Old 01-17-2013, 01:46 AM   #1
josby
Drives: 2008 Honda S2000 (yellow)
What are these things on the rear deck?
If I get an 86, I'm thinking of building a bandpass sub box in the trunk with its port vented through a hole in the rear deck. It looks like I'll have to remove one of these things, whatever they are, to do that. I'm thinking they're either release latches to fold down the seatback, or flow-through vents for air circulation. Can someone confirm?
Thanks
josby is offline   Reply With Quote
Old 01-17-2013, 01:52 AM   #2
Demandred7
Demandred7's Avatar
Drives: 2018 Camry XSE V6
Thanks
They are for car seats. Take off the covers and attach the top tether for a car seat. They are part of the LATCH system that is law for all North American automakers to provide. I know, because I use them for my kids' seats.
Demandred7 is offline   Reply With Quote
Old 01-17-2013, 01:57 AM   #3
root
Drives: Raven FR-S
Child seat anchors.
Oops, you beat me to it.
root is offline   Reply With Quote
Old 01-17-2013, 02:05 AM   #4
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
Drives: 2013 scion frs 001467
according to the things i read a second ago, anchors for car seats.
mrlewistan is offline   Reply With Quote
Old 01-17-2013, 02:49 AM   #5
whataboutbob
AutoX-10/10ths every run
A good place to anchor a 4 point seat belt? :P
Build thread:Here
Old 01-17-2013, 11:18 AM   #6
Cade01
Cade01's Avatar
Drives: '13 White FR-S, 09 Triumph St.3 R
I think it would be too high up wouldn't it? Isn't there a certain height you want to stay close too (just below the shoulders or something?)
Cade01 is offline   Reply With Quote
Old 01-17-2013, 12:18 PM   #7
grgonium
grgonium's Avatar
Drives: Whiteout FR-S
I thought it was for hanging kids. That's what the picture on top looks like at least.
grgonium is offline   Reply With Quote
Old 01-17-2013, 12:27 PM   #8
JWA
Drives: BRZ, Exige, Boxster
Nope - they are NOT strong enough. Don't do it. Use a proper set of belts with an ASM device mounted to the upper rear seat belt anchor bolt.
JWA is offline   Reply With Quote
Old 01-17-2013, 05:48 PM   #9
root
Drives: Raven FR-S
Yup, been through Scroths info on mounting harnesses and the child anchors at NOT strong enough.and actually for the shoulder straps you want them ideally horizontal or higher.
How-To: Remove Rear Deck & Third Brake Light Moshpit37 DIY (Do-It-Yourself) Guides 63 08-01-2020 09:48 PM
Solution Found: Rear Deck Rattle jdubz Issues | Warranty | Recalls / TSB 29 10-13-2019 02:48 PM
Solution Found: Rear Deck Rattle jdubz DIY (Do-It-Yourself) Guides 31 08-23-2015 05:08 PM
Subaru TSB 12-140-12 for Rear Deck Popping sparks Issues | Warranty | Recalls / TSB 31 07-17-2013 11:11 AM
do you think the rear deck rattle... pr086 Issues | Warranty | Recalls / TSB 7 08-03-2012 04:35 PM
