#15 |
Drives: Asphalt MT FR-S
Yes, they did the full service and this re-alignment were cost free and covered under the regular Scion Service (that comes without any additional cost), so everything was free of charge. I don't think they were jerking me around, probably just unfamiliar with the car itself compared to the usual sedans/SUVs they service. Thanks for the suggestions all, as at this point sounds like nothing to worry about.
#16 |
Drives: '94 Miata R Package
No, it's not at all. A parking brake adjustment is very common place on practically the whole line of Toyotas as they tend to favor the parking brake inside the rear rotor design. They may have misspoke as brake alignment sounds ridiculous, but they just performed a standard parking brake adjustment.
#17 | |
Drives: Attitude
#18 |
Usually over time, yes, those are usually why the parking brake goes out of adjustment. So my guess would be the vehicle was possibly driven while the parking brake was engaged or it was delivered out of spec. It happens, we'll occassionally see vehicles in for a service early in their life that need an adjustment.
#19 |
Drives: Toyota 86GT
Hi guy's,
I'm new to the forum and just saw this thread. Both myself and a friend replaced our OEM brakes recently, one at 3k and the other at 1.5k. Both had uneven wear on the stock brake pads, and I mean dramatic. On the car that had done 3k half the pad had worn away at 1 end whilst the other had plenty of life left. IMO it looks like a design flaw given the issue was visible on both vehicles which were delivered 4 weeks apart. Suggest you keep an eye on them just to be safe. Cheers |
#20 | |
Drives: 2013 Asphalt FR-S
~Namaste~ |
#21 |
Drives: 99' SIR Kswapped Racer/Showcar
STFU.. google what "trolling" is. This forum claims everything as trolling yet most the old people throwing the term around have no clue how to use it properly. Starting to get annoying to say the least. Stop trying to get E-cred by dropping the troll bomb - it's a fail.
![]() To the OP. It's easy for an e-brake to be out of alignment - it's not a huge issue but will destroy one set of your pads faster than the other side. It's not the use of your e-brake that is doing anything what is happening is your e-brake is constantly putting tension on the calliper thus engaging the calliper on to the rotor while you are driving. That is where the wear is coming from. This is a common issue amongst all disc brake cars so don't be too concerned. |
| The Following User Says Thank You to Orthow For This Useful Post: | Subie (02-20-2013) |
#22 | |
Sarcastic SOB
OP *might* have been a troll. You are rude, and I am finished with you. SOME trolling is funny.
#23 | |
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
| The Following User Says Thank You to Ranatsu For This Useful Post: | Anthonytpt (02-20-2013) |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 10:20 PM |
| Reported idle-drop and crickets - got turned away | empower-auto | Issues | Warranty | Recalls / TSB | 11 | 10-21-2012 11:36 AM |
| First Reported Toyota 86 Crash in South Africa | PREDATOR786 | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 09-20-2012 07:50 AM |
| gas mileage: actual vs reported... | FRSowner | Scion FR-S / Toyota 86 GT86 General Forum | 21 | 09-04-2012 12:24 AM |
| Secondary Rear Brake Caliper for drifting or parking brake?? (pics) | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-25-2010 10:28 AM |
