#2157 | |
Drives: 2013 Scion FRS
Scionara to you
#2158 |
Yes, that's correct.
#2159 | |
Tells it like it is
Drives: SS1LE | F150 Diesel | Civic | S3
Anyone turbocharging the car and not buying a boost gauge is a total idiot to be honest.
-Seven || youtube.com/turnsevenvideo
![]() 2012 C6 Grand Sport 4LT 2015 Mazda 3i-T/Tech |
| The Following User Says Thank You to seven For This Useful Post: | Sportsguy83 (01-25-2013) |
#2160 | |
I Love custom Turbo kits
Drives: Limited BRZ
Turbo car tuning is very sensitive. Any chances will affect the tuning. You plan on changing several components, you have to know off the bat the base map will not work, not on this kit or any other kit. It will need a new tune.
#2161 | |
Tells it like it is
Which is why I'll probably install the kit with a boost gauge, injectors, pump, and a boost controller, and the only drive it will make will be RIGHT TO THE DYNO from my house, for a tune. And you can bet even on that 25-35 minute drive, it will never see boost.(car will already have a full exhaust by then also)
| The Following 2 Users Say Thank You to seven For This Useful Post: | Drift-Office (01-26-2013), Sportsguy83 (01-26-2013) |
#2162 |
Australian and Proud !!!!
Drives: 2012 Toyota 86 GTS Aero Kit
So is the standard map designed to work with 100% stock exhaust or cat back as I currently have no exhaust fitted and I want to know if I need to put a cheap mild steel one on til the one I want is back in stock.
BONKRS for life
#2163 |
I think the best explanation is this - it's designed to work with the standard cross-over pipe and the standard secondary catalytic converter in place. The base map can compensate for having either muffler upgrade or cat-back after that point.
| The Following 2 Users Say Thank You to AVOturboworld For This Useful Post: | GC GTS Aero Kit (01-25-2013), Sportsguy83 (01-26-2013) |
#2164 |
Thats what I wanted to know as you were saying ANY modifications are going to change the base map. I wanted to know if it was tuned with a cat back or stock system and you have answered that thanks.
BONKRS for life
#2165 |
How would it be a statement? I know I didnt use a question mark but yeah it was pretty obvious it was a question.
BONKRS for life
| The Following User Says Thank You to GC GTS Aero Kit For This Useful Post: | BRZranger (01-26-2013) |
#2166 |
Drives: Limited BRZ
My bad for making general statements. I more specifically mean for example, replacing the stock intake box for a different higher flow one.
#2167 |
Drives: Toyota 86 (old) / GR86 - (current)
Changing cat back or etc on turbo car
FYI:
changing anything after the dump pipe will not have that much of a effect and won't need a retune. you won't see any increase in boost that is noteworthy enough to warrant changing boost control settings or etc. Changing cat back exhausts is about the only thing you can change on a turbo car without a retune. In almost every case changing the air intake from what the car was tuned on to a different one would need a retune because the metered air is now incorrect and the AFR's would be off and you need to rescale the MAF in the ecu. |
#2168 |
Drives: Subaru WRB BRZ Limited
i wished i still lived in vancouver.. could have made the trip easily.. now im in toronto.
#2169 |
Drives: 2013 Raven FR-S
@AVOturboworld
Is the "Turbocharger to Secondary cat engine pipe" (Dump Pipe) a split or bellmouth opening going back? AFAIK its a 2.5" diameter but is there any plans for a factory option for bellmouth w/ a 3" outlet for 3" frontpipe and midpipes? Another question for people turbo savvy then myself, would this setup benefit from a bellmouth dump pipe, or would it not make much difference for a turbo of this size? (Considering that it may need to be custom fabricated to mate up to a 3" front pipe, and a tapered 3->2.5" midpipe). How much of an impact would the larger diameter have on EGT? My fairly uneducated idea is that having a bellmouth dump pipe should increase laminar airflow earlier in the pipe, and the larger diameter would give more surface area for heat dissipation. In turn the EGT should be lower combined with smoother airflow.. in turn increasing overall turbo performance. Also it is my understanding that the pipes closer to the turbo have the greatest impacts on power gains so tackling the dump pipe would be one of my top priorities after turbocharging... having the 3" exhaust gives extra flow and more heat dissipation (obv diminishing returns) i'd want to taper down to 2.5" to help muffle the sound a bit, plus i have a 2.5" nameless axleback already lol. Tried searching and couldn't get any confirmation on this
#2170 |
Drives: AVO BRZ
| PC Build Thread | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 126 | 01-22-2017 10:59 PM |
| FT-86 SpeedFactory - Firestorm Red - Build Thread | FT-86 SpeedFactory | Member's Car Journals | 38 | 02-26-2015 03:42 PM |
| JoeBoxer FR-S build thread | JoeBoxer | Member's Car Journals | 112 | 04-08-2013 02:19 AM |
| Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? | fred_boosted | Engine, Exhaust, Transmission | 215 | 12-12-2011 08:23 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 11:13 AM |
