Old 02-03-2013, 06:20 PM   #15
Dang Lad
Dang Lad's Avatar
Drives: Asphalt MT FR-S
Yes, they did the full service and this re-alignment were cost free and covered under the regular Scion Service (that comes without any additional cost), so everything was free of charge. I don't think they were jerking me around, probably just unfamiliar with the car itself compared to the usual sedans/SUVs they service. Thanks for the suggestions all, as at this point sounds like nothing to worry about.
Dang Lad is offline   Reply With Quote
Old 02-03-2013, 06:27 PM   #16
Robmilkshakes
Drives: '94 Miata R Package
No, it's not at all. A parking brake adjustment is very common place on practically the whole line of Toyotas as they tend to favor the parking brake inside the rear rotor design. They may have misspoke as brake alignment sounds ridiculous, but they just performed a standard parking brake adjustment.
Robmilkshakes is offline   Reply With Quote
Old 02-04-2013, 02:07 AM   #17
OrbitalEllipses
Drives: Attitude
Usually wouldn't the tension on the cable have to change for that to happen or the friction material on the parking brake shoes have to wear down? In a brand new car it doesn't seem like either would apply.
Old 02-04-2013, 11:47 AM   #18
Robmilkshakes
Usually over time, yes, those are usually why the parking brake goes out of adjustment. So my guess would be the vehicle was possibly driven while the parking brake was engaged or it was delivered out of spec. It happens, we'll occassionally see vehicles in for a service early in their life that need an adjustment.
Old 02-20-2013, 07:14 AM   #19
Rowdy86
Drives: Toyota 86GT
Hi guy's,
I'm new to the forum and just saw this thread. Both myself and a friend replaced our OEM brakes recently, one at 3k and the other at 1.5k. Both had uneven wear on the stock brake pads, and I mean dramatic. On the car that had done 3k half the pad had worn away at 1 end whilst the other had plenty of life left.
IMO it looks like a design flaw given the issue was visible on both vehicles which were delivered 4 weeks apart.
Suggest you keep an eye on them just to be safe.
Cheers
Rowdy86 is offline   Reply With Quote
Old 02-20-2013, 09:30 AM   #20
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by Rowdy86 View Post
Hi guy's,
Cheers
Sounds like stuck pistons on the calipers, these are dual piston fronts.
Old 02-20-2013, 09:41 AM   #21
Orthow
Drives: 99' SIR Kswapped Racer/Showcar
Originally Posted by wbradley View Post
Or it's a troll.....?
STFU.. google what "trolling" is. This forum claims everything as trolling yet most the old people throwing the term around have no clue how to use it properly. Starting to get annoying to say the least. Stop trying to get E-cred by dropping the troll bomb - it's a fail.
To the OP. It's easy for an e-brake to be out of alignment - it's not a huge issue but will destroy one set of your pads faster than the other side. It's not the use of your e-brake that is doing anything what is happening is your e-brake is constantly putting tension on the calliper thus engaging the calliper on to the rotor while you are driving. That is where the wear is coming from. This is a common issue amongst all disc brake cars so don't be too concerned.
Orthow is offline   Reply With Quote
The Following User Says Thank You to Orthow For This Useful Post:
Subie (02-20-2013)
Old 02-20-2013, 12:36 PM   #22
wbradley
Sarcastic SOB
wbradley's Avatar
In [ame="http://en.wikipedia.org/wiki/Internet_slang"]Internet slang - Wikipedia, the free encyclopedia[/ame], a troll (pron.: [ame="http://en.wikipedia.org/wiki/Help:IPA_for_English"]Help:IPA for English - Wikipedia, the free encyclopedia[/ame]) is someone who posts inflammatory,[1] extraneous, or off topic messages in an online community, such as a forum, chat room, or blog, with the primary intent of provoking readers into an [ame="http://en.wikipedia.org/wiki/Emotion"]Emotion - Wikipedia, the free encyclopedia[/ame] response[2] or of otherwise disrupting normal on-topic discussion.[3] The noun troll may also refer to the provocative message itself, as in: "That was an excellent troll you posted."
OP *might* have been a troll. You are rude, and I am finished with you.
SOME trolling is funny.
Old 02-20-2013, 12:43 PM   #23
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
Well... that escalated quickly.
Ranatsu is offline   Reply With Quote
The Following User Says Thank You to Ranatsu For This Useful Post:
Anthonytpt (02-20-2013)
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 11:20 PM
Reported idle-drop and crickets - got turned away empower-auto Issues | Warranty | Recalls / TSB 11 10-21-2012 12:36 PM
First Reported Toyota 86 Crash in South Africa PREDATOR786 Scion FR-S / Toyota 86 GT86 General Forum 20 09-20-2012 08:50 AM
gas mileage: actual vs reported... FRSowner Scion FR-S / Toyota 86 GT86 General Forum 21 09-04-2012 01:24 AM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 11:28 AM
