Old 09-06-2012, 11:31 AM   #1
karma003
auto-crosser/drifter
karma003's Avatar
Drives: 2013 scion FR-S black M/T
performance/aftermarker struts
R there any after market struts out yet? I want to get lowering springs cuz for 1) they're cheaper, & 2) I'm never going to adjust ride height anyways. But I don't wanna run springs on stock struts. Anyone have any idea?
karma003 is offline   Reply With Quote
Old 09-06-2012, 11:46 AM   #2
thermobox
Drives: 16 Impreza 5dr CWP
The only struts I have seen are on the BRZ STi Concept Car. From this thread http://www.ft86club.com/forums/showthread.php?t=15582 .
I would assume that Race Comp will carry this set at some point. These STi bits should cost an arm and a leg.
Originally Posted by AVOturboworld View Post
AVO Turboworld Japan was invited to a Subaru BRZ event in Honjou, Japan today. Subaru STI brought their BRZ STI Version, which has a carbon fibre hood and roof, STI suspension, 18" wheels and other parts.
thermobox is offline   Reply With Quote
Old 09-06-2012, 11:50 AM   #3
Racecomp Engineering
There aren't any options available right now unfortunately. Koni Yellows probably won't be too long but I don't have an ETA. We're planning on working with Bilstein for a sport strut eventually.
The standard struts are actually pretty solid. The valving can handle some decent spring rate, but going too low will make short work of them. But you don't want to do that anyway if you care about handling.
You can always add upgraded struts later when there are some options.
- Andrew
Old 09-06-2012, 12:38 PM   #4
thermobox
Oops. Spoke to soon. Prova has a set of struts and springs - http://jprova.co.jp/products/suspens...000001ffc.html
Thanks for chiming in Race Comp. You guys rock!! When ever I make up my mind with struts, spring, coilovers, etc I will be having you install them and aligning.
Old 09-06-2012, 03:09 PM   #5
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
That's an announcement of upcoming strut/springs, they don't actually have them yet. Like the air filter and many of the other products listed there.
AVOturboworld is offline   Reply With Quote
Old 09-07-2012, 11:26 AM   #6
karma003
karma003's Avatar
Hmmm. That sucks. I thought some would be out by now. I'm planning on dropping it 1.5". Is that too much for the stock struts? I wanted to install the eibach sportlines
Replacing Struts and Installing Coil Springs DarrenDriven DIY (Do-It-Yourself) Guides 195 04-26-2017 04:15 PM
WANTED (GA) - Stock FR-S/BRZ struts xwd Brakes, Suspension, Chassis 8 11-07-2012 10:43 AM
JDM BRZ Struts different than USDM BRZ Struts? switchlanez Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-30-2012 10:21 AM
Handling: Camber Attainable with Struts. Your Experiences? skeeler Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 11-09-2011 04:07 PM
