Old 01-31-2013, 10:18 PM   #1
stealth_fighter
Drives: FA20Club ELH&CAI, MT,Tinted, Raven
dyno numbers seem low
Hey guys, i just went to the dyno today and my numbers seemed odd. 132HP @ 6400, 127ft-lb TQ @ 2500 & 4500 rpm. It was a Mustang Dyno. No clue what the AFR was. Could the winter grade fuel be the issue? The outside temp was around 8deg.
stealth_fighter is offline   Reply With Quote
Old 01-31-2013, 10:31 PM   #2
Jlin
Drives: FRS
if anything you should be making more power during colder temps.
Jlin is offline   Reply With Quote
Old 01-31-2013, 10:34 PM   #3
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
Some mustangs read low...i wouldn't worry.
Jesse@JDLAutodesign is offline   Reply With Quote
The Following 2 Users Say Thank You to Jesse@JDLAutodesign For This Useful Post:
Freeman (01-31-2013), stealth_fighter (02-01-2013)
Old 02-02-2013, 07:48 PM   #4
kilrb
Drives: '13 Black BRZ
Mustang dyno's usually do read lower than Dynojets. From my LS1 Vette days, I remember cars getting 20 or 30whp less on a 400whp car. Don't know if its proportional or not, but I wouldn't be surprised to see that number on a Mustang dyno.
kilrb is offline   Reply With Quote
Old 02-02-2013, 08:28 PM   #5
fistpoint
Drives: Supercharged Golf Cart
Just curious as I know nothing of these things...but if this Mustang system is known for giving low numbers, doesn't that equate to the system being basically worthless?
What would be the point of having a system designed to measure HP that always measures lower than it really is? It's like using a broken thermometer to check your temperature.
fistpoint is offline   Reply With Quote
Old 02-02-2013, 08:38 PM   #6
AVOturboworld
It's basically worthless if you want to have numbers to brag about, yes.
But that's not the purpose of a dyno. It's a measuring stick to see if your tuning is doing something or not. It doesn't matter if the baseline is 120 or 180, the idea is to measure the gain from that baseline.
Old 02-02-2013, 08:47 PM   #7
kilrb
I have always ascribed to the view that the number is meaningless in and of itself. In my opinion (and others much more valuable than mine), dyno's are useful as a tool when you get a baseline on one machine, then modify, then return to the same dyno for another run. Even two different Dynojets will get different results. And then there are the shops who adjust their atmospheric corrections to get higher numbers to make customers happy. My $0.02 worth is don't worry about the number itself, but the changes as you mod the car...
Old 02-02-2013, 08:48 PM   #8
mact
Drives: 13 GTI
You were at Performance 2ning outside of Dubuque right? I want to get my car dyno'd there sometime. It'd be interesting to compare numbers.
mact is offline   Reply With Quote
Old 02-02-2013, 08:54 PM   #9
DarkCard
Drives: Asphalt Scion Frs 6MT
Mustang Dynos are called "Heartbreakers" for a reason. They're low reading dynos.
DarkCard is offline   Reply With Quote
Old 02-02-2013, 09:01 PM   #10
stealth_fighter
I was indeed. My first impression is i like the shop. The guys are pretty knowledgeable and the pricing is on par with what i expected. I would recommend then and will be going back one i get me intake and tune so i can fine tune it.
Stock FR-S/BRZ shock dyno & stock FR-S spring dyno xwd Tracking / Autocross / HPDE / Drifting 16 08-07-2014 09:04 PM
dyno numbers based on break in procedure. EZWood Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 06-09-2013 08:32 PM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
Base line dyno figure (dynapak Hub dyno) gtauto AUSTRALIA 16 10-08-2012 08:06 AM
Part numbers 20valvewynn83 Cosmetic Modification (Interior/Exterior/Lighting) 1 07-24-2012 06:16 AM
