Old 02-13-2013, 03:23 AM   #43
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Originally Posted by ayau View Post
Thanks! Any difference between running the Scangauge/oem sensors vs aftermarket gauge with aftermarket sensors?
scangauge reads whatever signals the ecu can see.
an aftermarker oil temp sensor (unless it runs off the OBDii port) will have its own sensor to read temp which i would wager is not as accurate as the factory sensor. (obviously depends on placement)
86•BRZ is offline   Reply With Quote
Old 02-13-2013, 10:14 PM   #44
pkny
Drives: Firestorm FR-S 6MT
Added the relative and absolute throttle position codes to the first post.
2013 Scion Firestorm FR-S MT
pkny is offline   Reply With Quote
Old 02-16-2013, 04:55 PM   #45
pkny
Added Fuel Pressure in the 1st post.
The Following User Says Thank You to pkny For This Useful Post:
86•BRZ (02-16-2013)
Old 02-16-2013, 05:22 PM   #46
brillo
Drives: 2013 Firestorm FR-S
I can't seem to get oil temp in F only in C. Am I missing something?
brillo is offline   Reply With Quote
Old 02-16-2013, 05:33 PM   #47
pkny
What did you get? Empty respond or some weired number?
Old 02-16-2013, 05:42 PM   #48
brillo
It was a - 35 and my coolant was at 191
Old 02-16-2013, 06:25 PM   #49
pkny
Update: It's working on mine.
Just make sure you enter the right code, and also your fw ver is at least 4.05.
Old 02-16-2013, 09:36 PM   #50
brillo
Is the is FRS CANSF? I got my scan gauge updated last week so I'm on 4.05
Old 02-16-2013, 10:02 PM   #51
pkny
Yes, FR-S is CANSF. If you're getting oil temp in C correctly, that means the TXD, RXF, and RXD are correct. Just make sure the MTH is 0009 0005 FFD8 (for F).
Old 02-17-2013, 05:02 AM   #52
brillo
Can the xguage read the wide band sensor? On of the posted pics hints that it can
Old 02-17-2013, 03:32 PM   #53
brillo
Got the oil temp working, now just working on air fuel ratio
Old 02-17-2013, 03:47 PM   #54
Lonewolf
Lonewolf's Avatar
Drives: Moped
NM
Old 02-17-2013, 06:16 PM   #55
pkny
Brillo, it's good to hear you got it working. I also got an email from Scangauge. They confirmed that my oil temp code is fully working, and they posted the code on their website.
I will add a full list of supported standard (mode 01) PID soon. Stay tuned.
Update: Added the Supported PID list to the 1st post.
Old 02-20-2013, 04:02 AM   #56
Nardi330
Nardi330's Avatar
Drives: 86
Tried a few codes on my upgraded scangauge and its working great.
Thanks for your effort!!
Nardi330 is offline   Reply With Quote
FT-86 low temp THERMOSTAT ft86-UAE Engine, Exhaust, Transmission 52 08-30-2016 03:46 PM
A/C Oil/Water temp gauge Exhaust Scion FR-S / Toyota 86 GT86 General Forum 16 02-07-2013 01:19 PM
Engine oil temp now available in Torque App Yruyur Engine, Exhaust, Transmission 8 02-03-2013 10:52 PM
exterior temp. gauge off? Rayme CANADA 8 01-23-2013 09:06 PM
Simple Oil Temp. Gauge Sportsguy83 Cosmetic Modification (Interior/Exterior/Lighting) 4 01-19-2013 08:25 PM
