Old 01-17-2013, 02:52 AM   #2073
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
Thumbs up
Originally Posted by AVOturboworld View Post
... and our next big task is getting Stage 1 kits in boxes and out to customers!
Pretty Please!
Bob @ Drift-Office, LLC
Drift-Office is offline   Reply With Quote
The Following 2 Users Say Thank You to Drift-Office For This Useful Post:
BRZranger (01-17-2013), Sportsguy83 (01-17-2013)
Old 01-17-2013, 06:52 AM   #2074
Lammie
Lammie's Avatar
Drives: Subaru BRZ
Originally Posted by Drift-Office View Post
Pretty Please!
+2
I'm in the 2nd group and can't wait to see how things go with the 1st batch.
Lammie is offline   Reply With Quote
Old 01-17-2013, 08:10 AM   #2075
zohare
zohare's Avatar
Drives: '13 Firestorm Base AT
[QUOTE=AVOturboworld;655423]Sorry we haven't been giving much updates, it's been a busy week for us, but that's because we are getting ready for the Tokyo Auto Salon from tomorrow (Friday, Japan time). We've got our car and the white DAMD Turbo A/T to prep, along with everything else going on.
@AVOturboworld
Holy crap that front bumper is sexy! What is it? Also in light of heat discussion... how's the A/T holding up? Any chance of some more footage of the damd car, maybe an interior from a dig?
zohare is offline   Reply With Quote
Old 01-17-2013, 08:34 AM   #2076
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
Easy. written on it )
MSTiFK8R is offline   Reply With Quote
Old 01-17-2013, 08:43 AM   #2077
Argento_FR-S
Drives: Scion FR-S
With the standard secondary cat in place, you won't be running into overboost (boost spike) issues at those temperatures. Without the secondary cat (catless) or with a high-flow cat, that may change - but you better not be running on a stage 1 basemap at that point anyways!
This statement worries me slightly... So if I have a cat-less headerback exhaust then I run the chance of overboosting the stage 1 kit? If so then would you say that the stage 2 kit should fix this issue? What suggestions do you have to solve this potential issue?
Argento_FR-S is offline   Reply With Quote
Old 01-17-2013, 08:52 AM   #2078
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
for the guys who plan to remove our 2nd cat initially, what other boost spike management parts are there, either as part of the base system or as an upgrade if our driving style is heavy footed? I cover a region from SoCal to Seattle.
same as Previous post, what parts get added into stage II and what will it cost me?
also, I wanted to know, with either system what if any warranty there was as this kit is at the top of my turbo kit list.
thank you.
Huehuecoyotl is offline   Reply With Quote
Old 01-17-2013, 09:46 AM   #2079
FasterpromsFRS
FasterpromsFRS's Avatar
Drives: FRS
wasnt he just implying because of the extreme cold air?
FasterpromsFRS is offline   Reply With Quote
The Following 3 Users Say Thank You to FasterpromsFRS For This Useful Post:
Brody602 (01-17-2013), seven (01-18-2013), Sportsguy83 (01-17-2013)
Old 01-17-2013, 10:06 AM   #2080
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
thank you.
I'm not 100% sure if you guys are aware but the original question that I asked about over boost was due to extremely cold climate where the air is far more dense, from what I can understand North Carolina doesn't seem to go below 10°C (50°F) very often, my question was specific to air that is exposed to tenperatures of -20°C to -30°C and below, (-4°F to -22°F) therefore I don't think this would be an issue for you if you removed your 2nd cat. As for Seattle and SoCal, I'm not very firmiliar with the weather conditions there..
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 01-17-2013, 11:11 AM   #2081
zohare
zohare's Avatar
Ah. Thanks haha just found the thread about it. Couldn't see NEAR that small on my phone. I like it
Old 01-17-2013, 11:33 AM   #2082
AVOturboworld
The original question was about extreme cold conditions on the stage 1 base map, the original tune that we ship with the kit.
But - it's worth saying that if you make any major changes from a stage 1 setup, get it re-tuned! Removing the secondary cat and going catless or with a high-flow cat, is going to add 1-3psi of boost at upper rpm's, and I would insist on a tune for that if you do so.
Once you've gone FI on the FR-S/BRZ, it falls under the same set of rules as, say, a Impreza turbo or an Evo turbo model. Any major changes in the system needs a tune to correspond to it. That's because any change can result in minor to major changes in PSI at the engine.
At the engine is the key phrase here. Turbochargers are simple air pumps, not really that complicated. But if you measured PSI at the turbo itself, and then at the intake, you'd find two different figures. Piping to the intake, the intercooler, and even the design of the intake will determine how efficiently the engine gets that air over the rpm range. So 5psi at the engine may be 6psi at the turbo, for instance. And that's a fairly efficient system.
Then backpressure in the exhaust determines how well the turbo is going to do in the upper rpm range. Our base tuning map is designed around 4-5 psi range in the upper range due to the backpressure of the secondary cat, but if you went with a full catless exhaust, suddenly you've removed that backpressure, and now the system wants to go to 6psi. Nothing actually wrong with that, it's going to feel great! But the tune was not designed for that.
It should be mentioned, though, that 5-8psi is the figures we are talking about. This isn't a 20psi build that's going to spike to 24psi, this is not a high pressure solution for an STI.
The Following 4 Users Say Thank You to AVOturboworld For This Useful Post:
Alienate (01-17-2013), Bonburner (01-18-2013), Brody602 (01-17-2013), SonnyBRZ (01-17-2013)
Old 01-17-2013, 11:37 AM   #2083
AVOturboworld
thank you.
If you are planning to remove your secondary, get it tuned for a catless system. That's all you need to do to.
Stage II is still not set in stone at this time.
We do warranty the kit itself against defects.
Old 01-17-2013, 12:59 PM   #2084
SonnyBRZ
SonnyBRZ's Avatar
Drives: 15 WRX 6mt (DD), 13 BRZ Sports Tech
I apologize if this question has been answered previously.
In the future, is there a possibility for AVO to provide base maps for cars using high flow cat (300 cell for example) and aftermarket exhaust?
My target purchase date is still another 10-12 months from now.
06 Infiniti G35x - Black 5AT (DD)
13 BRZ Sports Tech - White 6spd (June 18, 2012!) - Vortech SC
15 WRX Sport - ISM 6spd - Ordered May 3, 2014
SonnyBRZ is offline   Reply With Quote
Old 01-17-2013, 01:01 PM   #2085
AVOturboworld
Yes, we'll be working on base maps for a full turbo back exhaust as well, that falls in line with the stage 2+ maps.
The Following User Says Thank You to AVOturboworld For This Useful Post:
Old 01-17-2013, 02:50 PM   #2086
Huehuecoyotl
Can you be more specific when you say you do warranty against defects. what if it breaks?
Well say for example another setup proves x miles over y time. That makes it harder to buy this kit but shopping is easier then..
The conditions of use on avoturboworld.com say three months. Just wanting to know, not trying to stir anything up or be called a troll. Obviously it's a mod, I expect to pay to play.
Just when we talk of boost spikes etc, I drive often from Washington to California. When stuff happens, just good to know the terms. I know avo from back home. Big name. Still, terms are terms.
At this pricing it really doesn't matter. Can't get turbo for less
http://www.avoturboworld.com/avoshop/conditions.php
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
