Drives: Asphalt MT FR-S
Brake Alignment Reported Off
So I just got my car serviced at 5500 miles by the Toyota Dealership. They called and mentioned the rear brake alignment was "way off" and they had to re-align them. They said they don't know how/when it would have happened and didn't really have any suggestions for how to avoid it in the future.
Has anyone else had this reported? I use my FRS as my DD, and have taken it on a few short road trips, but nothing exceptional (had it since mid-May 2012). The dealer did fix it under warranty free-of-charge, but I'm concerned that they don't know how r why it happened, and I have yet to see a thread on this here. Anyone have any thoughts on this? |
Drives: '13FR-S Ultramarine 6MT
I'm no mechanic, but I've never even heard the term brake alignment before. Not sure what this means.
| The Following User Says Thank You to Fever For This Useful Post: | Mo707 (02-03-2013) |
Drives: SOLD...
yeah.. brakes don't get out of alignment...
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018 and its gone... Sept '18 tho I am sure I will miss it Replaced with 18 50th edition ND ![]() |
Sarcastic SOB
Probably rear wheel alignment.
I hadn't heard the term before either, glad I'm not the only one. I called the supervisor this morning and he said that the notes were incorrect the e-brake alignment was off - they said the friction point wasn't matching up.
Now the question is - does that make any more sense, and has anyone else had this issue? I'm definitely not using my e-brake for anything aside from parking (not using when drifting, etc.) so it shouldn't be due to not using it as intended. |
Re-member
Drives: Toyota camry
Perhaps he means there was too much or to little slack in the parking brake cable?
Nothing decays like progress, and nothing preserves like neglect.
| The Following User Says Thank You to ahausheer For This Useful Post: | Mo707 (02-03-2013) |
Drives: SOLD...
I'm no tech, but I could understand if when e-brake is applied one side engages before the other... Though I don't have a clue how it works on disc brakes in the drum brakes of the past that could easily happen if one adjuster had seized or soemthing.
I'm not 100% but I think the ebrake on these cars activate a small drum brake mechanism located in the hat of the rear discs rotors. They're on both sides, so one side could (for whatever reason) be out of alignment (of engagement) from the other.
Doesn't sound serious to me. That stuff would be adjustable. |
#10 |
Drives: LS Swapped BRZ
Sounds like the dealer was slow and wanted to make something out of nothing... I would go in and ask exactly what was adjusted, and have them show you the specification of how it was "out of alignment" and how far it had to be adjusted.
Now if this car had drums brakes that used them for actual braking, then once a year or so they should be cleaned and lubed and adjusted, but when your only using ebrake they so rarely need to be adjusted... |
#11 | ||
Drives: 2013 BRZ Ltd. MT
Well, I related your tale to my wife, and her face contorted into a weird shape and a strangled “WhaaaAAT?!” escaped her lips. “He’s making that up!” she exclaimed. “Or, he misunderstood.”
She's listened to a lot of NPR's "Click & Clack, The Tappett Brothers," over the years. Quote:
Perhaps it’s a “probe.” They’re testing you to determine how ignorant and gullible you are as they “prep” you for future service visits where they WILL charge you … and CHEAT YOU. Rear brake alignment … and “way off,” no less, huh? How’d they spot it in the first place? And just how far off was it? Exactly. Measured in degrees, millimeters, or kilograms? Quote:
#12 |
Sarcastic SOB
Or it's a troll.....?
#13 |
Drives: FR-S MT
Could they mean that the rotors are out of round?
#14 |
Drives: '94 Miata R Package
For most services, even just basic oil changes, the tech will inspect the safety components of the car, and it's a regular service recommended at Toyota dealers. The purpose is to adjust the parking brake shoes in relation to the drum surface. It may have come misaligned from the factory or if the parking brake was left on while the car was in motion can have an effect on the parking brake's adjustment. It's not a big deal.
| The Following User Says Thank You to Robmilkshakes For This Useful Post: | Dang Lad (02-03-2013) |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 10:20 PM |
| Reported idle-drop and crickets - got turned away | empower-auto | Issues | Warranty | Recalls / TSB | 11 | 10-21-2012 11:36 AM |
| First Reported Toyota 86 Crash in South Africa | PREDATOR786 | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 09-20-2012 07:50 AM |
| gas mileage: actual vs reported... | FRSowner | Scion FR-S / Toyota 86 GT86 General Forum | 21 | 09-04-2012 12:24 AM |
| Secondary Rear Brake Caliper for drifting or parking brake?? (pics) | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-25-2010 10:28 AM |
