AVOturboworld
Old 01-25-2013, 05:55 PM   #2157
Alienate
Drives: 2013 Scion FRS
Originally Posted by AVOturboworld View Post
The stage 1 base map would get you started up and to a tuner, but I wouldn't run it hard or long term. Changing that many components brings it beyond the stage 1 parameters.
It's the same as, say, adding a boost controller and running the car at 8psi - the base map isn't designed for that.
I am assuming this is a reply to MNSAYER with his mods and not to all of us rather stock people.
Scionara to you
Alienate is offline   Reply With Quote
Old 01-25-2013, 05:57 PM   #2158
AVOturboworld
Yes, that's correct.
Old 01-25-2013, 05:58 PM   #2159
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
^ ok but what happens when the car runs more than 5 psi .. You'd never know
Buy a boost gauge, you'll know.
Anyone turbocharging the car and not buying a boost gauge is a total idiot to be honest.
-Seven || youtube.com/turnsevenvideo
2012 C6 Grand Sport 4LT
2015 Mazda 3i-T/Tech
seven is offline   Reply With Quote
The Following User Says Thank You to seven For This Useful Post:
Sportsguy83 (01-25-2013)
Old 01-25-2013, 08:30 PM   #2160
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
^^ Exactly!!! Also, applies to people that want to change stuff and keep the base map.
Turbo car tuning is very sensitive. Any chances will affect the tuning. You plan on changing several components, you have to know off the bat the base map will not work, not on this kit or any other kit. It will need a new tune.
Old 01-25-2013, 08:36 PM   #2161
seven
Tells it like it is
seven's Avatar
Which is why I'll probably install the kit with a boost gauge, injectors, pump, and a boost controller, and the only drive it will make will be RIGHT TO THE DYNO from my house, for a tune. And you can bet even on that 25-35 minute drive, it will never see boost.
(car will already have a full exhaust by then also)
The Following 2 Users Say Thank You to seven For This Useful Post:
Drift-Office (01-26-2013), Sportsguy83 (01-26-2013)
Old 01-25-2013, 08:54 PM   #2162
GC GTS Aero Kit
Australian and Proud !!!!
GC GTS Aero Kit's Avatar
Drives: 2012 Toyota 86 GTS Aero Kit
So is the standard map designed to work with 100% stock exhaust or cat back as I currently have no exhaust fitted and I want to know if I need to put a cheap mild steel one on til the one I want is back in stock.
BONKRS for life
GC GTS Aero Kit is offline   Reply With Quote
Old 01-25-2013, 09:47 PM   #2163
AVOturboworld
I think the best explanation is this - it's designed to work with the standard cross-over pipe and the standard secondary catalytic converter in place. The base map can compensate for having either muffler upgrade or cat-back after that point.
The Following 2 Users Say Thank You to AVOturboworld For This Useful Post:
GC GTS Aero Kit (01-25-2013), Sportsguy83 (01-26-2013)
Old 01-25-2013, 10:08 PM   #2164
GC GTS Aero Kit
Thats what I wanted to know as you were saying ANY modifications are going to change the base map. I wanted to know if it was tuned with a cat back or stock system and you have answered that thanks.
BONKRS for life
Old 01-25-2013, 10:09 PM   #2165
GC GTS Aero Kit
Originally Posted by brzranger View Post
Is this a statement or question? Seems like three sentences. Not trying to be an jerk, had to read it three times to figure out what you were saying.
How would it be a statement? I know I didnt use a question mark but yeah it was pretty obvious it was a question.
BONKRS for life
The Following User Says Thank You to GC GTS Aero Kit For This Useful Post:
BRZranger (01-26-2013)
Old 01-26-2013, 12:39 AM   #2166
Sportsguy83
Drives: Limited BRZ
My bad for making general statements. I more specifically mean for example, replacing the stock intake box for a different higher flow one.
Old 01-29-2013, 06:26 PM   #2167
toyota_86
Drives: Toyota 86 (old) / GR86 - (current)
Changing cat back or etc on turbo car
FYI:
changing anything after the dump pipe will not have that much of a effect and won't need a retune. you won't see any increase in boost that is noteworthy enough to warrant changing boost control settings or etc. Changing cat back exhausts is about the only thing you can change on a turbo car without a retune.
In almost every case changing the air intake from what the car was tuned on to a different one would need a retune because the metered air is now incorrect and the AFR's would be off and you need to rescale the MAF in the ecu.
toyota_86 is offline   Reply With Quote
Old 01-29-2013, 07:59 PM   #2168
zex
zex's Avatar
Drives: Subaru WRB BRZ Limited
i wished i still lived in vancouver.. could have made the trip easily.. now im in toronto.
zex is offline   Reply With Quote
Old 01-30-2013, 01:41 AM   #2169
Ravenlokk
Ravenlokk's Avatar
Drives: 2013 Raven FR-S
@AVOturboworld
Is the "Turbocharger to Secondary cat engine pipe" (Dump Pipe) a split or bellmouth opening going back? AFAIK its a 2.5" diameter but is there any plans for a factory option for bellmouth w/ a 3" outlet for 3" frontpipe and midpipes?
Another question for people turbo savvy then myself, would this setup benefit from a bellmouth dump pipe, or would it not make much difference for a turbo of this size? (Considering that it may need to be custom fabricated to mate up to a 3" front pipe, and a tapered 3->2.5" midpipe). How much of an impact would the larger diameter have on EGT?
My fairly uneducated idea is that having a bellmouth dump pipe should increase laminar airflow earlier in the pipe, and the larger diameter would give more surface area for heat dissipation. In turn the EGT should be lower combined with smoother airflow.. in turn increasing overall turbo performance. Also it is my understanding that the pipes closer to the turbo have the greatest impacts on power gains so tackling the dump pipe would be one of my top priorities after turbocharging... having the 3" exhaust gives extra flow and more heat dissipation (obv diminishing returns) i'd want to taper down to 2.5" to help muffle the sound a bit, plus i have a 2.5" nameless axleback already lol.
Tried searching and couldn't get any confirmation on this
Ravenlokk is offline   Reply With Quote
Old 01-30-2013, 06:07 AM   #2170
nix
nix's Avatar
Drives: AVO BRZ
More pics in my build thread, will have dyno numbers over the next few days.
nix is offline   Reply With Quote
The Following 7 Users Say Thank You to nix For This Useful Post:
BRZranger (01-30-2013), FrX (01-30-2013), Jeff86 (01-30-2013), Pete156 (01-30-2013), Sportsguy83 (01-30-2013), t0dd (01-31-2013), thebear21 (02-01-2013)
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 10:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 03:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 02:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 08:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
