#15 |
Drives: Ultramarine FR-S
Like everyone else has said keep practicing. I'm in the same boat with 2nd. Sometimes it's good sometimes not so much but this is my first manual and I learned in it so keep at it because it's that much more rewarding when you everything clicks in place.
Also once your car is a bit more broken in you may be able to feel the catching point a bit more. My clutch feels way different from when I first got it (though could just be all the practicing too, lol. I'm At 2700 currently today) |
#16 |
Drives: 1997 Honda Prelude 5spd
Just more practice man. Got to find the right release point in the clutch while applying gas. The more you drive, the better you'll get at it.
Don't worry so much about accelerating faster cause of the people behind you. They can either wait or switch lanes. Focus and feel your your clutch. |
#17 |
Drives: Ultramarine FR-S 6MT
I've found it helpful to lift my heel up and bend at the knee slightly when releasing the clutch. I dunno why, but the ankle-pivot throws me off sometimes. I'm planning to do the clutch mod as soon as I get a nice warm day to play with it.
#18 |
Drives: 2013 FR-S Hot Lava
This is my first MT also and the 1-to-2 shift is something I still can't get right all the time. Any other up-shift is no problem.
I had to develop a whole separate technique for the 1-to-2 and in the process, I learned that it actually makes the other shifts better as well... lol In other words: practice and experience.
Live to drive another day
#19 |
Drives: 2013 FR-S Raven with carbon fiber
It was about 1500k befor I got the hang of it and still do it from time to time. As long as your still only shaky and not stalling your doing good. But simply try to have it at atleast 1500 rpm befor you let the clutch out enough to grab.
#20 | |
#21 | |
You Made Bro?
Drives: Raven 86
http://www.ft86club.com/forums/showt...t=gear+synchro |
#22 | |
Drives: M/T Raven FR-S
| The Following User Says Thank You to luuser75 For This Useful Post: | 5th 86 (06-17-2013) |
#23 |
You Made Bro?
Drives: Raven 86
the thing is cold is subjective, but not for this car, imo under 50 its a pain to get into second. even when its warm like 80 outside getting in and out of second is still vastly too rough. im in oc, if youd like to drive my car to see the buttery smoothness yourself ill show you.
#24 |
Drives: Scion FR-S
The 1-2 shift in this car is abnormally tricky to get completely smooth. I think it has to do with the fact that the ratios between the two gears are so far apart you could drive a truck through them, mixed with the revs not falling off quickly enough after you depress the clutch. (It holds them for just a second after you press the clutch, and it pisses me off)
#25 |
Drives: 2013 Limited DGM BRZ
practice practice practice ..then do the mod. It's worth it.
BRZGrincherhood |
#26 |
Pull my finger...
Drives: Silver Scion Slushbox
I must be getting old. I saw "Jerky / shaky sharts"
Don't overthink it, that's what usually causes it and prolongs the learning curve. Eventually, with enough practice it will all fall into place for you. |
#27 |
Drives: FR-S 6MT Whiteout
The car has an awkward clutch plain and simple. 1st gear is tough to get smooth regardless of your practice with the car or manual transmission experience
Follow me on Instagram @filthytravis
#28 |
I came from a motorbike
Drives: Firestorm 2013 FR-S 6MT
I was dropping off my girlfriend today, and I was low on gas, so I figured that I would grab a tank, and then on my way home, I decided to have some fun, and play around with starts from a complete stop and shifting into second.
Now personally, the way I found it easiest to get consistent, smooth, starts from a complete stop is too try and keep your RPMs as close to 1000 as possible until you fully disengage the clutch (should happen around 6MPH), and then you give it a little gas. Blipping the throttle or easing out the clutch before giving it gas generally wound up in rough starts. As for 1st to 2nd, it's still a work in progress for me. I generally wait for the RPMs to drop a bit while fully depressing the clutch, if I'm consciously thinking about it; however, I never consciously think about it whilst driving. That's just my sub-500 miles experience. I'm sure I'll have a revelation, but I did find I drove better after having a beer. Please take that advice with a grain of salt, I'm not encouraging driving with alcohol in your system, but it helps to take the edge off. |
| 2011 Nissan GT-R Pricing Starts at $85,060 | vh_supra26 | Other Vehicles & General Automotive Discussions | 195 | 05-18-2023 09:12 PM |
| Evasive Motorsports Project BR-Z officially starts now!!! | Evasive Motorsports | BRZ Photos, Videos, Wallpapers, Gallery Forum | 154 | 09-30-2014 04:23 AM |
| Cold morning starts | coldy | CANADA | 43 | 04-23-2013 02:30 PM |
| Issue: Cold starts | jesseps | CANADA | 7 | 11-24-2012 11:26 AM |
| I Hope FR-S Pre-Ordering Starts Soon! | Jokester | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 02-22-2012 10:07 AM |
