Old 01-26-2013, 05:13 PM   #575
disgruntld
Less than pleased...
disgruntld's Avatar
Drives: '13 BRZ Ltd SSM 6MT
Originally Posted by sbxjap View Post
I even tried flipping it around a few dozen times to see if I just put it down wrong.
Definitely did this too. Spent like 15 minutes in determined disbelief. I'd rather consider myself too dumb to figure it out the first time than accept that it was wrong.
disgruntld is offline   Reply With Quote
Old 01-26-2013, 05:13 PM   #576
Foobar
SLO NO MO
Foobar's Avatar
Heh, yeah... me too Even watched the video again just to see if maybe the instructions were wrong and the video would show otherwise.
No such luck.
Old 01-26-2013, 05:13 PM   #577
13 FR-S Veteran
13 FR-S Veteran's Avatar
Drives: 2013 FR-S (Raven Black)
Suddenly I'm no longer saddened at being number 167. Get that problem sorted out before they ship mine.
Sent from the great white north via smoke signal.
13 FR-S Veteran is offline   Reply With Quote
Old 01-26-2013, 05:54 PM   #578
CJB
Drives: 2013 BRZ Premium MT
Just got home and saw I had a package...what a let down.
I also didn't get any instructions, just a piece of paper telling me to download the instructions from grimmspeed.com. Unfortunately, their website doesn't yet have a product page for these.
CJB is offline   Reply With Quote
Old 01-26-2013, 05:56 PM   #579
Foobar
SLO NO MO
Foobar's Avatar
Instructions are on the first post of this thread, both PDF and video. Since this is a pre-release group buy, you won't see it on their website yet. Unfortunately, they used the standard instructions note in the package which really only applies to their products that are available for general retail.
Old 01-26-2013, 06:01 PM   #580
CJB
Doh! Thanks, I've read this thread enough I should have known that!
Old 01-26-2013, 06:03 PM   #581
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by GrimmSpeed View Post
Dat hair!
Can everyone post up if you received two drivers or two passenger side mounts?
It might help to figure out what went wrong and it might bring to light the possibility of two guys meeting up to swap mounts if they live close enough to each other.
Old 01-26-2013, 06:12 PM   #582
CJB
I received two passenger side mounts.
Old 01-26-2013, 06:17 PM   #583
disgruntld
disgruntld's Avatar
Two passenger mounts here as well.
Old 01-26-2013, 06:35 PM   #584
FRSGT86
FRSGT86's Avatar
Drives: 2013 Raven FR-S, 2005 Dodge Ram
Two passenger side mounts here too!
Morning sucked, afternoon was going to be better because I was gonna install these, ended up afternoon sucked too.
2013 FRS 6AT in Raven!
FRSGT86 is offline   Reply With Quote
Old 01-26-2013, 06:42 PM   #585
Foobar
SLO NO MO
Foobar's Avatar
Dos pasajeros.
Old 01-26-2013, 06:43 PM   #586
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
Same here. 2 passenger side mounts.
itzzmeeken [My Journal]
86 FRS is offline   Reply With Quote
Old 01-26-2013, 07:01 PM   #587
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
Hey guys. We're aware of the situation and were terribly sorry for the mix up. We got excited to get you guys these kits ASAP and in the rush, had a breakdown in communication between our engineering dept and the folks in assembly. There are 55 of you that will/have received two identical lower brackets in error. We're going to send you guys the correct bracket first thing on Monday. Thanks for your continued support and please bear with us as we make this right. We will post again or send PMs to let you know details, but I wanted to make that you know we're on it.
Matt
Engineering
GrimmSpeed is offline   Reply With Quote
Old 01-26-2013, 09:07 PM   #588
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
I haz a sad for u...
I'm not bummed at all about the mixup as the recipient, as its a given you'll make it right.
Good thing it wasn't the whole lot.
CircuitJerk is offline   Reply With Quote
Replacing Struts and Installing Coil Springs DarrenDriven DIY (Do-It-Yourself) Guides 195 04-26-2017 04:15 PM
Stock Springs/Struts FRS jadewbj Brakes, Suspension, Chassis 1 12-18-2012 10:00 AM
WANTED (GA) - Stock FR-S/BRZ struts xwd Brakes, Suspension, Chassis 8 11-07-2012 10:43 AM
performance/aftermarker struts karma003 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-07-2012 11:26 AM
JDM BRZ Struts different than USDM BRZ Struts? switchlanez Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-30-2012 10:21 AM
