Old 01-24-2013, 02:41 PM   #267
Aznsky
Drives: Nissan 350Z (sold) 13' Whiteout FRS
love love LOVE the Voltex wing!!
It seems like you can afford it, but I'd recommend looking into track insurance. I didn't have it when I hit a tire wall in my old 350Z and insurance didn't cover it. Luckly I was able to sell it to a friend of mine for cheap and got some money back.
Aznsky is offline   Reply With Quote
Old 01-24-2013, 03:03 PM   #268
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Originally Posted by pcasso87 View Post
I know i should, i have my scca license. Maybe next year i will, now i just need to find more sponsors and get a bite more noticed. I will be entering global time attack this year as well as my local H2R Time Trials, we will see how it goes from there.
Cheers man :happy0180:
Sponsors?... You planning on being on TV man? Unless you're on TV there's little to no value for sponsors.
PRO86 | WTCC | STL
Old 01-24-2013, 03:20 PM   #269
Amadeus
Amadeus's Avatar
Drives: White MT FR-S
subscribed
Love the mod on the guy at 127.7 "baby seat". Maybe that's the next item to try!
Amadeus is offline   Reply With Quote
Old 01-24-2013, 06:56 PM   #270
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
Did you drill through the floor and mount the side mount bracket with spreader plates under the floor? I had to do that in my mr2
Surok is offline   Reply With Quote
Old 01-25-2013, 02:45 AM   #271
cf6mech
Drives: FRS Silver LS1 swapped.
None actually, i had them mounted with planted seat bases and omp rails and i gained zero inches so i had them bolted down to the ground and now i have tons of clearance.
Not understanding, you gained no extra head clearance?, I'm 6'5'' and looking to gain head clearance with seats while I'm wearing a helmet, I would like to know if you gained any with this set up. Off hand it looks like you have but not sure.
cf6mech is offline   Reply With Quote
Old 01-25-2013, 08:55 AM   #272
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Yep, basically drilled the floor and installed backing plates. I need to ad some washers or some sort of height adjustment because now my seat is too low i want at least one more inch of height.
Ok so when you order Seats you need to get the Side mount's, Seat Bases and rails to mount the seats on. I ordered Planted Seat Bases, Status Side mounts, and OMP Rails with the Status seats. I mounted them with all this hardware and i gained nothing in head clearance since there are 4 things between me and the floor. I took out all the hardware and mounted the side mounts directly to the cars floor, i basically drilled holes in the cars floor and bolted them down with backing plates. With the latter setup i ended up gaining tons of head room since the seats are now mounted directly onto the cars floor. The only downside is that they are fixed now there is no adjustment once they are bolted down.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
The Following User Says Thank You to track_warrior For This Useful Post:
Surok (01-25-2013)
Old 01-25-2013, 07:08 PM   #273
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
Cheers, at least the car has the underbody plastic panels so nobody will know i have drilled through it once i put the carpet back in and put rubber plugs in the holes
The Following User Says Thank You to Surok For This Useful Post:
track_warrior (01-28-2013)
Old 01-25-2013, 09:45 PM   #274
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
The car looks and sounds like its got a little bit of a push, keeping you from being able to get on the power sooner. Have you found this to be the case?
GTM_Challenge is offline   Reply With Quote
Old 01-26-2013, 09:42 PM   #275
track_warrior
Track Junkie
Yes but not a lot considering my camber is setup fairly conservative right now. I will be playing with the suspension on tuesday to see if i can correct it a bit and ill update you with how that turns out.
Anyways guys i did some maintenance on my car and a friends E46 M3 since we are both getting the cars ready for COTA next week. Enjoy some pics of his beautiful M3 .
[IMG]http://i23.photobucket.com/albums/b395/nismo350z/Scion%20FRS/E6EE6C4E-ECF4-4AEF-A672-99E5BB***B7E-1303-00000142F68B0416.jpg[/IMG]
The Following 2 Users Say Thank You to track_warrior For This Useful Post:
6-Shift (01-27-2013), juliog (02-28-2014)
Old 01-27-2013, 08:28 PM   #276
eckoflyte
Drives: Toyota 86 GTS
Question re the vorshlag camber plates, do the camber and caster adjustments move together as you slide the bearing across? Seems like they are not independent of each other.
eckoflyte is offline   Reply With Quote
Old 01-27-2013, 09:01 PM   #277
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
That M3 intake is beautiful wow...
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
Old 01-28-2013, 02:09 PM   #278
GTM_Challenge
Drives: On track
I had a lot of static camber in my s2000 and struggled with understeer all season last season. I backed the caster down from 8.0 to 5.4 and BINGO. Knocked nearly two seconds off :happy0180: It's amazing how much time you can pick up when you get the car rotated and can be full throttle before even reaching the apex. Understeer is the devil.
The Following User Says Thank You to GTM_Challenge For This Useful Post:
Old 01-28-2013, 10:30 PM   #279
track_warrior
Track Junkie
I agree, i hate understeer!!
CSG Mike (01-30-2013)
Old 01-30-2013, 05:31 PM   #280
Slurve
Slurve's Avatar
Drives: 2006 White Mazda 3
I saw this car on the trailer at Harris Hill during that Corksport track day, I have a picture on my phone lol.
Slurve is offline   Reply With Quote
The Following User Says Thank You to Slurve For This Useful Post:
track_warrior (02-03-2013)
build, fr-s, mx-5, pcasso87, track
Pick up my FRS friday... ordering wheels today. Some questions NickFRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 06-19-2012 10:14 PM
Bought it....TODAY! DEC1 BRZ First-Gen (2012+) — General Topics 28 06-10-2012 12:10 PM
Just Bought Mine Today!! Rmccoy47 Scion FR-S / Toyota 86 GT86 General Forum 75 05-17-2012 10:32 AM
BRZ vs 86 vs Miata Roadster TRACK BATTLE carbonBLUE FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 164 05-04-2012 01:34 AM
