Old 02-10-2013, 02:06 AM   #43
invisage
Drives: Thunder Silver 86 GTS
Originally Posted by Asphalt~86 View Post
I may or may not have been used as a test car a couple of months back that may or may not make the AT unbelievable in possibly 2 months in which you will possibly have to spend $1500 but will blow your mind.
Solenoid upgrade?
invisage is offline   Reply With Quote
Old 02-10-2013, 08:22 AM   #44
Captain Insano
I'm guessing final drive change.
Captain Insano is offline   Reply With Quote
Old 02-10-2013, 12:06 PM   #45
Lonewolf
Lonewolf's Avatar
Drives: Moped
The Cusco 4.55 RCE is testing is good for either trans. Diff is the same.
Awesome, I thought I had heard the splines weren't lining up properly when it came to the AT. Thanks for the tip!
PS: Somebody install these when they are available!
Old 02-10-2013, 01:47 PM   #46
logoris
Drives: 04 is300 sport design ii
i assume with the final drive upgrade the speedo will also have to be recalibrated, and is there anyone working on different gear ratios for the auto trans
logoris is offline   Reply With Quote
Old 02-10-2013, 10:04 PM   #47
invisage
Just curious with final drive upgrades, as I have never done one, but I assume they will decrease your mileage some?
Old 02-10-2013, 10:23 PM   #48
zoomzoomers
zoomzoomers's Avatar
Final drive changes should give these cars some more pep, but it will definitely have some negative consequences on the speedo and had milage. I'd still love to see what sort of benefits it would bring though.
Old 02-11-2013, 01:38 AM   #49
invisage
Can the speedo be corrected via ECU?
Old 02-11-2013, 07:41 AM   #50
Ingen
Drives: Ultramarine FR-S 6MT
Originally Posted by husker741 View Post
I saw some guy in another thread have a car hit a 6 second 0-60 after some bolt ons and the unichip. That seems pretty impressive considering that's nearly 2 seconds better than stock.
Depending on where you looked, the reviews have the stock car (MT) anywhere from 6.2 seconds to 8+ seconds.
Automobile mag got 6.2: http://www.automobilemag.com/reviews...13_scion_fr_s/
Road and Track claims 7.6 seconds:
http://www.roadandtrack.com/car-revi...ring-prototype
Reinforcing the moral of the story, which is that driving lessons are the best mod you can possibly buy :P
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 02-11-2013, 08:32 AM   #51
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
I assume he meant that the top speed won't be as high because of the new gears.
Freeman is offline   Reply With Quote
Old 02-11-2013, 10:05 AM   #52
Anorexic 86
Trim the Fat & add Boost
Anorexic 86's Avatar
Drives: sometimes I fly
Originally Posted by Gixxersixxerman View Post
first race.. from about 5mph
second race some where in second gear for both of us
his is stock. mine has a greddy evo3 exhaust, injen intake, and perrin LW pulley. also both fuel tanks were around the same.
The automatic (one doing the recording) is not in SPORT MODE... the shifts would have come even faster... also, traction control wasn't fully disabled (see the cluster at the end of the 2nd video)... not that it would make a difference, but still.
The auto is upgraded, correct? With a GReddy cat-back and an Injen (hot air) intake and still loses.
Install the stock cold air intake, reset ecu... enable transmission SPORT MODE and it would be a closer race.
Anorexic 86 is offline   Reply With Quote
Old 02-11-2013, 01:11 PM   #53
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Sport mode only matters when it is shifting.. In drive.. When you put it in Manuel mode and do the shifting it doesn't matter.. And with the intake and exhaust I put 175 hp down at the wheels.. I don't see what taking the intake that has proven to be the better one out there off to make it a closer race.. But as I've taken my car to the streets of willow ands tried the sport mode and stuff and it doesn't change anything one bit
Gixxersixxerman is offline   Reply With Quote
Old 02-11-2013, 01:21 PM   #54
Orthow
Drives: 99' SIR Kswapped Racer/Showcar
Originally Posted by Freeman View Post
I hate a tease.....unless I'm paying for it.
To the OP, I went with the AT because MPG. This car is my personal car (my work provides me with a car) so it's the one I take for long trips back to see the parents.
If you're comfortable with a manual and want the max performance from the car then get the manual. I doubt you'll regret it.
Da fuq? Did I just read lol
It's a standard transmission that gets the better fuel mileage. You must be new to cars to assume it's the other way around.
Also, AT's in economy cars will always be slower than their manual counterparts.
All this talk about changing the rear gears to even things up is dumb. You can do the same with the stick - then what? lol.
Orthow is offline   Reply With Quote
Old 02-11-2013, 01:25 PM   #55
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
Actually the A/T gets better mileage than the MT. http://www.ft86club.com/forums/showthread.php?t=12715
mechaghost is offline   Reply With Quote
Old 02-11-2013, 01:31 PM   #56
zoomzoomers
This is fast becoming another MT is faster than AT thread. Then someone will come along and post that the Camry V6 is faster than Flash Gordon thread and we'll be in a ton of shit.
The Following 2 Users Say Thank You to zoomzoomers For This Useful Post:
Freeman (02-11-2013), husker741 (02-11-2013)
Transmission swap: auto to manual... itdansharpe Engine, Exhaust, Transmission 39 02-12-2018 04:53 PM
WRB Premium BRZ Auto. Transmission Available! ShoShin BRZ First-Gen (2012+) — General Topics 1 11-16-2012 07:25 PM
Why IS TRD so slow..... SF-FRS Engine, Exhaust, Transmission 10 07-10-2012 03:11 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
