Driver of FR-S 1467
Drives: 2013 scion frs 001467
would new brake pads significantly boost braking?
ive been driving a while with the frs and imo i feel like the brakes need more power behind them. when exiting an off ramp and trying to drop from 75mph, the brakes feel mushy as heck. same when im driving in the mountains and slowing for a tight turn.
my budget is kinda spent so i have to start saving up for the next thing and was wondering how much difference a nicer set of pads would have. i know a bigger brake kit would work much better but its much too expensive for me. |
#2 |
They sure will. Try an entry level race pad, but be careful when you're in freezing temps. They'll take a stop to warm up. Just one.
http://www.ft86club.com/forums/showt...ight=carbotech |
#3 |
Drives: Whiteout FR-S
Agree with Mike you might want to change fluid also to some Motul or AP Racing. There are lots of good pads available, Ferodo DS2500, Project Mu, and even the StopTech pads are supposed to be pretty good.
#4 | |
Drives: 2012 BRZ Premium WRB 6MT
Yes, pads will be your most significant upgrade in terms of feel. I would recommend Ferodo DS2500 front and rear. They are great for daily driving, weekend canyon bombing, autoX, and even track duty in some situations. They are an excellent value for their performance.
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division www.essexparts.com ![]() |
#5 | |
Drives: Attitude
#6 |
Ferodo 2500s are a great street pad that can take some real abuse.
- Andrew |
#7 |
Drives: 2013 Asphalt FR-S
Please flush out the oem fluid and replace with a high boiling point fluid like RBF600 or 660 if you step up to an agressive pad.... you can easily boil the fluid before DS2500's come close to pad fade... been there.. done that..... IMO Fluid should be the FIRST thing you upgrade with the brakes, then pads and lines.
~Namaste~ |
#8 |
If you could swing it try to do fluid and rotors at the same time.
http://ft86speedfactory.com/stoptech...grade-216.html $530.50 for: Kit Includes: 2 - Front Slotted Rotors 2 - Rear Slotted Rotors 1 - Front Brake Pad Set 1 - Rear Brake Pad Set 1 - Stainless Line Kit Front 1 - Stainless Line Kit Rear |
#9 | |
Drives: Attitude
He doesn't need rotors; yet. This kit includes pads, lines, and good fluid...all the necessities without spending money on unneeded rotors. |
#10 |
I'd just start with good fluid and pads. Even the lines aren't really necessary yet.
#11 | |
First 86
Drives: Scion FRS Argento Automatic
Edit: After doing some internet research it seems these brakes have a tendency to squeal a lot.
Life is short...NO BORING CARS Last edited by russv; 02-13-2013 at 01:07 PM. |
#12 | |
Drives: Attitude
You don't want dust or noise? Go with a ceramic "comfort" pad. Lower coefficient of friction, less performance. |
#13 | |
The Carbotech AX6 is designed for AutoX, where you want the increased bite and performance, but don't necessarily need something that's capable of a spring race. |
#14 |
Drives: Attitude
IIRC, they carry the price tag for their comfort too :-P
Good pads as well. I went through numerous street compounds on my WRX. Ferodo DS2500, Porterfield R4S, Stoptech Street, Carbotech AX6 and 8. |
| DIY - Changing Your Brake Pads (Race Pads upgrade) | PMok | DIY (Do-It-Yourself) Guides | 53 | 09-03-2021 05:17 PM |
| Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! | Mike@CZP | Brakes, Suspension, Chassis | 348 | 06-01-2018 12:29 PM |
| which brake pads? | NESW20 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 165 | 02-25-2018 02:07 AM |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 10:20 PM |
| brake pads | Dpark27 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 09-07-2012 07:58 PM |
