Old 12-31-2012, 11:16 PM   #1
Sparda29
Trunk won't open
Holding down the button on the key fob and the trunk won't open. Tried opening the trunk via the button from the inside of the car, and that won't work either? WTF?
Sparda29 is offline   Reply With Quote
Old 12-31-2012, 11:17 PM   #2
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Open with the key, inside on the left hand side is a button to turn off the remote trunk release..
You most likely hit it.. Not hard to do.. I've done it twice now
Gixxersixxerman is offline   Reply With Quote
The Following 4 Users Say Thank You to Gixxersixxerman For This Useful Post:
86gt? (09-28-2014), LeeMaster (01-01-2013), Sall (12-31-2012), whataboutbob (01-01-2013)
Old 12-31-2012, 11:41 PM   #3
Sall
Sallbaru
Sall's Avatar
Drives: raven FRS
theres a cancel button hidden on your left inside the trunk push it and try again
Sall is offline   Reply With Quote
Old 12-31-2012, 11:50 PM   #4
Dispect
Newbie Car Enthusiast
Dispect's Avatar
Drives: Asphalt 6MT FR-S
disengage the valet trunk lock located in the far left side of your trunk.
Dispect is offline   Reply With Quote
Old 01-01-2013, 12:08 AM   #5
whataboutbob
AutoX-10/10ths every run
^this^
Been there, done that.
Build thread:Here
Old 01-01-2013, 07:47 AM   #6
BRZnut
Drives: BRZ DGM Limited
Originally Posted by whataboutbob View Post
^this^
Did you correct it??
Old 01-01-2013, 01:10 PM   #7
whataboutbob
Yeah, I used the key to open the trunk and changed the state of the valet button that others have referred to above. After doing this I was again able to use the button on the keyfob to open the trunk.
Build thread:Here
Old 01-01-2013, 02:17 PM   #8
Sparda29
Thanks that worked. Looks like some of the cargo was moving around in the trunk and hit the button.
Old 01-01-2013, 02:45 PM   #9
pumice
Drives: Argento FRS
It happened to me the second day I took it home. Freaked me out until I found the fix in the manual.
pumice is offline   Reply With Quote
Old 01-10-2013, 09:15 PM   #10
Failscalator
Drives: Subaru BRZ Limited, Silver
I'm having this issue except when i put the key in the slot and go to turn it, nothing happens, it just turns and no sounds. Not sure what's going on, I'm pretty sure i heard a pop though while I was driving, I think maybe a bottle exploded or something in my trunk and pissed something off, any tips? Are there any other ways to get into the trunk??
Failscalator is offline   Reply With Quote
Old 01-10-2013, 11:34 PM   #11
root
Drives: Raven FR-S
Oh wow, I'd have to go look to see how it works, but I'm sure the key in the trunk is a physical release via cable, not electrical like all the other buttons. The only other way I can think of getting into the trunk is to fish for the seat back release straps. You might be able to fashion a wire coathanger hook, feed it through the back seat along the side and hook the webbing strap. If you can hook those and pull the end into the interior compartment you can then pull the two straps and release the seatback and fold down. I've been able to release the seatback from inside the cabin that way a bunch of times because when I quickly flipped the seatback up to latch it back, the straps lagged behind and ended up caught in the edge of the seatback and the ends sticking out into the cabin.
Once you get the seatback down you should be able to see the glow in dark emergency anti-kidnapping trunk release T handle.
root is offline   Reply With Quote
Old 01-10-2013, 11:57 PM   #12
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
not sure if you tried but use the key open the trunk push the little black button on the bottom left it deactivates the remote trunk pop and trunk pop in the driver seat aswell i got scared mine didnt work after i got it i pushed it and yah basically i was dumb lol
DanoFA20 is offline   Reply With Quote
Old 01-11-2013, 09:52 AM   #13
Failscalator
Thanks for the tip, I tried the coat hanger but couldn't get any purchase on anything to help lower the seat. X_X
In regards to the other guy, I stated that I already tried using the key it just kind of turns to it's limit and then refuses to go any further, there isn't any sound or anything. I notice any time i try to pop the button on the rear the key fob illuminates because it's getting the signal to pop the trunk by proximity and what not but no dice. That was what I figured too, unfortunately the key didn't work
I think this is just going to turn into a dealership trip dun dun dun
Old 01-11-2013, 11:10 AM   #14
White64Goat
When you turn the key in the lock, push down on the trunk lid at the same time. Might just be stuck to the latch....
Trunk won't pop open Reflex Issues | Warranty | Recalls / TSB 36 01-02-2021 03:16 PM
Stock Nav swap from BRZ to FR-S & Five Axis trunk spoiler install on BRZ trunk? 07stealth350z DIY (Do-It-Yourself) Guides 8 08-27-2020 03:27 PM
Trunk will not open Hbomb Issues | Warranty | Recalls / TSB 33 06-12-2017 06:56 AM
WTT: Satin White Pearl BRZ Limited Trunk with Spoiler for Wingless Trunk R0ME0 Exterior Parts (Aero, Lighting, Etc.) 3 01-07-2014 09:36 PM
WTT: SoCal SWP BRZ BRZ Limited Trunk with Spoiler for Trunk without Wing wollview Exterior Parts (Aero, Lighting, Etc.) 1 12-30-2012 03:14 PM
