Old 01-29-2013, 04:55 PM   #113
xjohnx
Grip>Slip
xjohnx's Avatar
Judging by the 22 gauge power wire on the 1150 I think I'll be safe. I'll know in about an hour or two. Thankfully i ordered the oem power cable pin with my original order from svxdc
Old 01-29-2013, 05:49 PM   #114
Foobar
SLO NO MO
Foobar's Avatar
Originally Posted by SVXdc View Post
Anyone who ordered my camera RCA cable or harness without the power lead, let me know and I can send you just that extra wire.
Thanks David - I'll shoot you an e-mail!
Old 01-29-2013, 05:57 PM   #115
xjohnx
Grip>Slip
xjohnx's Avatar
Just confirmed the 1150 works on oem 6v supply. No lines from the camera, only the head unit lines. Now to wire it up permanently tomorrow. Ran out of daylight and spent 45 minutes thinking it wasn't working because I forgot to connect the 16 pin harness back into the head unit. Doh!!
tripjammer (02-25-2013)
Old 02-13-2013, 04:32 PM   #116
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
i just ordered the rydeen duo to replace what i have now. i'll update with photo's later.
Jive Turkey is offline   Reply With Quote
Old 02-15-2013, 04:16 PM   #117
Mpowered
Drives: BR-Z
I've never wired anything into a HU before. How exactly do you fish the wire behind there?
Mpowered is offline   Reply With Quote
Old 02-23-2013, 10:38 PM   #118
Tony Mac
Tony Mac's Avatar
Drives: SWP BRZ
On the Rydeen Duo, does anyone know if I need to connect that reversing wire to the reverse lamp?
Tony Mac is offline   Reply With Quote
Old 02-23-2013, 11:39 PM   #119
xwd
That is the power wire. It won't work connected to the reverse lights because the head unit needs to detect the camera when the car is turned on. You can wire it to an ignition switched source like the green amp wire or if you are using the newer svxdc harness I believe he has a pin/wire to power the camera from the head unit's camera power output. So you would connect that to the power wire.
Old 02-24-2013, 12:16 AM   #120
Tony Mac
Tony Mac's Avatar
Drives: SWP BRZ
I have his newer harness with a power wire. I'm assuming I can connect the "Reverse power anode output" wire to the harness and ignore the "To reverse light power +" wire?
The "To reverse light power +" wire is much shorter and looks like it wasn't meant to be run to the head unit.
Old 02-24-2013, 12:38 AM   #121
xwd
Yes but make sure you tape up the end of the power wire near the camera.
The Following User Says Thank You to xwd For This Useful Post:
Tony Mac (02-24-2013)
Old 02-24-2013, 01:09 AM   #122
xjohnx
Grip>Slip
xjohnx's Avatar
that will work if you're using an aftermarket head unit but not with the stock unit.
with the stock head unit, if the car doesn't sense the camera as being powered on when the head unit boots up, it won't work. Thus, wire it to accessory power, or to the head unit itself. Wiring it to reverse light power will prove problematic, unless you shift into reverse before you start each time.
Old 02-24-2013, 02:51 AM   #123
Tony Mac
Tony Mac's Avatar
Drives: SWP BRZ
Thanks, good to know I don't need to run an extra wire!
Power will come from the head unit so this shouldn't be a problem.
Old 02-24-2013, 06:18 AM   #124
Foobar
SLO NO MO
Foobar's Avatar
Anyone who ordered my camera RCA cable or harness without the power lead, let me know (via e-mail) and I can send you just that extra wire.
Anyone get theirs yet? I can't get a response from svxdc via e-mail.
Sent from my Nexus 4 using Tapatalk 2
Old 02-24-2013, 05:30 PM   #125
kludger
kludger's Avatar
Drives: '13 Boxter S, '13 BRZ(gone)
Yeah same here I suspect he has been offline or out of town, no reply for a couple of weeks, hope all is good.
kludger is offline   Reply With Quote
Old 02-25-2013, 02:50 PM   #126
Jive Turkey
the tuna, no crust.
so the camera i had before i had to run a ground and power in the trunk(cheap $30 crap cam)...when i did this to this camera my reverse lights never turned off and the display indicated reverse on the dash...i had no idea what was going on. after reading turns out you dont need to wire it in the trunk with the stock headunit as stated above so i cut the wires and taped it off. so all i did was use the harness provided by SVDX and wired the red wire and RCA connector to the headunit and thats it. easy peasy.
here is the wire i soldered the tiny red wire into.
and this is where i installed the Rydeen duo.
with the color of my car the camera is barely noticeable. it is the perfect angle to see the bumper and the nightime visibility is exponentially better than the camera i used to have.
sorry for this cellphone shot:
before i had a camera mounted under the reverse/fog light, you can see it here:
it was some random 30$ camera that i bought because it was flush-mount and i thought i could fit it in the tow hook cover on the rear bumper by cutting a hole...but there is the metal bumper beam there so i couldn't mount it as i wanted. in all honesty if you want to do a back up camera, just spend the money on a good quality camera like the rydeen, because otherwise you'll get terrible quality. also when i mounted that camera i realized it still didn't give me a good distance judgement, with the rydeen i can see the back bumper so i can actually see how close i am to what ever is behind me, thats the maint reaon why i got a camera, to see how close i am. i dont really use it to back up or park, jsut to judge distance because i always back into parking spots.
The Following User Says Thank You to Jive Turkey For This Useful Post:
DGM BRZ limited on the way? Coheed Member's Car Journals 16 04-11-2013 02:09 AM
My LR BRZ Limited epson1 BRZ Photos, Videos, Wallpapers, Gallery Forum 11 09-08-2012 02:18 PM
BRZ Limited Available JohnATL Southeast 3 08-12-2012 11:32 AM
Want to buy a BRZ Limited AT kgc Northwest 1 06-16-2012 11:45 PM
DGM BRZ Limited (man) available Mitchs_86 BRZ First-Gen (2012+) — General Topics 6 06-14-2012 12:50 PM
