Old 01-15-2013, 12:36 AM   #15
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
I like the foglight idea, even if the user has to cut the fogs with a template... Mainly because some people plan to go F/I and need space for an intercooler
I'd even consider buying these and just cutting the foglight housings myself but a template would be nice.
-Seven || youtube.com/turnsevenvideo
2012 C6 Grand Sport 4LT
2015 Mazda 3i-T/Tech
seven is offline   Reply With Quote
Old 01-15-2013, 12:37 AM   #16
fastfrs
Drives: frs
would you guys sell the backing plate only?
fastfrs is offline   Reply With Quote
Old 01-15-2013, 07:48 PM   #17
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
Yes we can.
Touge Factory is offline   Reply With Quote
Old 01-17-2013, 07:41 PM   #18
000 Racing
000 Racing's Avatar
Drives: 2012 86GTS Race Car #86
and the backing plate would cost $$ ? Any indication would be good as I have the first race coming up in March and it has some big brake points .. one from about 260kph down to 80.. will it work with the Essex Sprint kit?
Thanks for the good work.
000 Racing is offline   Reply With Quote
Old 01-18-2013, 02:52 PM   #19
Touge Factory
Drives: ZN6
I believe the Essex AP racing kit uses a larger rotor, so our backing plate would have a large gap. the air inlet on the backing plate would be larger also since there would be more space on the larger rotor.
Just for the backing plate for the OEM rotors - we're estimating $275 for the pair.
The Following User Says Thank You to Touge Factory For This Useful Post:
000 Racing (01-18-2013)
Old 01-24-2013, 08:56 PM   #20
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
I noticed a lot of break fade last hill run, so I'll be looking in to this when it comes out. How bad is the install?
Ricepuddin is offline   Reply With Quote
Old 01-25-2013, 01:43 PM   #21
Touge Factory
Drives: ZN6
It's not too bad.
Remove wheel
Remove Caliper + Rotor
Remove wheel speed sensor
Remove hub: 4 bolts. Dust shield comes off at this point
Install backing plate
Install wheel speed sensor
Install Rotor + Caliper
Trim the inner fender lining slightly to allow room for hose to pass through.
Unbolt the windshield washer tank to route hose past it.
No special tools required other then your standard wrenches / sockets and a cutter of some sort.
Old 01-25-2013, 03:07 PM   #22
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
Originally Posted by Touge Factory View Post
It's not too bad.
Remove wheel
So this would be a good time to change my pads and lines. Thank you
Old 01-25-2013, 05:43 PM   #23
Touge Factory
Drives: ZN6
Yes most definitely!
If you're gonna do all of that make sure you have DOT 4 Brake fluid...
Old 01-25-2013, 06:37 PM   #24
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
Hp+ pads, and stop tech lines for the front along with a couple bottles of RBF 600 are sitting in a closet waiting to go on/in
Old 01-25-2013, 08:24 PM   #25
Calum
That Guy
Drives: 2013 asphalt FRS MT
does the washer bottle get put back?
Old 01-28-2013, 07:30 PM   #26
Touge Factory
Drives: ZN6
Oh yes.
It's just very difficult to feed the hose with the washer fluid tank there.
You just have to unbolt it to route the hose, and bolt it back up.
Our backing plates should be arriving any day now.
Calum (01-29-2013)
Old 01-28-2013, 10:19 PM   #27
Squishy
Drives: 2013 WRB BRZ
A nice option instead of the fog light piece for BRZ limited owners would be an adapter piece to screw in place (since we can unscrew the foglights themselves) to mount the ducting to, might be dandy.
Or this already an option?
Squishy is offline   Reply With Quote
Old 02-06-2013, 11:50 AM   #28
GTFrank
Let me know when this is available. Gtfrank
Please contact me when this is available. Gt frank.
GTFrank is offline   Reply With Quote
FRS bumper duct VENOM~ Cosmetic Modification (Interior/Exterior/Lighting) 36 12-12-2015 12:15 PM
Arrows Japan Brake Duct Cooling Kit & Suspension BPAuto Brakes, Suspension, Chassis 65 06-22-2013 09:35 AM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
Carbon Fiber Brake Cooling Duct JDMenrique Cosmetic Modification (Interior/Exterior/Lighting) 7 10-25-2012 12:03 AM
Brake cooling duct kit tranzformer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 12-14-2011 01:37 PM
