#29 |
Senior Addict
Drives: 86 GT
Slight difference in drop, the ProKit gives 25mm drop whereas the Sti items are 15mm. But yea the eibachs are much cheaper.
| The Following User Says Thank You to Fizz For This Useful Post: | DNAPoPo (02-05-2013) |
#30 |
Drives: 86 GTS
#31 |
Wannabe JDM Type S
Drives: 2013 BRZ Limited
no issues. What's captive w/o compression mean?
My Wannabe JDM Type S build: http://www.ft86club.com/forums/showthread.php?t=24702
#32 |
Drives: 86 GTS
Spring is trapped in the top of the shock when it's hanging free (isn't loose on the shock body before you fit it to the car.)
#33 |
Wannabe JDM Type S
Yes c wo c
| The Following User Says Thank You to ZC6BRZ For This Useful Post: | Panman (02-08-2013) |
#34 | |
Shift Down
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
plus i like RCE A lot keep up the good work guys!![]()
| The Following User Says Thank You to DanoFA20 For This Useful Post: | Racecomp Engineering (05-03-2013) |
#35 |
Drives: 2022 WRB BRZ; 1993 Skyline GT-R
That looks great! Just what I'm looking for too! I'm not trying to slam my car but do want to get a little bit of a drop. Anything over an inch is just too much.
#36 |
Drives: 2012 F25 X3 xDrive35i M-Sport
Where did you buy the spring?
#37 |
Mine are arriving tomorrow from japanparts.com
#38 |
Drives: GT86
Does anyone know the rates of these springs? (particularly the higher rate)
#39 |
Drives: 86 GTS
Installed these in my 86 - Definitely a good upgrade. Certainly rotates quicker, ride is not compromised and drop is noticeable but not excessive as I have the factory Aero kit (Australia) and cant drop too much.
| The Following User Says Thank You to Panman For This Useful Post: | Jaylyons1 (03-23-2013) |
#40 |
Would those of you with the STI springs kindly share how much they affected your wheel alignment?
Did you install any other suspension parts or just the springs? |
#41 |
Drives: 86 GTS
I had mine aligned when I had them fitted - back to factory specs which it did with no problems. No other parts in mine except the springs at this point.
| The Following User Says Thank You to Panman For This Useful Post: | BRZebra (05-27-2013) |
#42 |
Drives: Toyota 86 Turbo, Lexus NX300H
front : no camber change
rear : -1.5~1.8. I installed Pink springs with STI flexible tower bar. (& front camber bolt too) definitely better handling with good ride quality. |
| The Following User Says Thank You to Yobiwan For This Useful Post: | BRZebra (05-27-2013) |
| OEM BRZ springs? | jm1681 | Brakes, Suspension, Chassis | 1 | 11-03-2012 08:14 AM |
| Anyone use the JDM/Sti springs? | G4mb17 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 10-25-2012 08:10 PM |
| HELP:Q about springs | Obja | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 10-08-2012 02:12 PM |
| trd springs or no? | FT86R | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 09-30-2012 03:52 PM |
| STi Springs | illmatic | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 08-14-2012 01:19 PM |
