CANADA Canada
Old 11-28-2012, 11:53 AM   #1
coldy
coldy's Avatar
Drives: Scion FR-S Asphalt MT
Cold morning starts
I'd like to know if anyone else has experienced a problem with the car starting up in the morning when its -5C and under. I've noticed it the past couple mornings here in Montreal that it doesn't just come to life.
It takes a good 5-10 seconds of chtz.. chtz.. chtz.. vroooom. till it gets going.
Thoughts?
coldy is offline   Reply With Quote
Old 11-28-2012, 12:01 PM   #2
KingGeo
Drives: FRS
nope, but mine is garage parked, unheated garage mind you. not sure exactly what the temp in the garage is but she has been starting up just like it was +10
KingGeo is offline   Reply With Quote
Old 11-30-2012, 02:09 PM   #3
whitejdm
Drives: BRZ prem.
I just experienced that same thing this morning, parked outside with it being -15c, several long cranks then finally starts. Tonight I am going to try out the block heater and see if it makes a difference (although modern synthetic oil is usually good till at least the -25 to -30 range).
whitejdm is offline   Reply With Quote
Old 11-30-2012, 02:13 PM   #4
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
It was -13 here this morning it wasn't any harder to start than usual.
If this happens again, try removing the key, and try 'her up again.
Rayme is offline   Reply With Quote
Old 11-30-2012, 02:23 PM   #5
JSUB
JSUB's Avatar
Drives: 2026 BRZ tS coming
-13 C this morning (1st real cold morning) and not problem at all to start. Have a battery warmer thought. Also notice some weird noise coming out of engine bay/under the car once engine running (1s 10 sec). Like a clunk noise. Could it be some kind of vaccum/trap closing because of cold weather (just had the dealer service guy on the phone while typing this and he had no clue about potential cause...)
JSUB is offline   Reply With Quote
Old 11-30-2012, 06:58 PM   #6
jesseps
Drives: Scion FR-S
I have yet to change my battery, for something that would work in colder weathers. Plus I do want to get a block heater, seeing at least it be quicker to have a warmer car in the mornings.
jesseps is offline   Reply With Quote
Old 12-01-2012, 11:21 AM   #7
whitejdm
Drives: BRZ prem.
Just an update, -15 last night at my Christmas party (parked outside 4 hours) then-18 this morning. Didn't plug it in, fired up no problem on first crank. Will monitor it.
Old 12-01-2012, 12:56 PM   #8
Ben_G
Drives: Blue BRZ
I have had long cranking situations, but not related to cold. On two occasions, i've parked the car for about an hour or so and when I go to start it, it takes about 10 seconds to fire up.
Ben_G is offline   Reply With Quote
Old 12-01-2012, 01:57 PM   #9
waynegro
Drives: Dodge Omni
I have also experienced the long start a couple of times.
waynegro is offline   Reply With Quote
Old 12-01-2012, 04:24 PM   #10
thorlius
Canadian
Drives: Frieda: Firestorm/MT (11/28/2012)
Had it happen to me this afternoon. Held the key for probably three times as long as usual, and nothing. Waited 10 seconds then tried again, and it started up no problem. The car was still warm from being driven only a couple hours before, and it was around 0 degrees outside. It was pretty weird.
thorlius is offline   Reply With Quote
Old 12-07-2012, 12:21 PM   #11
coldy
coldy's Avatar
Got an appointment on the 11th to check a number of annoyances I have with the car (ie. crickets, weird RPM at idle, TPMS sensor going off with temperature dip).
I already mentioned to them about the car having trouble starting in the mornings. So we'll see what they say.
Old 12-07-2012, 02:20 PM   #12
JSUB
JSUB's Avatar
TPMS (tire air pressure in fact) are sensible to quick temperature dip. If too suddent temp drop, pressure in tires will drop and TPMS will send signal. Happens to many of us (independent of what your driving).
Driving the vehicule will bring tire air pressure up at least 3-5 PSI I would guess but that might not be enough to re-establish normal pressure. Just go put some air in them and you'll be fine. Happened to me with my Acura lately.
Old 12-08-2012, 10:11 AM   #13
Sh4rp
Had one a couple nights ago when it got really cold. Took 3-4 s
Sh4rp is offline   Reply With Quote
Old 12-08-2012, 05:57 PM   #14
dadream
Drives: SCION FRS (Raven Black)
Had the same starting problem a few times... when it happens I like to convince myself it's only because I didnt push the cluch all the way down. haha that way i avoid mental distress...! FRS Love.
dadream is offline   Reply With Quote
2011 Nissan GT-R Pricing Starts at $85,060 vh_supra26 Other Vehicles & General Automotive Discussions 195 05-18-2023 09:12 PM
Issue: Cold starts jesseps CANADA 7 11-24-2012 11:26 AM
Cold morning and horrible grinding/screeching sound Books Issues | Warranty | Recalls / TSB 1 11-14-2012 02:18 PM
Cold-weather morning shifts NetMagi Scion FR-S / Toyota 86 GT86 General Forum 11 11-08-2012 11:05 AM
I Hope FR-S Pre-Ordering Starts Soon! Jokester Scion FR-S / Toyota 86 GT86 General Forum 15 02-22-2012 10:07 AM
