Old 01-11-2013, 09:22 PM   #1
636
636's Avatar
Drives: '23 CWP BRZ
Muffler Delete - Run Rich?
I was doing a little second/third gear pull today and my buddy who was behind me said I was pouring black smoke. I also noticed my car was popping and "backfiring" a lot upon downshifts and letting off.
All I have done is the Berk Technology single tip track pipe(muffler delete). Theres no way this would cause my car to run rich, right? Any other suggestions? I just got an oil change today, if that matters.
Thanks!
636 is offline   Reply With Quote
Old 01-11-2013, 11:23 PM   #2
FirestormFRS
I'm gonna say no. There's nothing behind the muffler that ties into the ECU.
FirestormFRS is offline   Reply With Quote
Old 01-11-2013, 11:27 PM   #3
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
I'd have to agree with you.. Logic to me says it would lean it out a bit, since it flows better and moves more air
Have you noticed a drop in fuel mileage
Gixxersixxerman is offline   Reply With Quote
Old 01-11-2013, 11:32 PM   #4
Mo707
Mo707's Avatar
What would it mean if you noticed a drop in mpg. Isn't that normal when you do something to the exhaust or remove your muffler?
Mo707 is offline   Reply With Quote
Old 01-11-2013, 11:36 PM   #5
Gixxersixxerman
If he started running rich then it should put a dent in fuel mileage, pouring black smoke just seems to run extremely rich and fuel mileage would be cut noticeably.. Now if fuel mileage jumped up, then I wouldn't worry about it, I've gained ~2ish mpg, with my injen intake and evo 3 exhaust
In some cases you do lose fuel mileage, some is because it flows more air and therefore uses more fuel, some is because like me, when I got my intake, and then later my exhaust I loved getting on it to hear the sounds... But you can gain mpg's by the engine isn't working as hard to pull air in and push it out making it more efficient.. And engine is after all a giant air pump lol..
The Following User Says Thank You to Gixxersixxerman For This Useful Post:
Mo707 (01-11-2013)
Old 01-11-2013, 11:47 PM   #6
Mo707
Mo707's Avatar
Is that why some people would get a tune?
Old 01-11-2013, 11:55 PM   #7
Gixxersixxerman
Well the electronics of the car can compensate for the intake and exhuast and things like that to be able to run safely.. Just as running from Death Valley to Denver.. The computer will make the right fuel adjustments.. But if you get a tune for your car, with your performance parts.. It will run much much better.. The exact (for the most part) fueling your engine needs.. That's why every engine will always run different.. Even two stock engines can run a couple horsepower difference.. And altitude can be a factor also.. That's why it's always best to dyno and tune as close to your region as possible..
Old 01-11-2013, 11:59 PM   #8
Jason@Nameless
Jason@Nameless's Avatar
Drives: '88 BMW 535is Turbo
Not a chance. Has nothing to do with the muffler delete. Did you take a cat out of the system also?
'Course - the car does run pig rich at WOT past about 5kRPM, but most of it gets fired off by the cats.
J
Jason@Nameless is offline   Reply With Quote
The Following User Says Thank You to Jason@Nameless For This Useful Post:
636 (01-12-2013)
Old 01-12-2013, 12:02 AM   #9
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
I notice the backfire type sounds when I lift off after hard acceleration with my custom delete. It's just things normally cause by the muffler. And I love it. Sounds so good like that, at least to me.
I have noticed some carbon build up on the tip too but the car does rich from the factory from what the tuners have said.
I have notice no change in fuel economy, other than my willingness to drive hard just to hear the sound. So much nicer than any catback I've heard
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 01-12-2013, 12:28 AM   #10
Mo707
Mo707's Avatar
Damn. Well thanks for the info. I always learn something new on this forum.
Muffler Delete SkitterSkotter Engine, Exhaust, Transmission 37 07-04-2017 01:44 AM
Does anyone have Mach V muffler delete? ScionFrsFan Engine, Exhaust, Transmission 24 09-18-2014 08:05 PM
Muffler delete zooplane Engine, Exhaust, Transmission 11 12-16-2012 08:00 PM
Dual Muffler Delete by F.M.S fmsida Engine, Exhaust, Transmission 2 10-19-2012 09:37 AM
X-Pipe with Muffler delete dav0777x Engine, Exhaust, Transmission 3 06-21-2012 11:30 AM
