Trunk won't open
Holding down the button on the key fob and the trunk won't open. Tried opening the trunk via the button from the inside of the car, and that won't work either? WTF?
#2 |
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Open with the key, inside on the left hand side is a button to turn off the remote trunk release..
You most likely hit it.. Not hard to do.. I've done it twice now |
| The Following 4 Users Say Thank You to Gixxersixxerman For This Useful Post: |
#3 |
Sallbaru
Drives: raven FRS
theres a cancel button hidden on your left inside the trunk push it and try again
#4 |
Newbie Car Enthusiast
Drives: Asphalt 6MT FR-S
disengage the valet trunk lock located in the far left side of your trunk.
#5 | |
AutoX-10/10ths every run
Been there, done that.
#6 |
Drives: BRZ DGM Limited
#7 |
Yeah, I used the key to open the trunk and changed the state of the valet button that others have referred to above. After doing this I was again able to use the button on the keyfob to open the trunk.
#8 |
Thanks that worked. Looks like some of the cargo was moving around in the trunk and hit the button.
#9 |
Drives: Argento FRS
It happened to me the second day I took it home. Freaked me out until I found the fix in the manual.
#10 |
Drives: Subaru BRZ Limited, Silver
I'm having this issue except when i put the key in the slot and go to turn it, nothing happens, it just turns and no sounds. Not sure what's going on, I'm pretty sure i heard a pop though while I was driving, I think maybe a bottle exploded or something in my trunk and pissed something off, any tips? Are there any other ways to get into the trunk??
#11 | |
Drives: Raven FR-S
Once you get the seatback down you should be able to see the glow in dark emergency anti-kidnapping trunk release T handle. |
#12 |
Shift Down
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
not sure if you tried but use the key open the trunk push the little black button on the bottom left it deactivates the remote trunk pop and trunk pop in the driver seat aswell i got scared mine didnt work after i got it i pushed it and yah basically i was dumb lol
#13 | |
Thanks for the tip, I tried the coat hanger but couldn't get any purchase on anything to help lower the seat. X_X In regards to the other guy, I stated that I already tried using the key it just kind of turns to it's limit and then refuses to go any further, there isn't any sound or anything. I notice any time i try to pop the button on the rear the key fob illuminates because it's getting the signal to pop the trunk by proximity and what not but no dice. That was what I figured too, unfortunately the key didn't work ![]() I think this is just going to turn into a dealership trip dun dun dun |
#14 |
When you turn the key in the lock, push down on the trunk lid at the same time. Might just be stuck to the latch....
| Trunk won't pop open | Reflex | Issues | Warranty | Recalls / TSB | 36 | 01-02-2021 04:16 PM |
| Stock Nav swap from BRZ to FR-S & Five Axis trunk spoiler install on BRZ trunk? | 07stealth350z | DIY (Do-It-Yourself) Guides | 8 | 08-27-2020 04:27 PM |
| Trunk will not open | Hbomb | Issues | Warranty | Recalls / TSB | 33 | 06-12-2017 07:56 AM |
| WTT: Satin White Pearl BRZ Limited Trunk with Spoiler for Wingless Trunk | R0ME0 | Exterior Parts (Aero, Lighting, Etc.) | 3 | 01-07-2014 10:36 PM |
| WTT: SoCal SWP BRZ BRZ Limited Trunk with Spoiler for Trunk without Wing | wollview | Exterior Parts (Aero, Lighting, Etc.) | 1 | 12-30-2012 04:14 PM |
