Old 02-14-2013, 07:44 PM   #1
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
How to fix wheel Hop
What causes wheel hop on these cars, is there a way to fix it?
Thanks,
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 02-14-2013, 07:50 PM   #2
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Burnouts.
husker741 is offline   Reply With Quote
The Following 8 Users Say Thank You to husker741 For This Useful Post:
8R6 (04-22-2014), charged86 (08-23-2013), civicdrivr (04-24-2013), Dimman (04-06-2013), EsoBOFH (04-15-2016), ftc~brz (09-24-2013), QuikSilveRX-8 (04-24-2013), Turdinator (04-24-2013)
Old 02-14-2013, 07:56 PM   #3
Walldodger
Walldodger's Avatar
Drives: Four wheels, two seats, etc
Do you mean the wheels are tramping on acceleration? I didn't think that was a problem with these cars.
But first I've heard of it.
Walldodger is offline   Reply With Quote
Old 02-14-2013, 08:54 PM   #4
dorifuto
If in doubt,flat out
dorifuto's Avatar
Drives: 2013 brz
I've dumped the clutch and smoked the tires plenty of times. Never once had wheel hop.
dorifuto is offline   Reply With Quote
Old 02-14-2013, 09:28 PM   #5
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
I get wheel hop all the time. Just not when sideways. It happens more on damp roads. And it is violent.
Needs subframe bushings I think.
Coheed is offline   Reply With Quote
Old 02-14-2013, 09:38 PM   #6
Simmons
Simmons's Avatar
Nope, I already have them and it didn't help.
Simmons
Old 02-14-2013, 09:46 PM   #7
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Control Arms
Tansey86 is offline   Reply With Quote
Old 02-14-2013, 10:56 PM   #8
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Differential bushings maybe? There are some trailing arm bushings and stuff available too but this is the first i've heard of this issue.
Old 02-15-2013, 06:36 AM   #9
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
Control arms, controls arm bushings, and diff bushings. It worked for my G8 GT.
Sent from my Galaxy S3 using Tapatalk 2
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 02-15-2013, 06:52 AM   #10
Calum
That Guy
Drives: 2013 asphalt FRS MT
[ame="https://www.youtube.com/watch?v=IDfJ_zYFPcs"]BRZ / FT86 / FR-S Whiteline Subframe Lock Out Kit - YouTube[/ame]
Watch the diff bushings in this video.
Wheel hop can come from a lot of places, if you're getting it you need to take care of all of them. I think those stock diff bushings are going to be one of the weakest links. But subframe bushings, control arm bushings, springs and shocks, and even the tires can all play a part. I know guys that would swap strut/springs packages if they were going from drag radials to slicks.
This can get as in depth as tuning the rest of the suspension.
For now, try adding 2 more psi to your tires and see if that helps.
The Following User Says Thank You to Calum For This Useful Post:
continuecrushing (04-24-2013)
Old 02-15-2013, 10:54 AM   #11
wparsons
wparsons's Avatar
Will diff bushings actually do anything for wheel hop? I would think only parts that actually effect the suspension (subframe and control arm) bushings would have an effect?
flickr
Old 02-15-2013, 11:40 AM   #12
xxscaxx
Drives: 2013 SWP BRZ
I get this a lot on my winter tires... If I step on it and i'm on a crappy road, my TSC goes off and you can just see my RPM's bouncing. its annoying as shit. I never noticed it with my stock tires. I just assumed it was the snows.
xxscaxx is offline   Reply With Quote
Old 02-15-2013, 12:30 PM   #13
Noob4Life
86 Noob
Drives: Firestorm FR-S
I replaced just the dogbone mount in my jetta with a stage 1 poly mount and there was so much less wheel hop that I actually thought id lost some power. The difference was might and day.
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
Noob4Life is offline   Reply With Quote
The Following User Says Thank You to Noob4Life For This Useful Post:
jeepmor (04-28-2022)
Old 02-15-2013, 12:39 PM   #14
A5D5TRYR
A5D5TRYR's Avatar
Drives: FR-S 6MT Ultramarine (BeeDrill)
I seem to get this with my winter tires as well.
2013 Scion FR-S - Ultramarine 6MT
A5D5TRYR is offline   Reply With Quote
Wheel Directory: ProDrive GC-012L 18x8.5 +48 MarkMash Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 05-12-2013 03:55 PM
OK wheel gurus, wheel are here, now for tires FRSGT86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 02-12-2013 01:36 AM
Wheel Gap & Wheel Size white_knight Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 01-26-2013 10:01 AM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 12:28 PM
