Old 02-07-2013, 08:05 PM   #15
Foobar
SLO NO MO
Foobar's Avatar
Those of you noticing this - can you check your oil level and see if it's still where it should be? I wonder if it's not engine oil but some other kind of lubrication coming from somewhere else.
Old 02-08-2013, 08:27 AM   #16
sure74
sure74's Avatar
Drives: 2016 Toyota 4Runner Trail Premium
Looks like it is coming from the bottom of this plate.
Dripping on to the block, then on to the header.
From a much lower angle, doesn't look like it could be coming from anywhere else.
sure74 is offline   Reply With Quote
The Following 5 Users Say Thank You to sure74 For This Useful Post:
BlaineWasHere (03-19-2013), developer (02-08-2013), Egyptn (11-28-2013), jeebus (02-08-2013), LeeMaster (02-08-2013)
Old 02-08-2013, 09:01 AM   #17
Foobar
SLO NO MO
Foobar's Avatar
Hmm, anyone know what that plate is? Cylinder head plate?
Old 02-08-2013, 09:22 AM   #18
jimbobrand
jimbobrand's Avatar
Drives: 2013 Subaru BRZ Premium
Exact same thing for me. I'm at 15K+ and probably noticed it 2K earlier. Will check as op suggested and report back.
Same with me. Mine started after my 15,000 service and I thought it might have been due to the dealership overfilling the oil (the dipstick level was reading 1-1.5" higher than full). I had the oil changed and the engine checked for leaks, with no leaks found (according to the dealer). I was still getting a burnt oil smell for the last week up to at least a couple days ago but didn't notice it yesterday or today.
Jim Brand
2013 Subaru BRZ Premium 6MT WRBP
Oklahoma Subaru Crew-OKSC.org
TXIC San Antonio
jimbobrand is offline   Reply With Quote
Old 02-08-2013, 05:33 PM   #19
jimbobrand
jimbobrand's Avatar
Well, I just checked and my car has a similar (although bigger) spot of oil on that cylinder head plate. Looks like it might be time to make an appointment with the service department.
Jim Brand
TXIC San Antonio
The Following User Says Thank You to jimbobrand For This Useful Post:
Mikem53 (08-24-2013)
Old 02-08-2013, 05:52 PM   #20
jeebus
bummer.
jeebus is offline   Reply With Quote
Old 02-08-2013, 06:39 PM   #21
jimbobrand
jimbobrand's Avatar
Originally Posted by jeebus View Post
bummer.
In a way, but at least I know where the burning oil smell is coming from now.
Jim Brand
TXIC San Antonio
Old 02-08-2013, 06:41 PM   #22
developer
Drives: BRZ Limited
Add me to the oil leak list, my VIN is in the 3400 range. I have been smelling burning oil off and on since I got my car. I needed to take my car in for it's first oil change anyway. Thank you tonytduc for the heads up and sure47 the pictures! And no my oil level is just fine.
developer is offline   Reply With Quote
Old 02-08-2013, 07:20 PM   #23
Foobar
SLO NO MO
Foobar's Avatar
So it looks like it's a very small leak then. I too noticed some burning smell coming from the header area after a spirited run - I can't check right now due to the blizzard out here, but I suspect I too have this oil spot on the cylinder head plate. VIN 2100 range, 3K miles. Sounds like the same gasket problem that plagued earlier subies?
Old 02-08-2013, 07:36 PM   #24
jimbobrand
jimbobrand's Avatar
This isn't a head gasket issue like the early EJ251s but might be an issue with the gasket under the plate or bolts becoming loose over time.
Jim Brand
TXIC San Antonio
Old 02-08-2013, 07:56 PM   #25
zoomzoomers
zoomzoomers's Avatar
I think I'm starting show signs of this issue.
Old 02-08-2013, 07:56 PM   #26
Foobar
SLO NO MO
Foobar's Avatar
Ah - think we might have to re-torque those bolts on the cylinder head plate?
Old 02-08-2013, 09:41 PM   #27
tonytduc
tonytduc's Avatar
You are very welcome.
tonytduc is offline   Reply With Quote
Old 02-08-2013, 09:43 PM   #28
tonytduc
tonytduc's Avatar
I did but still small leak after a few days.
The Following User Says Thank You to tonytduc For This Useful Post:
Marrk (02-09-2013)
Still Leaking? 636 Issues | Warranty | Recalls / TSB 15 01-11-2013 03:41 PM
Leaking Oil? 636 Issues | Warranty | Recalls / TSB 11 01-05-2013 04:43 PM
Leaking front left shock Xauterus AUSTRALIA 10 11-06-2012 04:15 PM
Tires keep leaking EvoXDD Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 08-29-2012 03:03 AM
Brake Light Leaking Covered in Condensation Smokinbuffalo BRZ First-Gen (2012+) — General Topics 9 06-12-2012 04:43 PM
