Old 02-14-2013, 05:48 AM   #883
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Originally Posted by whitefrs View Post
Hey guys
I'm looking to get CCW but looking for semi aggressive
Planing on doing
18x9.5 3inch lip Front
18x10. 3inch lip rear
Questions!!!
What offset should I go with in the front and rear?
What size tire should I go with (don't wanna rub)?
Btw I'm lowered on BC coils
Thanks
Any help please????????
Old 02-14-2013, 11:49 AM   #884
MKIV
MKIV's Avatar
Drives: 4 tires mounted to 4 wheels
Why don't you talk to John at CCW?
I've only been wrong once, and that's when I thought I was wrong.
MKIV is offline   Reply With Quote
Old 02-14-2013, 02:43 PM   #885
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
I would like opinions from peoplr that have this car
Old 02-14-2013, 04:34 PM   #886
MKIV
MKIV's Avatar
Over the man who would actually build your wheels??
Old 02-14-2013, 05:07 PM   #887
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
It's really your call, bro. If it was me and i was running the widths you gave id go +15 to +30 max..
If you're having someone build your wheels why not ask him to show you what each option looks
ill86 is offline   Reply With Quote
Old 02-14-2013, 05:08 PM   #888
ill86
ill86's Avatar
Drives: iG FR-S
A lot of this is personal preference. based off of your exact suspension setup, usage amd driving style.
Old 02-17-2013, 04:14 AM   #889
Unsustainable
Unsustainable's Avatar
Hey guys! Would Enkei Raijins 18x8 +45 fit with 245/35/18 ventus v12s? Stock suspension here. Or would the +35 be better? Thanks for the help.
Unsustainable is offline   Reply With Quote
Old 02-17-2013, 04:48 AM   #890
VENOM~
VENOM~'s Avatar
Drives: 2013 sti
Anyone know if 9.5 +20 & 10.5 +30 front/rear will work without to much fuss? Pull and roll I'm thinking.
VENOM~ is offline   Reply With Quote
Old 02-17-2013, 02:54 PM   #891
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
both are fine, just preference.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 02-20-2013, 04:51 PM   #892
VoiD
Drives: 13 WRB BRZ
will 18x8.5 with Et25 fit all around? I'm sure the rears would work, but not sure on the front.
VoiD is offline   Reply With Quote
Old 02-23-2013, 10:00 PM   #893
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Best size tires for 17x9 et 35
Im going turbo so i need good tires
Im not looking for strech nor wide
I want to stay in the middle
Old 02-23-2013, 11:04 PM   #894
ill86
ill86's Avatar
Drives: iG FR-S
255/40
Old 02-25-2013, 09:32 AM   #895
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
ok, sanity check.. I've seen other posts with the same size and I think this will fit but I just want to make sure before I hit 'buy'.
I have stock tires and I'd like to put them on Enkei GP5s. I'm also going to order some TPMS sensors with it too.
17x8 +45 on stock tires?
(From Tirerack)
Offset: +45mm
Backspacing: 6.25"
Bolt Pattern: 5-100
Rec. Tire Size: 235/40-17
Weight: 24.4lbs.
Finish: Special Brilliant Coating
Construction: 1 Pc. Gravity Cast
Finish Warranty: 1 Year
Manufactured in China
PS I know these tires are heavier than stock, but they look great.
Books is offline   Reply With Quote
Old 02-25-2013, 03:21 PM   #896
ill86
ill86's Avatar
Drives: iG FR-S
(From Tirerack)
Sure. Spend away.
The Following User Says Thank You to ill86 For This Useful Post:
Books (02-25-2013)
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
