Old 01-23-2013, 03:09 PM   #113
Yruyur
Yruyur's Avatar
Originally Posted by jpit View Post
I'm not interested in spending that much either. However, how were they able to get oil temp thru the OBD ll connection?
They figured out the pid like we are teying to.
Old 01-27-2013, 02:59 AM   #114
TyperRspec789
Version 2 Coming Soon...
TyperRspec789's Avatar
Drives: Turbo Argento FRS, Asphalt FRS
I'm trying to determine if the torque app with a tab is a true solution for monitoring AFR and boost. Me and Pure Automotive are in the process of completing the Full Blown turbo build. Does the torque app work on cars that have been tuned by Ecutek, more specifically monitor Boost (psi) and AFR?
TyperRspec789 is offline   Reply With Quote
Old 01-27-2013, 03:03 AM   #115
Yruyur
Yruyur's Avatar
Yes. I have three tunes and reads specs just fine
Old 01-27-2013, 03:40 AM   #116
TyperRspec789
Do you believe that the ECU actually monitors boost accurately? What's the delay time like?
Old 01-27-2013, 12:12 PM   #117
Yruyur
Yruyur's Avatar
As far as I know its accurate. There is a delay. I can get a video for you when I get my car back this week.
Old 01-28-2013, 03:47 AM   #118
Gardus@Supersprint
Drives: Clio TCE
Wait, the stock ECU has a built in turbo management?
Gardus@Supersprint is offline   Reply With Quote
Old 01-28-2013, 08:59 AM   #119
Yruyur
Yruyur's Avatar
Vacuum and boost are on the same scale. Its normal. One is the negative value and one is the positive.
Old 01-28-2013, 09:26 AM   #120
ML
ML's Avatar
Drives: 13 White MT FR-S
I wish I could have more faith in this...
Old 01-28-2013, 09:14 PM   #121
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
I've tested the Boost and AFR gauges for accuracy in my brothers EVO X in comparison with his in car gauges, the readings I was getting on my tablet matched perfectly his in car gauges, as far as delay is concerned, the delay is fairly minimal, if you're not doing some extreme racing, the torque app would be perfectly fine and reliable.
Brody
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 01-29-2013, 11:22 PM   #122
ML
ML's Avatar
You did see where it said 184hp and 194tq right? I doubt it especially @ 5000rpm
Old 02-03-2013, 08:24 PM   #123
andreyiv
Drives: Hot Lava FR-S
Torque Oil Temperature PID
Hey guys,
I found the Oil Temperature PID using TorqueScan and verified it by driving, as well as heating up only the oil temperature sensor area with the engine cold (and not running).
Without further delay, here's the info:
OBD2 Mode and PID: 2101
Minimum Value: -40
Maximum Value: 215 (this is just the maximum that this location can support, which does not mean the sensor can read that high)
Scale factor: x1
Unit type: C
Equation: AC-40 (no space between A and C; "AC" is the location within the response)
OBD Header: 7E0 (Auto also works, but seems to take longer)
Just as an aside, I don't know if it's my OBD adapter, or the Header needs to be tweaked (corrected), or if the response is not always long enough but every once in a while I'll get a reading of 189 or 1840 which are both incorrect. I'm not familiar enough with torque to figure out where these glitches are coming from.
Edit: The incorrect readings of 189 and 1840 I was getting were caused by a faulty OBD adapter. Just received another one and have no problems.
Enjoy!
Andrey
andreyiv is offline   Reply With Quote
The Following 49 Users Say Thank You to andreyiv For This Useful Post:
2forme (02-03-2013), 3essess (12-11-2013), 86drift (02-04-2013), @Art_Mighty (06-22-2015), Area86 (02-03-2013), B L U E S L A T E (11-05-2013), Brody602 (02-04-2013), cobrabyte (03-13-2013), CxG (01-12-2017), d1ck (02-03-2013), dasting (10-28-2020), developer (02-17-2013), Draco-REX (04-22-2014), ft_sjo (02-04-2013), garfull (09-16-2013), Guillaume (02-04-2013), IBill4You (06-06-2015), jsooke (08-21-2014), jwoodland (08-20-2014), keelerad (02-06-2013), keen as (02-06-2013), Laika (02-03-2013), lazyluka (02-04-2013), LeeMaster (02-03-2013), melon (02-16-2014), michaelxchristopher (07-04-2018), ML (02-07-2013), Ninjin (02-03-2013), nix (02-08-2013), nzer (02-04-2013), orthojoe (02-03-2013), Pete (02-06-2013), pheoxs (02-04-2013), PineappleFriedRice (11-22-2013), pixel67 (02-03-2013), pkny (02-05-2013), Pug (02-04-2013), RJ_ (02-06-2013), Sarlacc (11-30-2013), Sideways? (02-04-2013), t0dd (02-04-2013), The Slow One (02-04-2013), ultra (12-17-2013), whataboutbob (01-01-2020), ybotspawn (06-30-2014), Yobiwan (02-04-2013), Yruyur (02-03-2013), zoomzoomers (04-09-2013), zoth (06-03-2014)
Old 02-03-2013, 08:34 PM   #124
Yruyur
Yruyur's Avatar
Originally Posted by andreyiv View Post
Hey guys,
Minimum Value: -40
Scale factor: x1
Unit type: C
Enjoy!
Andrey
You are the man!!
Old 02-03-2013, 10:05 PM   #125
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Minimum Value: -40
Scale factor: x1
Unit type: C
Please forgive the noob question but what do I do with this information?
I have the Mini ELM327 V1.5, I have TorquePro.
Thanks
Old 02-03-2013, 10:19 PM   #126
Ninjin
Ninjin's Avatar
Drives: SWP BRZ 6MT
Open the Torque app and then hit the menu button. Select "Manage extra PIDs/Sensors" (should be second from the bottom).
Hit the menu key again and select "Add custom PID". Enter the information provided by @andreyiv (And a full and short name of your choice).
Hit ok. The oil temp parameter will now be available for logging and real time display.
The Following 5 Users Say Thank You to Ninjin For This Useful Post:
Captain Snooze (02-03-2013), CxG (01-12-2017), keelerad (02-06-2013), Sportsguy83 (02-03-2013), zoomzoomers (04-09-2013)
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 05:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-23-2012 12:05 AM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 05:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 02:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 09:23 PM
