Old 02-08-2013, 07:42 PM   #29
hachi_dos
hachi_dos's Avatar
Drives: 2013 FR-S ARGENTO
Im running 18x9.5 +35 and running 255/35 all the way around. the fronts poke slightly but im happy with it. im lowered on coilovers. not super low though.
hachi_dos is offline   Reply With Quote
Old 02-08-2013, 09:44 PM   #30
wparsons
wparsons's Avatar
Originally Posted by Tansey86 View Post
They will, as demonstrated a dozen times. You just need the proper offset for it to work.
Should've clarified... I meant fit without poking.
flickr
Old 02-08-2013, 09:46 PM   #31
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
If you run say a 18x9.5 +42 from what ive seen you can clear it and it is flush.
Tansey86 is offline   Reply With Quote
Old 02-08-2013, 10:25 PM   #32
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Skurj View Post
rolled from the factory..
... up front.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-08-2013, 10:32 PM   #33
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Fortunate Few View Post
It is. It's just not folded flat. There is still a lip at an acute angle.
It's basically horizontal, it's not at all what most consider rolled (the front is though).
It does have a beveled edge or whatever, but it's still horizontal and sticks in 1/2"-3/4". Less need to roll the rears for most people. They did cut the material back some tough.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-09-2013, 11:18 AM   #34
SonnyBRZ
SonnyBRZ's Avatar
Drives: 15 WRX 6mt (DD), 13 BRZ Sports Tech
What tires are you putting on?
For example, I purchased 245/35/18 Michelin Pilot Super Sport. The section width of the 245/35/18 PSS is the same as a...say.. 255s Yoko S-Drives or 255s Hankook V12s. 255s AD08s will almost be an inch wider than 245s PSS.
Generally, the more "Extreme" summer tires have a slightly wider tread width.
265s Evo v12s is only 0.1" wider in tread width compare to a 245 PSS. Depends what you want, i chose the latter.
06 Infiniti G35x - Black 5AT (DD)
13 BRZ Sports Tech - White 6spd (June 18, 2012!) - Vortech SC
15 WRX Sport - ISM 6spd - Ordered May 3, 2014
SonnyBRZ is offline   Reply With Quote
The Following User Says Thank You to SonnyBRZ For This Useful Post:
switchlanez (12-07-2013)
Old 02-09-2013, 12:21 PM   #35
Skurj
Drives: SOLD...
Hmm good info, I am going with the Hankook V12's. The car they said they had rubbing with was lower than mine will be and they had fit Michelin PSS which were rubbing a little in 255.
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
Old 02-09-2013, 12:27 PM   #36
MTCRX
MTCRX's Avatar
Drives: Whiteout FRS- autocross ready
You have to remember that many customers are depending on the tire store to get the right tire on the car. And their past experiences with the particular car will be a factor. They want to do the best for you but also don't want to spend a lot of extra time on a wasted effort and risking damaging a vehicle or causing a mechanical failure and maybe a wreck. There are so many people out there that will blame the tire company and demand they fix the problem at their cost. You might consider since this is a special project that it may cost you more. Just because a customer says a tire will fit probably isn't enough for the tire shop staff who deal with tire fitment everyday. Good luck. Maybe find a shop interested in this modification process.
MTCRX is offline   Reply With Quote
Widest tire to fit on an 18x9.5 Wheel?!!! ** ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 60 07-07-2014 05:08 PM
Recommend a good tire shop in LA/OC Hanakuso Southern California 10 12-08-2012 06:15 PM
Tire/Wheel or auto shop recommendation in Seattle area please. mugen79 Northwest 6 12-04-2012 01:13 PM
Socal area tire shop? Tylub Southern California 3 11-03-2012 03:00 AM
F/S Enkei RPF1 5x114.3 18x9 +35 18X9.5 +38 with track tires SsmoothyMonster Wheels and Tires 17 09-24-2012 02:52 AM
