Old 01-28-2013, 10:20 AM   #57
jarviz
jarviz's Avatar
Drives: Raven FRS MT
Or learn how to control the car when it fishtails or slides out when you're in the snow.
I think NYC is supposed to get snow today... again.
This will be the third time I'm driving in the snow without snow tires. I'll be chancing it this winter
jarviz is offline   Reply With Quote
Old 01-28-2013, 10:23 AM   #58
Doug&Julie
Boxer Fan
Doug&Julie's Avatar
Drives: 2013 Subaru BRZ
Originally Posted by Allch Chcar View Post
Try and find an expert that recommends all-seasons for winter as far North as Ohio.
Eg: http://www.popularmechanics.com/cars...andle-the-snow
Not arguing that either. My first post was simply in response to a poster who said "all season" tires doesn't include winter. Perhaps I should have just ignored it...
We all know there are good and bad "all season" tires, and some that are better than others in winter and (most) that are better in summers and barely worth their rubber in winter.
But as to the simple point I'm trying to respond to...an all season tire is designed to work in all seasons, according to the manufacturer. How well it does...YMMV.
Doug
2012 Subaru Impreza 2.0i
1986 Porsche 911
Doug&Julie is offline   Reply With Quote
Old 01-28-2013, 10:56 AM   #59
Entroper
Entroper's Avatar
Drives: 2019 MX-5 RF GT-S, 2002 Miata LS
Originally Posted by chenshuo View Post
yes, there are about a million of these posts. yours just made the total count to be a million and one.
now to answer your question, winter tires is more dependent on the temperature, not just snow. if where you live is really cold then you need winter tires cause your summer tires will turn into circular bricks.
Your summer tires may lose substantial grip in the cold, but they will still be perfectly safe to drive on. But in snow, not so much.
@Efenys, I drove the FR-S in last week's snow on its stock Bridgestones. I wouldn't exactly recommend it, but it's doable if you know what you're doing and if you don't need to drive it on steep hills.
Entroper is offline   Reply With Quote
Old 01-28-2013, 11:07 AM   #60
Efenys
Drives: Galaxy Blue 6sp BRZ LTD
Would anyone actually recommend all seasons? I've read that not too long ago but would it make a difference that would be worth it?
Also does anyone actually recommend getting snow tires for a few days of snow and otherwise spotless roads the rest of the year? Are there any snow tires that would hold up well in these conditions? I've read some of these snow tires wear quickly on dry so thats why i ask.
Yes i know these questions have been out there, i've read a lot and appreciate the responses.
Efenys is offline   Reply With Quote
Old 01-28-2013, 12:22 PM   #61
A5D5TRYR
A5D5TRYR's Avatar
Drives: FR-S 6MT Ultramarine (BeeDrill)
I had all-seasons on for a bit cause I thought I might try that (Continental DWS) and it was fine except for traction to get going. Slight incline with a little snow and I was stuck. This is embarrassing and I didn't ever want to feel like I couldn't drive somewhere because of the weather so I ended up getting dedicated snows and put them on the OEM wheels. If you're not seeing a appreciable amount of snow at any time I would've been fine on the all-seasons. They seemed to control and brake fine they just couldn't get the traction to go.
2013 Scion FR-S - Ultramarine 6MT
A5D5TRYR is offline   Reply With Quote
Old 01-28-2013, 01:58 PM   #62
edward
edward's Avatar
Drives: 2013 BRZ - Sterling Silver Metallic
If the temperature is regularly below 45 degrees (Fahrenheit) you should be driving on winter/snow tires.
edward is offline   Reply With Quote
The Following User Says Thank You to edward For This Useful Post:
Jive Turkey (01-28-2013)
Old 01-28-2013, 02:35 PM   #63
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
all of you guys arguing about winter tires. you know there is more to the compound than just the ability to grip in snow right? its temperature related.
i can understand where some are coming from, you have on set of wheels and want one tire, in which case all seasons are okay. all seasons are jacks of all trades master of none.
while you think you're wasting money, in the long run you're changing tires less often because you have a compound that isn't wearing as much. initial costs are higher, but over all costs will level out as soon as you go to buy a second set of the all season tires...
i for one have a different set of rims/tire for summer and winter. in the summer i track the car, and to get the best out of your car, no all season will make due. period. in warm weather a dedicated summer tire will out handle any all season, and in the winter a winter tire will out handle an all sea on tire. some of you think that winters get warm out fast by driving them on the bare asphalt, wrong, these tires will not get worn out, especially fi you get a harder compound winter tire.
the way i see it, if you are truly using the car to it's full potential, no all season will do. once you've experience something with amazing grip like a start spec or a michelin PSS, you'll never not want to run them in the summer.
all of these posts are irrelevant, and uneducated. if you dont have first hand experience, please dont say that winter tires are useless. they aren't just made for snow...
with that said i have blizzaks on the, while they are soft, they are very predictable and i've had ZERO issues in the rain/snow/sleet so far. daily driving the car they are perfectly fine, if anything next time i'll go for a performance snow tire, instead of a studdless snow to get a little stiffer sidewall.
Jive Turkey is offline   Reply With Quote
Old 01-28-2013, 05:37 PM   #64
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
JIVETURKEY gobbles: "and in the winter a winter tire will out handle a winter tire".
I am confused. So much advice. I just lay up my BRZ for the winter.
BTW: When one says a SET of winter tires does one mean FOUR tires, front and ear, or just two tires?
Also, don't ask or tell me what, or how many tires to get. I have lived in southern Michigan and Northern Michigan all my life (that is until I move out to one of the Western states). But don't get me wrong I absolutely love reading the various comments.
BRZfan is offline   Reply With Quote
Old 01-28-2013, 06:27 PM   #65
Mobius357
Drives: '15 WRX '13 Legacy '07 Colorado
Always get a set for four tires, doing only 2 isn't safe, and will likely cause interesting, possibly unexpected handling characteristics.
Mobius357 is offline   Reply With Quote
Old 01-28-2013, 06:42 PM   #66
jmaryt
Drives: 2012 honda civic ex
Originally Posted by Enemies View Post
To each their own. I don't think any of us have an aversion to saving money. But with that said, I think there's definitely some places where it should be spent. I don't see any point in buying a $30,000 car if you can't spend a fraction more to keep it out of the ditch.
I unfortunately don't have the luxury to choose not to drive when the weather is bad so I went with (what I thought was) the safer route. I see we're not going to agree here though so... I'll drop it. Safe driving to everybody whether or not they are using winter tires or all-seasons.
I just hope nobody is driving their summers in sub-zero temperatures. Or sub-32F temperatures for you silly Americans... Just kidding!
car cost $25,000,and i have never driven off the road into a ditch in 45 years
with any car.where you live "snow tires" would be considered "mandatory" but NOT here,and NOT for me for the reasons previously stated.
jmaryt is offline   Reply With Quote
Old 01-28-2013, 06:44 PM   #67
jmaryt
Originally Posted by a2cpc View Post
You can get a set of General Articmax(sp) 215/65/16 for $400.
thanks for the tip! don't need,or want 'em! the (a.s.) on the car is sufficient! no worries! i'm off the road anyway when it snows! just sayin'
Old 01-28-2013, 06:52 PM   #68
tomt5078
tomt5078's Avatar
Can you now get up the same slight incline that you couldn't before?
tomt5078 is offline   Reply With Quote
Old 01-28-2013, 06:54 PM   #69
jmaryt
Originally Posted by Efenys View Post
I've read about a million of these posts. Each one followed by a post saying to get a good set of winter tires. This makes sense. But...
What should you do if you only get snow 3 or 4 times a year for a day but roads are clear the next day? It seems like a waste to get winter tires for 4 days of driving your car.
Is there any alternative? Any suggestions? Driving style changes?
/ :happy0180:
Thanks guys
forget snows,stay with (a.s.) slow down,and take your time, plan ahead,and brake gradually no worries.
Old 01-28-2013, 06:59 PM   #70
jmaryt
/ :happy0180:
Thanks guys
short answer is "NO!" you'll spend "tall" money on dedicated snows,and run 'em all winter on bare asphalt.will wear out quickly.to be honest under THOSE conditions,might as well put a "match" to your money,and watch it burn!..just sayin'
Having Fun in The Snow with FR-S Pavel NY / NJ / CT / PA 10 01-06-2013 06:32 PM
SNOW!!! Tanuki FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 65 01-01-2013 11:42 PM
BRZ vs. Snow? serith BRZ First-Gen (2012+) — General Topics 45 08-28-2012 07:26 PM
FRS/BRZ in the Snow smbrm Scion FR-S / Toyota 86 GT86 General Forum 38 03-23-2012 07:03 PM
BRZ in snow sieeegel BRZ First-Gen (2012+) — General Topics 40 02-22-2012 12:44 AM
