Old 11-27-2012, 08:31 PM   #1
brbrz
Drives: 2013 BRZ Limited DGM
Uncommanded Start
While putting the car away in my garage I had is restart on me.
Here's what happened.
  • drive into the garage
  • clutch in
  • press the start/stop button
  • engine stops
  • move the shifter to neutral
  • begin to set parking brake ( hand is on the parking break )
  • engine starts ( hand is still on the parking break )
  • WTF
anyone else had anything like this happen?
Also after I stop the engine the car starts beeping ( not a continious tone, just beeping ). I restart the engine ( pushing the start/stop button ) and then stop it again and everything appears normal.
Vehicle has just over 4K miles.
brbrz is offline   Reply With Quote
Old 11-28-2012, 03:29 AM   #2
Moshpit37
FR-S Owner!
Moshpit37's Avatar
Drives: 2013 FR-S Ultramarine 6AT
No answer here, but since you mention push-start, I'm assuming this is in a BRZ, and not the Sentra you have listed in your info? Need to update your ride, bro!
Frances - 2013 Scion FR-S in Ultramarine
Owner's Journal
Moshpit37 is offline   Reply With Quote
Old 11-28-2012, 10:50 AM   #3
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
Well the beeping when the car is off is normal. It does that when the key is inside the car and the car is off.. Its a warning to keep you from locking your key in the car. If you get a solid high pitched tone, its because you have the lights turned on and the car off.
I don't know why the car would start.. thats just random.
Ranatsu is offline   Reply With Quote
Old 11-28-2012, 12:13 PM   #4
Dezoris
Dezoris's Avatar
Put in neutral and pull parking brake before killing engine.
Old 11-28-2012, 12:23 PM   #5
JDMenrique
DEEEERP
JDMenrique's Avatar
cant help since i dont have P2S, but it does sound weird.
JDMenrique is offline   Reply With Quote
Old 11-28-2012, 12:58 PM   #6
xjohnx
Grip>Slip
xjohnx's Avatar
I've found that if i shut the car off, then put it in gear before opening the door, you don't get the beeping. You'll know you did it right if you hear the steering wheel lock engage as you pull the handle on your door.
Old 11-28-2012, 05:43 PM   #7
brbrz
Doh!
Old 11-28-2012, 05:46 PM   #8
brbrz
Yea, I always leave the car in gear so that's probably why the beeping seemed unusual. Also the beeping was while the door was closed.
Old 11-28-2012, 05:51 PM   #9
Jayde
Jayde's Avatar
I've noticed in the 6 months I've had mine is that the only time it'll beep when I shut the engine off (or if the car was just in "on") and the door is open. Hasn't beeped when the door is closed.
However, the engine starting randomly is weird. See if you can reproduce it somehow by following those steps.
Jayde is offline   Reply With Quote
Old 11-28-2012, 11:26 PM   #10
ryanmatic
Pichu
ryanmatic's Avatar
Drives: 2017 Series.Yellow
Me too. I vaguely recall the manual actually saying to leave it in neutral when it's off, which sounds like a bad idea to me.
ryanmatic is offline   Reply With Quote
Old 11-29-2012, 11:03 AM   #11
xjohnx
Grip>Slip
xjohnx's Avatar
Old 11-29-2012, 12:18 PM   #12
Razz
Razz's Avatar
Drives: Fast
That is a bad idea to leave it in neutral.
On the auto start, something in your pocket push the start button on the remote?
Razz is offline   Reply With Quote
Old 11-29-2012, 12:49 PM   #13
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Leaving your car in neutral is a bad idea? Since when?
Now if it is on unleveled ground obviously putting it in gear is a smart backup plan.
chulooz is offline   Reply With Quote
Old 11-29-2012, 10:24 PM   #14
brbrz
AFAIK there is no way to start the car with the remote.
I haven't had it happen again, hoping this is a one time glitch.
Hard start ?? Rayme Issues | Warranty | Recalls / TSB 44 03-28-2015 08:51 AM
FS [SYD]: TRD Start Button eleu2166 Australia Classifieds 3 11-04-2012 06:31 AM
Car Won't Start schtebie Issues | Warranty | Recalls / TSB 25 10-15-2012 04:06 PM
Start them off young phenom86 Off-Topic Lounge [WARNING: NO POLITICS] 10 08-12-2012 03:41 PM
push to start pa2gamer02 BRZ First-Gen (2012+) — General Topics 6 03-17-2012 01:01 PM
