| AUSTRALIA Australia and New Zealand |
#43 | |
Drives: 86 GTS
#44 | |
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
My fully loaded TRD86
http://www.ft86club.com/forums/showt...760#post582760 |
#45 | |
Drives: Exige S 240
#46 |
Drives: 2011 Corolla Ascent Sport
Yes, Techstream can read live engine oil temp.
Unless you can hack the Techstream software (and have a recent enough version), you won't be able to get the PID straight away. The long way is to monitor each PID during warmup ... The quick way to get it would be 'sniff' all PIDs without Techstream running, then a second one whilst Techstream is on with a custom data list with only the desired channel selected. The difference between the two will be that you will see at least 20 times per second the request and reply for that PID will be sent over the CAN-BUS. You would need to work out a way to make a DLC3 double adapter though ... |
#47 |
Not sure of Europen suppliers but you can get from New Zealnd here with worldwide shipping http://www.fortyone.co.nz/parts/show...%20Gauge.html#
Make sure you choose the Subaru one and if you want orange or white illumination. Or from Japan here - this is the BRZ one as your profile says you have a BRZ. Woud be good to be able to buy from an FT86 club vendor but I haven't found one that has it. http://global.rakuten.com/en/store/w...auge_dxw_wbrz/ .
#48 |
Drives: 2013 Asphalt FR-S
EcuTEK is most likely pulling the data directly from RAM addresses and bypassing OBD all together.. that is why they have a fast logging rate with lots of parameters.
#49 |
Pegasus White
Drives: 86
I accidentally left my adepter left in when I took my car in to get a service... The guys urged strongly not to use them as it can cause shortages and fry the obd port....
HAAHHH
Driving: Pegasus White Manual GTS 86.
#50 | |
Sent from my SCH-I535 using Tapatalk 2 |
#51 | |
Did you chaps see this! Oil temp PID
http://www.ft86club.com/forums/showp...&postcount=123 Quote:
#52 |
Drives: Silver Manual Toyota GT86
It works as well!
See here http://www.gt86ownersclub.co.uk/foru...011.html#35011
This is the UK owners club, but we used the info supplied by Andrey Alec |
#53 |
Oil temp using Dash Command on iphone and ipad.
Posted this in a couple of threads so sorry for the cross post but want to make sure as many people that are interested in this know about it. As many of you will know you cannot currently add the oil temp PID for the twins to Dash Command to get oil temp to show on an iPad or iPhone. Best option at the moment is to use Torque on an Android. Not good for iOS users. If you use an iPhone or iPad and want to be able to see oil temp gauge using dash command PLEASE go to the developers Dash Commnd forum and add you voice to the request thread here. http://www.palmerperformance.com/for...pic=6351.0;all They are looking at adding Toyota/Subaru specific sets of data but also other makes. The more of us that request either being able to add specific PIDs or a Toyota/Subaru set the more likely we get to the front of the queue for development. Also a good idea to write an app review of Dash Command and tell them you have voted it down due to no oil temp for the 86 or BRZ. Let's get the FT86 Club to put the pressure on their development team! 86ers are go! .
#54 |
Drives: 86 GTS
honestly think this is the best way, i popped mine in just to see the results but ended up leaving it there,
the best bit is that you can match the colour to the dash... Scangauge II |
#55 | |
I still like the idea of gauges on an android head unit best but agreed that looks pretty good.
#56 |
Drives: 86 GTS
| BT OBDII/Android/Torque Confirmed working | Dadhawk | Engine, Exhaust, Transmission | 54 | 12-06-2012 12:57 AM |
| brake light connector | kask2_6.0 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 10-28-2012 05:18 PM |
| iPhone 5 new connector & BeSpoke?!?!? | Davyator | Electronics | Audio | NAV | Infotainment | 14 | 09-18-2012 11:39 PM |
| Subaru iPod Connector Cable? | Kimsey47 | Audio/Visual, Electronics, Infotainment, NAV | 25 | 07-05-2012 02:49 PM |
