Old 01-10-2013, 01:19 PM   #855
OrbitalEllipses
Drives: Attitude
Originally Posted by djdnz View Post
READ. Front mount heat exchanger. You have one with your oil cooler.
Intercooler. Oil cooler. Radiator. Condenser. Radiator. How many heat echangey thingamabobs does one need?!
OrbitalEllipses is offline
Old 01-10-2013, 01:19 PM   #856
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
Water/air heat exchanger are much thinner than Air/air heat exchanger ( aka FMIC) their for much less restrictive to airflow going to engine radiator.
W/A heat exchanger are less than 1" thick. compare to FMIC that are often 2.5" thick
Mars2 is offline
Old 01-10-2013, 02:20 PM   #857
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Originally Posted by 2forme View Post
I remember reading in one of the other forced induction threads that the overheating issues people are having are more due to the intercooler sitting in front of the radiator (negating some of the cooling effect), rather than cooking the oil.
Oh the joys of adding heat, of any kind. FI or NA.
OEM radiators have their airflow impeded from the factory to begin with via the A/C Condenser. We could all improve the functionality of our radiators by removing that!
Other options: larger radiator, aluminum radiator, radiator shrouding to increase air flowing through it, high flow fans, reduction of glycol in coolant mixture, etc etc etc.
PRO86 | WTCC | STL
rice_classic is offline
Old 01-10-2013, 02:31 PM   #858
RYU
RYU's Avatar
Drives: really slow...
Now that is just crazy talk!!! I'd rather not have FI than remove my AC lol
RYU is offline
The Following User Says Thank You to RYU For This Useful Post:
ATL BRZ (01-10-2013)
Old 01-10-2013, 04:53 PM   #859
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I was planning to add a Killer Chiller type product that uses the A/C system to cool the intercooler liquid anyways.
King Tut is offline
Old 01-10-2013, 04:55 PM   #860
OrbitalEllipses
Drives: Attitude
Freon cooled IC core...I want to see frost on my goddamn intercooler!
carbonBLUE (01-10-2013)
Old 01-10-2013, 05:05 PM   #861
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
lolz heat exchanger rides shotgun in a bucket of ice
Jeff86 is offline
The Following User Says Thank You to Jeff86 For This Useful Post:
Old 01-10-2013, 06:38 PM   #862
Frostyman
Drives: 2013 Raven FRS
ALL OF THEM.
Frostyman is offline
Old 01-10-2013, 09:47 PM   #863
sw20kosh
Drives: 2013 Black FR-S
It may get cool to the touch but the heat a sc or turbo will produce quickly overcomes the capacity of a refrigerant system.
Its been tried and tested in many forms. Doesn't work.
sw20kosh is offline
Old 01-10-2013, 09:48 PM   #864
OrbitalEllipses
Drives: Attitude
I wasn't serious.
Old 01-10-2013, 10:02 PM   #865
Mitch
form follows function
Drives: RIP '13 BRZ
I wasn't serious.
It's a legitimate question, though. Still could be worth doing the math to see if there's a break-even point on a cooling system that takes advantage of heat of vaporization draw for a compressible gas refridge loop. Could just be that the added power draw is never made up for by the power added by the increased air density, but I'd like to see the numbers. I'm going to be doing a lot of heat calcs soon, so I might do the numbers once I get warmed up again.
Mitch is offline
Old 01-10-2013, 10:34 PM   #866
Noob4Life
86 Noob
Drives: Firestorm FR-S
IMO the extra power draw would be worth it for the engine. Heat is the main killer of engine so if I could lose 1-2 hp just to keep the intake temps down a good chunk id probably do it.
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
Noob4Life is offline
Old 01-10-2013, 11:15 PM   #867
OrbitalEllipses
Drives: Attitude
Just do what the drag guys do and drop a load of ice into it .
While I like this kit, I prefer air-to-air intercoolers on the street simply because there's less to go wrong. AWICs can cool very well, I've just always been wary of that scenario where I need to fill some water and I don't have any, thus stranding me.
Though trying to get a blown coupler reaffixed onto an air-to-air IC charge pipe on the side of the highway is no better AND I've actually been in that situation.
Old 01-11-2013, 12:50 AM   #868
stockysnail
Just the tip
stockysnail's Avatar
This is why I'm just doing the one without the intercooler. ~80-100hp more with the non-intercooled car is plenty on this light car.
stockysnail is offline
***Recaro / Racetech / OMP / STATUS / Defi / Apexi / HKS / Innovate / AEM / Cobb***** Touge Factory Interior Parts (Incl. Lighting) 9 11-29-2012 02:13 PM
lost screw for sensor intake Mr.Jay Engine, Exhaust, Transmission 5 10-21-2012 09:26 PM
Lowest Prices on all Gauges and Electronics! Defi|STRI|AEM|INNOVATE+More Rev Works Audio/Visual, Electronics, Infotainment, NAV 28 10-09-2012 05:04 PM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 12:42 PM
Missing rubber piece for intake screw ngabdala Engine, Exhaust, Transmission 1 08-31-2012 06:10 AM
