Old 01-12-2013, 01:33 PM   #1
Cajun
Cajun's Avatar
Drives: asphalt fr-s AT
LED bulb help! Won't work!
Had to solder a piece of wire back on, and it still won't work. Does it matter which piece of wire goes in which hole of the black plastic cap?
Cajun is offline   Reply With Quote
Old 01-12-2013, 02:11 PM   #2
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
I assume this bulb is a switch back. Identify ground first. Then individually touch the other wires to a 12v source. Did it not come with a diagram of some sort?
Old 01-12-2013, 03:31 PM   #3
Cajun
Cajun's Avatar
If it did I don't have it, and yep it's a switchback
Old 01-12-2013, 03:49 PM   #4
mashal
DADA
mashal's Avatar
Drives: 2013
Wear gloves bro
mashal is offline   Reply With Quote
Old 01-12-2013, 11:24 PM   #5
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by mashal View Post
Wear gloves gal
Fixed that for you
Old 01-12-2013, 11:24 PM   #6
Sportsguy83
Drives: Limited BRZ
Originally Posted by Cajun View Post
Attachment 25229
Get a cheap replacement from ebay and be done with it.
Old 01-13-2013, 12:08 AM   #7
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
Wear gloves bro
Why? They are LED's, they are unaffected by oil on your fingers like Halogens or HID's are.
To OP: LED's are polarized so they only work when connected in the right direction, from my guess the lead with the diode on it (that little black cylinder) needs to be connected to the ground (common) wire which is usually the black wire. Then the other three activate the different LED Clusters.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
Old 01-13-2013, 01:03 AM   #8
EBMCS03
Drives: Argento FR-S
Im curious... What bulb is that for?
EBMCS03 is offline   Reply With Quote
Old 01-13-2013, 07:44 AM   #9
Cajun
Cajun's Avatar
It's a switchback turn signal.
I tried switching it around, I have LEDs in other spots so I get that part.
After trying it several different ways, it blew something, cause my rear tails, parking lights, and side markers don't work. Checked and double Checked all fuses, those are all good. Blinkers headlights and brake lights all work.
Old 01-13-2013, 10:45 AM   #10
boredom.is.me
Custom User Title
Yes, do not actually test electronic items in the car. You should always use or separate power source (or directly from the battery terminals). As far as whether the bulb is blown or not, it really depends on the components used to build it. I know some LEDs can handle a small amount of reversed polarity. These are SMDs though so I'm not exactly sure what they would be able to tolerate.
Although a switchback should only have two functions, I see four wires. I've never played with one so I honestly don't know. (kind of irrelevant though)
I'ld say to find a 9v battery or a little 9-12v wall power supply (like for computers and other chargers). The one with the resistor should be negative so touch that to negative, then touch the others one at a time to positive. I'm sure you've already tried that, but it's all I got.
Old 01-13-2013, 11:10 AM   #11
wbradley
Sarcastic SOB
wbradley's Avatar
Where is the wedge socket? If it broke off I'd just replace it.
If it is a switchback then it contains two circuits. That requires 2 hot wires and one ground. Look at the band on the diode. The end of the diode with the band on it indicates the direction of current flow. I'm going to guess the band indicates current leaving the device, in which case it is ground. So try red on either plain wire and ground on the diode wire.
I'd just jumper off the car battery to test as it is the only isolated 12v source you probably have access to.
Really unless you want to tinker, I'd just toss it.
Old 01-13-2013, 11:19 AM   #12
Cajun
Cajun's Avatar
I paid $45 for these switchbacks- I hate to throw it away. There needs to be 2 wires on each side (once I put the black cap on it). We tried it several different ways, and it never would work. Just trying to figure out what side each wire needs to go on when folded down. Hope that makes sense
Old 01-13-2013, 11:21 AM   #13
Cajun
Cajun's Avatar
Here is a pic of how it was before the black piece was off. Had to solder the missing piece back on. I need to figure out which wires are on which side. Yes I can do process of elimination but I don't want to blow another fuse
Old 01-13-2013, 11:22 AM   #14
Cajun
Cajun's Avatar
Woops forgot pic Name:  ImageUploadedByTapatalk1358094118.590333.jpg
BRZ HID Bulb Swap JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 19 01-24-2014 09:06 PM
Work Emotion CR Kiwami Bronze 18x8.5 +47 18x9.5 +38 (5x100) w/tires + Work lug nuts serial gixxer Wheels and Tires 41 03-29-2013 03:14 AM
bulb size for frs brichard0625 Exterior Parts - The Rest 4 07-23-2012 03:33 PM
which H11 replacement bulb 7thgear Cosmetic Modification (Interior/Exterior/Lighting) 13 07-18-2012 10:23 AM
BRZ D4S bulb ? MRZ415 BRZ First-Gen (2012+) — General Topics 82 06-28-2012 07:18 PM
