Northwest AK, ID, OR, WA
Old 01-26-2013, 03:07 PM   #365
stockysnail
Just the tip
stockysnail's Avatar
Bump so people don't forget
Old 01-26-2013, 08:17 PM   #366
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
Originally Posted by Kmurph View Post
Man looks good! Can't go wrong with Hyper black on white. Are those the G-Force Rota's....?
Yea 18x9 and 18x8.5 Hyper black rota g-force. 12mm spacers were needed on the front.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 01-27-2013, 01:31 AM   #367
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
@DarrenDriven - Did you purchase a press? The rear camber bushings install will require one to get it out and press in the new one. Although you may have some MacGyver style trick up your sleeve for this too . I'll stop in for a bit with my daughter but can't stay too long. Taking her to the movies without her brother or mother along.
digital_assassin is offline   Reply With Quote
Old 01-27-2013, 02:47 AM   #368
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
No press. Uh-oh.
Old 01-27-2013, 11:59 AM   #369
Biddys
Drives: AE86
bushings
how did it go?
Biddys is offline   Reply With Quote
Old 01-27-2013, 01:33 PM   #370
DarrenDriven
NW Region Moderator
Biddys!?!?! Is that you, Brian?
It hasn't gone yet... today is Sunday and it's still hours from 1pm.
Old 01-27-2013, 02:18 PM   #371
stockysnail
Just the tip
Guess we aren't doing the rear camber bushings then. Oh well. Lots of other bushings. Hopefully someone chimes in if they think we need a press for anything else.
Old 01-27-2013, 10:50 PM   #372
BRZPDX
Boosted Member
BRZPDX's Avatar
Big props to Darren again for the mancave sundays!!
Fender garnish plasti dip.. First time using this stuff.
Shit is harder than I thought!! Youtube guy does it so easily..
Old 01-27-2013, 11:06 PM   #373
DarrenDriven
NW Region Moderator
Good to meet @Pdxc43 (Sean) for the first time. Had some fun figuring out where @stockysnail's (Josh) bushings installed while @BRZPDX (Kohei) plastidipped his vents. @Kensurs (Kenneth) and @digital_assassin (Kevin) were here, too.
Old 01-27-2013, 11:22 PM   #374
whataboutbob
AutoX-10/10ths every run
I used a press when I installed these:
-Whiteline Front Control arm - lower inner front Anti-Dive / Caster Correction Kit KCA434
-Whiteline Front Control arm - lower inner rear bushing W0509
-Whiteline Front Steering - rack & pinion mount bushing KSR210
Build thread:Here
Old 01-27-2013, 11:48 PM   #375
Pdxc43
Had a good time! It's nice to put faces to other frs and brz in the area
Pdxc43 is offline   Reply With Quote
Old 01-28-2013, 12:32 AM   #376
digital_assassin
How far did you guys get on Josh's car today?
Old 01-28-2013, 01:03 AM   #377
m.box.design
m.box.design's Avatar
Drives: 2013 Whiteout FRS
Man i'm getting the urge to put together my own foglights via this thread
http://www.ft86club.com/forums/showthread.php?t=27366
Old 01-28-2013, 01:03 AM   #378
stockysnail
Just the tip
We were able to do:
-Pentosin 3 Liter; 75W-80 Trans Oil
-Whiteline KCA416 Front Camber adjusting bolt 16mm
-WhiteLine Rear Crossmember Mount Bushings KDT922 Positive Traction Kit
-Whiteline Gearbox Positive Shift Kit KDT926
-Whiteline Rear Sway Bar with bushings 16mm Adjustable BSR53Z
-Perrin Rear Shifter Bushing
-Perrin Poly Rear End Links
I did this the night before at my place. My bumper isn't exactly straight anymore but not noticeable unless you're looking for it or up really close.
-Perrin intake system and hose
All of these below seem to need a press which Darren doesn't have so I think I may need to take it to a shop unless someone on here has a press and would like to press them for me.
-Whiteline Rear Trailing arm - lower front bushing W63414
-Whiteline Rear Control arm - upper inner bushing (camber correction) KCA326
My front sway bar is coming tomorrow so I'll need to put that on soon as the car with only the rear sway bar is so tail happy it's a little scary!
SoCal: any local shop to install springs jgonx213 Southern California 12 12-16-2013 03:20 PM
Coilover and Springs Install at Performance Shop F-T Mechanical Maintenance and Tools 22 12-12-2013 02:12 PM
WTB RCE spring or RS*R spring mounted on stock strut jshum Want-To-Buy Requests 1 10-11-2013 03:47 PM
Need to find a shop in Chico area for spring install Senzai Northern California 1 08-08-2013 06:59 PM
Garage FR-S at home or pay a shop/someone else? ProTekk Scion FR-S / Toyota 86 GT86 General Forum 34 10-30-2012 01:17 PM
