Old 02-05-2013, 12:25 AM   #1
tintumz22
tintumz22's Avatar
Drives: 2013 Scion FR-S Toyota 86
Functional tire combo
I'll be upgrading wheel specs to staggered. 18x8.5 F et.35 & 18x9.5 R et. 42. Question is what can you guys suggest for a functional tire combo? Especially in the rear. Chose staggered for looks but still want this tail happy car be there. (Note:I'm a little noob so trying to learn these stuff)
tintumz22 is offline   Reply With Quote
Old 02-05-2013, 04:12 AM   #2
Stance86
Drives: Toyota 86 GTS
Given what you have said, what about 225 F and 235 R.. or even 235 all round if you want to be able to rotate.
I am on 18x9.5 +38 rear with a 255 and definitely the car is a bit too grippy for the stock power now.. so I would think maybe a 235 given you say you want it to be tail happy..
You will find it will actually make the most difference with your tyre choice.. a really good 235 will perform better than the cheapest 255..
Stance86 is offline   Reply With Quote
The Following User Says Thank You to Stance86 For This Useful Post:
tintumz22 (02-05-2013)
Old 02-05-2013, 04:21 AM   #3
coyote
coyote's Avatar
Drives: Slowly
Tip #1: Choose your tyre size first, then select wheels to suit.
coyote is offline   Reply With Quote
Old 02-05-2013, 01:52 PM   #4
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
I disagree since finding tires to fit your wheels is much easier than the other way around.
Plus you may find some wheels you like that are rare or whatever and they might not fight the tire size you wanted to begin with.
I'm dangerous, find some wheels; make em fit.
edit: 225f 235r is a good suggestion.
I would even say 225 all around but some may think that's too much stretch on a 9.5
dori. is offline   Reply With Quote
The Following User Says Thank You to dori. For This Useful Post:
Old 02-05-2013, 01:53 PM   #5
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
I like my grip
instagram @Tylub
Mods: Tomei UELs, Tomei OP, Perrin Catted FP, ARK DT-S, Perrin LW Crank Pulley, Enkei RPF1, RSR Sporti, Supertek Intake Tube, Perrin CAI, Stoptech SS lines/brakes/slotted rotors, Cusco MCB brace/Strut Bar
Tylub is offline   Reply With Quote
Old 02-05-2013, 01:55 PM   #6
Tylub
Tylub's Avatar
your offset for the front is pretty aggressive, maybe you'll get understeer
but if you are to be running 9.5 in the rears... you gotta stretch some 235s on there and maybe go 205/215 stretched fronts if you want a tail happy car.
maybe go with a 9.0 rear and 8.0 front to minimalize stretching and still keep the staggered look
I'm not for stretching but if that's what you want
instagram @Tylub
The Following User Says Thank You to Tylub For This Useful Post:
Old 02-05-2013, 02:05 PM   #7
tintumz22
tintumz22's Avatar
I already got my wheels. (managed to get a hold of a set of ADVAN RSII...So sticking to that staggered sizes. Now just to find for the proper tires. I'm just lowered w/ a 1" springs adding to the info. But yeah.. I'll keep those point in mind.
Old 02-05-2013, 02:10 PM   #8
Tylub
Tylub's Avatar
good choice!
just be careful with stretch because too aggressive and it can become dangerous. just look up tire stretch fail lol
oh 1 last thing, try to keep the rolling diameter about the same. i.e, 40 sidewall in the front and a 35 sidewall in the rears since you have 18s
instagram @Tylub
Old 02-05-2013, 02:14 PM   #9
#87
I usually post drunk
#87's Avatar
I have 235 255 all seasons and you can slide it, in fact its prob less grip than stock. Its all about the compound.
#87 is offline   Reply With Quote
The Following User Says Thank You to #87 For This Useful Post:
Old 02-05-2013, 02:20 PM   #10
tintumz22
tintumz22's Avatar
good choice!
Thanks! I know. Just want to get a feedback w/ the setup I want to do but I'll keep those points in mind so that I can make the proper decision when I get there.
Old 02-05-2013, 02:25 PM   #11
Tylub
Tylub's Avatar
yeah compound is important too left that out thanks 87
instagram @Tylub
Old 02-05-2013, 03:16 PM   #12
tintumz22
tintumz22's Avatar
Is 245/40 in the rear will be okay
Old 02-05-2013, 06:19 PM   #13
Tylub
Tylub's Avatar
http://www.tacomaworld.com/forum/tir...5r17-245-40r18
here's the calculator for you. If you don't mind being off by about 3mph going 65 then you can do it
then again, you could always get your speedometer sensor calibrated again lol
instagram @Tylub
Old 02-05-2013, 07:11 PM   #14
tintumz22
tintumz22's Avatar
What do you mean off by mph in my speedo? I'll be slower than the speedo? So what can you suggest w/o anything being recalibrated?
Functional front fender vents JohnATL Cosmetic Modification (Interior/Exterior/Lighting) 10 01-25-2013 12:58 PM
Functional and Simple Plate Covers Wesley Cosmetic Modification (Interior/Exterior/Lighting) 2 01-13-2013 09:51 PM
Winter Wheel/Tire Combo... Wes B. Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 09-10-2012 09:33 AM
86 Knee Pads Functional? wootwoot Cosmetic Modification (Interior/Exterior/Lighting) 13 08-12-2012 12:32 PM
