Old 02-15-2013, 02:53 PM   #15
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by wparsons View Post
Will diff bushings actually do anything for wheel hop? I would think only parts that actually effect the suspension (subframe and control arm) bushings would have an effect?
Originally Posted by Noob4Life View Post
I replaced just the dogbone mount in my jetta with a stage 1 poly mount and there was so much less wheel hop that I actually thought id lost some power. The difference was might and day.
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
Noob4Life answered your question.
My experience has been similar, improving the motor mounts on a front wheel drive had a HUGE effect on wheel hop.
Old 02-15-2013, 03:28 PM   #16
OrbitalEllipses
Drives: Attitude
I get this with damp roads, summer tires or winter tires doesn't matter. Watching the shifter rattle violently...is disconcerting.
Old 02-15-2013, 03:36 PM   #17
CSG Mike
CSG Mike's Avatar
It depends on the wheel hop, but yes, bushings will help.
We get some wheel hop in our car under high speed at-the-limit cornering, but not enough where it's become a priority item.
Tein offers a bushing set that solves the problem.
Old 02-15-2013, 04:37 PM   #18
Pete156
I like to eat!
Obviously these cars were designed with rear slippage in mind, never intended for the rear to actually 'hook up'. I don't think it's possible to experience true wheel hop with the Primacy summer tires, unless you air down. Once OEM tires are replaced these traction issues surface. Bushings do help a great deal IMHO.
Pete156 is offline   Reply With Quote
Old 02-15-2013, 07:28 PM   #19
Calum
That Guy
Mike, could you post a link? I didn't even know they made bushings...
Old 02-15-2013, 07:39 PM   #20
CSG Mike
CSG Mike's Avatar
It's not something actively marketed here, since there's not a lot of interest in them... send me a PM.
Old 02-15-2013, 08:26 PM   #21
usptwins
Toyota Soul
usptwins's Avatar
Drives: 96 taco
lol air down... haha was just funny
No replacement for Displacement??? Tell that to the people with a 2JZ.
usptwins is offline   Reply With Quote
Old 02-20-2013, 05:28 PM   #22
2Brnt2BRZ
Drives: 2013 WRB BRZ premium
Just give it more gas like a real man and it'll smooth-out past 6000rpm.
Seriously, wheel hop can lead to broken drivetrain parts,including rear differentials, and axles.
On hard launces, wide, sticky 245s would definitely induce wheel hop on our cars w/ soft OEM bushings intended for less grippy tires. Simply upgrading with poly bushings (Whiteline / SuperPro) is all that may be needed. I will be replacing the rear CA and diff bushings.
In some cases, weak shocks, or adjustables that are set too soft? can allow a hopping wheel to continue hopping since the motion is not properly damped. Shocks should not be ruled out as a factor. Good luck on you build.
2Brnt2BRZ is offline   Reply With Quote
Old 04-06-2013, 03:46 PM   #23
Dipstik-sportech
Dipstik-sportech's Avatar
Oh it for sure is possible I know I've done it several times. Just takes a damp road and an overly aggressive launch. I wonder if the rear differential brace that beatrush and cusco are selling would help?
Old 04-13-2013, 09:13 AM   #24
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
less air more shock
Huehuecoyotl is offline   Reply With Quote
Old 04-13-2013, 11:11 AM   #25
WillBRZ
WillBRZ's Avatar
Drives: 2013 BRZ Limited 6MT GBS
I get the worst wheel hop around corners. Kinda freaks me out when it's a 100+ foot drop if I don't hook up around the corner. I used to drive that road all the time in my old cars and never had any issues. It's like I can't push this car as hard as I want to because it starts hopping around corners.
2014 infiniti Q50 Daily 1996 Mazda Miata Racecar
SOLD -> Galaxy Blue Silica Subaru BRZ Limited 6MT
SOLD -> 2003.5 Infiniti G35 Sedan Emerald Mist
WillBRZ is offline   Reply With Quote
Old 04-22-2013, 10:29 PM   #26
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
I was getting crazy wheel hop at the Pro Solo on Sunday.
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 04-22-2013, 11:34 PM   #27
MadFRS
MadFRS's Avatar
Drives: UltraMarine FR-S
I can also contest to stock, in my case Bridgestone tires, having wheel hop. I agree with @Dipstik-sportech that slightly damp road with a hard launch will definitely cause it.
Gear shifter shacks like a motha-f.....
MadFRS is offline   Reply With Quote
Old 04-24-2013, 01:33 AM   #28
OrbitalEllipses
Drives: Attitude
Had a strange occurance earlier today. Dumped the clutch from 3k and floored it with TRAC/VSC off (both orange lights illuminated on dash) and obviously spun the rear tires, but as the car started to move sideways (after moving forward several feet) wheel hop occurred; that's not odd. What's odd is that the slip light illuminated when the wheel hop occurred. Theories? Ideas?
Tires are Michelin Pilot Super Sports in 225/45/17 and this occurred in the dry, albeit at a temperature bordering on "cold" when it comes to summer compounds.
Wheel Directory: ProDrive GC-012L 18x8.5 +48 MarkMash Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 05-12-2013 03:55 PM
OK wheel gurus, wheel are here, now for tires FRSGT86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 02-12-2013 01:36 AM
Wheel Gap & Wheel Size white_knight Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 01-26-2013 10:01 AM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 12:28 PM
