#15 | |
I like to eat!
Thanks. Were you able to get the car started and drive it to the dealership? My steering wheel was physically unlocked but the car would still not start. Wonder if a sensor or relay is sticking. |
#16 |
Drives: Fr-s 2013 white out
That happened to me a few days ago it took 2 turns to start the first time was long and i was like why is it not starting *-*
#17 |
Ontario's FT86
Drives: 2016 Lexus GS-F
#18 |
Yeah i think it happened to me twice since i got my car... i hope it's just because of the temp? But oddly enough it was on tuesday where the weather was really warm...only rainy... so i dont know what it is that is causing it...
#19 |
I like to eat!
Do you guys have keyless FRS'? I didn't think they made such a thing. It's not a starter or engine issue. It's definitely electronic.
#20 | |
I Love custom Turbo kits
Drives: Limited BRZ
Pete, I believe when the keyfob is not recognized, you need to actually rest the keyfob in contact with the pushbutton, then push the button in.
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | Guff (04-03-2013) |
#21 |
Drives: SWP BRZ
^ This
same procedure when key fob battery goes out In fact you need to rest the back of the key fob (where the engraved subaru logo is) against the push star button |
#22 |
Drives: 2016 STI DGM
I didn't see this when reading through but did you try to start the car with your other fob?
Subaru STI :![]() |
#23 |
Gettin SIKKY sideways
There's a thing in the manual that stated the fobs go into a "sleep mode" after so long of not being used, to preserve the battery. Did you press any buttons on it before it finally started? Hopefully it's an easy solution of the fob needed waking up for the car to see it.
Beyond that, yup. Get it as close to a sensor as possible |
#24 |
Drives: SWP BRZ
i like style of insert key in and turn.
| The Following 2 Users Say Thank You to zc06_kisstherain For This Useful Post: | sho220 (02-02-2013), strat61caster (02-01-2013) |
#25 | |
Drives: 2013 Subaru BRZ
#26 |
I like to eat!
Good suggestions all. Thank you VERY much.
I just can't figure out why it took half an hour then finally started the car. Yes I touched the fob to the start switch as the manual states. Everything worked BUT the starter. The wheel was unlocked. I could still switch to ACC, ON, and OFF. Very wierd stuff. I didn't have the other fob with me at the time or would have tried it. |
| The Following User Says Thank You to Pete156 For This Useful Post: | Sportsguy83 (02-01-2013) |
#27 |
Drives: CBS BRZ Limited
My BRZ was towed to the dealer unfortunately.
#28 |
Sounds like you're having an issue with your key fob. I guess you already had your car towed to the dealership, but should this happen again try changing out the battery in your key fob. This happened to me before with my old car and I, for the life of me, couldn't figure out the issue. Then the tech at the dealership charges my key fob and poof! Like a charm. Sometimes the solutions are easy, we just don't see it. Either way good luck!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam. |
| Push Start Rough Engine Start Up | joergasm | Engine, Exhaust, Transmission | 3 | 12-12-2012 03:44 AM |
| Uncommanded Start | brbrz | Issues | Warranty | Recalls / TSB | 15 | 11-30-2012 01:06 AM |
| FS [SYD]: TRD Start Button | eleu2166 | Australia Classifieds | 3 | 11-04-2012 06:31 AM |
| Car Won't Start | schtebie | Issues | Warranty | Recalls / TSB | 25 | 10-15-2012 04:06 PM |
| Honey, do...? (start over now) | ToxicSneakers | Off-Topic Lounge [WARNING: NO POLITICS] | 0 | 06-14-2012 05:01 PM |
