timing pull condition near the end. Peak power is still the same but power past peak definitely isnt-
| The Following 2 Users Say Thank You to johnbradley For This Useful Post: | Dimman (02-18-2013), tripjammer (02-19-2013) |
#1279 | |
Kuruma Otaku
Because titanium. |
#1280 |
eagerly awaiting more information. Would be nice to see a street review of power and sound. I think(hope) the dyno session was distorted due to being in a closed shop.
Thanks, |
#1281 |
Well, we can at least see the header itself is producing amazing power, but that dip is all ECU. P&L is running their tests on E85 so the dip isn't as apparent.
I'm not going to let it bother me too much. If the dip is there for MPG reasons, I'm all for it since my FR-S is my DD and when I want to floor it, I get the power I want. I'm sure many track drivers aren't going to be a fan of it at all. I guess we'll see what happens with more time and going through more maps with Ecutek. I'm learning a ton myself with all of this. |
#1282 | |
Kuruma Otaku
Because titanium. |
| The Following User Says Thank You to Dimman For This Useful Post: | mad_sb (02-19-2013) |
#1283 | |
Drives: 2013 Asphalt FR-S
This header design and tune combination has already turned a big chunk of what was the dip into a mound of torques... I stoked to see the finished product and how it performs.
~Namaste~ |
#1284 | |
Frosty Carrot
Drives: The Atomic Carrot
What you end up with is a pile of parameters. Some are estimated and some are sensed. The sensed parameters are more reliable and useful... but sensors cost money are eventually require maintenance. Cuts get made on a Scrooge McDuck scale. Estimated parameters are built from functions and tables based on piles and piles of test data which (presumably) replicates all possible conditions the engine will ever see. Obviously, you can't predict all engine conditions... but you can try (hence the convertible spy shots in South Africa). Estimation of parameters can be too simple and insufficient, or it can "over fit" the data and lose connection with the reality (aka process physics). The challenge comes in creating an estimate that's accurate enough of the time, and having a framework with checks-and-balances (with diagnostic routines and adaptive variables). Finally, they look at computational power, sample rates, and CAN bus bandwidth as a cost (albeit smaller). Things get slowed down, filtered, and a "good enough" estimation algorithm is chosen. Take it to the racing world. Computing power is "free." Sensors are "free." Road conditions are "simpler" (off-throttle and WOT acceleration only). Weight, power output, fuel economy, response time, and smoothness are now the top priorities. That's how racing teams can crank out 50% more horsepower on stock hardware. That, plus shorter maintenance schedules and fuel economy and emissions and a pile of other burdens lifted. One common example, most turbo engines are outfitted with MAP and MAF (with included IAT) sensors in multiple places along the intake path. Typically engine load is a function of MAF, which is a function of MAP and IAT (among other things). The equations for this are well established, but tuning the coefficients and table values to be accurate requires some number crunching. End result is quite effective. You don't see many production vehicles that run both MAF and MAP (though it would help in some situations). For EGT, you bet your booty they installed a thermocouple. They just built a function that estimates it, and developed an event trigger that changes your timings and mixture to cool down the catalyst. There are variables the indicate operational mode, and you'll see it oscillate when the headers start to glow. Those were the good ole days of freebie catalysts. YES it's considered, YES you can still manage to break stuff, YES you should expect your tuner to have considered this and a billion other things before you trust them to "re-engineer" your car.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX Wall of Shame - aFe Takeda, Wilwood, FA20Club |
#1285 |
Drives: Scion Frs
this is a bit off topic but i have to put my thought in about the header.. what if you were to join the primary tube a few inches earlier and joining the secondaries where the primaries join now, but doin this it should change the torque curve in a good way right??? i kinda made a very very rough drawing over this picture
[/IMG]
#1286 |
Drives: 2013 Scion FR-S (manual)
I would like to know how the ECU handled the header without the tune. Are there graphs and actual figures?
Customize the piss out of it and call it yours!
#1287 | |
Kuruma Otaku
Because titanium. |
#1288 |
Drives: Scion Frs
i just know with v8s a "Shorty" header creates more lowend torque vs. a long tube header which makes more topend i would assume the same thing would apply here
| Tags |
| 21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag |
| Nameless Performance BRZ Axleback Exhaust | ESBjiujitsu | Engine, Exhaust, Transmission | 1377 | 04-21-2020 02:23 AM |
| Nameless Performance Axleback is available for pre-order. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 114 | 07-23-2012 10:38 PM |
| Nameless Performance Downpipe is available for pre-order. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 4 | 07-12-2012 04:57 PM |
| We are Nameless Performance. | John@Nameless | Announcements, Contests, Giveaways | 22 | 06-18-2012 11:32 PM |
| Nameless Performance is here. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 16 | 06-06-2012 04:32 AM |
